Hi, excellent site you have here. I read an article about the "great capacitor caper" in Australian PC User magazine a few months ago, they included a reference to this site and here I now am.
As subject line, I have a Leadtek Winfast A250 TD (GeForce Ti4400) AGP card with visibly bulging caps. Have had the card for going on four years now and it's never given any trouble operationally, but just pulled it out recently when I upgraded to 6800GT (which is itself not running 100% right but that's another story) and saw this.
Check out the three green guys (yep... GSCs ), they are all bulging to different extents but the one front and left is most pronounced and has a bit of orange-brown, what I suppose is leakage, on the top as well.
Now stupid question time: most of what I've read on this site takes the approach of: computer not running right -> see failed capacitors = you have a problem. Now this card was running absolutely fine at last notice... but if the caps are showing physical signs like this, then they are definitely going to fail? I should get them replaced I want to continue using this card for the long haul? I've already spoken to a local guy who I use for servicing and repairs to see if he could replace them for me, and it sounded like he could, but he basically said it wasn't worthwhile and that the expansion is only caused by heat, they would still be sealed (this was only on the phone though, he hasn't seen it). Should I really keep using the card in this state, and only worry about it when/if it starts showing operating problems (or blows up)?
The card was/is destined to go in a PC I'm putting together using other contemporary components I had spare, which I otherwise intended to run till the end of time... goodness knows I still have a 200MHz Windows 95 PC going here
 ), they are all bulging to different extents but the one front and left is most pronounced and has a bit of orange-brown, what I suppose is leakage, on the top as well.Now stupid question time: most of what I've read on this site takes the approach of: computer not running right -> see failed capacitors = you have a problem. Now this card was running absolutely fine at last notice... but if the caps are showing physical signs like this, then they are definitely going to fail? I should get them replaced I want to continue using this card for the long haul? I've already spoken to a local guy who I use for servicing and repairs to see if he could replace them for me, and it sounded like he could, but he basically said it wasn't worthwhile and that the expansion is only caused by heat, they would still be sealed (this was only on the phone though, he hasn't seen it). Should I really keep using the card in this state, and only worry about it when/if it starts showing operating problems (or blows up)?
						 Leadtek Winfast A250 with bulging caps
								 Then you'll have a card you won't have to worry about (caps-wise anyway).
  That being case made me think it was probably a good thing I didn't try it myself, but still I didn't expect to spend that much. Maybe someone here can shed light on what a double-soldered board means for me?
