Abit IT7-MAX2 rev 1
  • FujiMan
    • Aug 2007
    Abit IT7-MAX2 rev 1
    I have a Abit IT-Max2 rev 1 board that posts showing the wrong cpu installed. 2.4ghz shows as a 1.8ghz. 3ghz shows up as 1.5ghz.
    Here is a list of caps near cpu:
    7 - Rubycon mbz 3300uf 6.3v
    1 - Lelon 470uf 16v
    3 - ??? (silver cans) 1200uf 16v
    The silver cans only have a logo which looks like an unconnected oval.
    These are all over the board:
    8 - Teapo 220hf 16v
    9 - Teapo 1500uf 6.3
    None of them are visibly defective (no open vent, leakage, etc).
    I will try to pull board and test the power supply under load check vdc.
    Will check CPU as well on another board to see if it is the culprit.
    Any hints? suggestions? I'm willing to have it repaired if needed.
    Thanks.
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Abit IT7-MAX2 rev 1
    Which board is it ? - heading says Abit IT7-Max2, and post #1 says Abit IT-Max2
    Quick Google shows IT7-Max2 is based on i845PE chipset, which will limit it to processors running 400mhz Front Side Bus (FSB) and possibly 533mhz, although the Rev.1 may mean 400 only
    A 2.4ghz showing as 1.8ghz tends to confirm that - namely 18 multiplier with 100mhz FSB (quad pumped to make it 400mhz), instead of 18 with 133mhz
    And 3ghz is probably just not supported by i845PE
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Unable to edit my original post #2, although I thought I was within 2 hours, anyway ....
      A 3ghz processor will probably be 200mhz FSB, so showing as 1.5ghz will be 15 multiplier with 100mhz FSB, instead of 15 with 200mhz
      • RJARRRPCGP
        • Jul 2004
        • 6304
        133 Mhz should work, especially, if it's like the MSI's version. (845E Max)
        100 Mhz is usually for Celerons. (Except for Pentium 4 2.2)
        (Pentium 4 2.2 was made for 100 Mhz FSB.) (And likely the same with the 2.0s)
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Wrong RAM can cause it to kick down too.
          Mann-Made Global Warming.
          - Dr Seuss
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
