BF6 Mosfets
  • Smiffy
    • Feb 2006
    • 16
    BF6 Mosfets
    Hi All
    Just picked up a BF6 with a few blown caps.There are 2 mosfets marked as 76129S next to the ATX connector and I cant find any datasheets for them.They are getting hot with a Tualatin 1.3 so I would like to upgrade them.Does anyone have any info about them?.Many thanks for any help.
    Smiffy
  • Rainbow
    • Aug 2005
    • 1374
    Re: BF6 Mosfets
    • davmax
      • Dec 2005
      • 899
      Re: BF6 Mosfets
      The previous link malfunctions. Try this one: http://www.ortodoxism.ro/datasheets/...HUF76129P3.pdf
      The MOSFET is a powerful device at 56A 30V. It might be an idea to find out why they are getting hot. Most mother boards have several sharing the Vcore load ie two or three phase convertor.
      Can you show a pic of board and MOSFETs?
      Gigabyte EP45-DS3L Ultra Reliable (Power saver)
      Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      160Gb WD eSATAII Server grade for backup.
      Samsung 18x DVD writer
      Pioneer 16x DVD writer + 6x Dual layer
      33 way card reader
      Windows XP Pro SP3
      Thermaltake Matrix case with 430W Silent Power
      17" Benq FP737s LCD monitor
      HP Officejet Pro K5300 with refillable tanks
      • davmax
        • Dec 2005
        • 899
        Re: BF6 Mosfets
        The MOSFET on your board is apparently obsolete. So if you need a replacement that is better go here for data: http://www.st.com/stonline/products/...00nf03l-03.pdf
        This MOSFET is characterised to be fully ON with a 5 Volt logic input that the original required. It has lower ON resistance and rated at 100A.
        It appears that the manufacturer sells off web page here :
        http://www.st.com/stonline/stappl/pr...TC+0800%202006
        Nvidia 8500GT 256Mb
        33 way card reader
        Windows XP Pro SP3
        • davmax
          • Dec 2005
          • 899
          Re: BF6 Mosfets
          On further inspection the replacement suggested is not so good for high speed converter such as VRM. The switching speeds are substantally slower. Current rating is just one factor.So will need a better alternate. I suspect that as current rating rises the switching speed slows.
          I will take a wider look for you.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • davmax
            • Dec 2005
            • 899
            Re: BF6 Mosfets
            This device is faster
            http://www.st.com/stonline/products/...tb200nf04l.pdf
            The following Fairchild device looks designed for this application but the turn off times are poorly specified ( at 1 amp only for an 80 amp device) additional the ON resistance is higher.
            http://www.fairchildsemi.com/ds/FD%2FFDB7030L.pdf
            On balance the ST device looks better and probably more obtainable from manufacturer.
            About as far as I will go at this stage.
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
            • davmax
              • Dec 2005
              • 899
              Re: BF6 Mosfets
              Here we go again!!! The challenge when upgrading to a higher current MOSFET is that the input capacitance increases. Too much increase will slow down the switching speed as the driver chip stuggles to charge and discharge the input capacitance. This will increase switching losses and increase heat. In some cases this may damage the driver chip.
              Take the last two replacement possibilities.
              1. Fairchild FDB7030L input C = 2440pf
              2. STB200 input C = 6400pf.
              The original 76129S input C = 1350pf
              From these figures it would be reasonable to use the FDB7030L as a replacement but the STB200 is pushing input C too high.
              It has been fun searching this out. Hope this helps.
              I re-emphasise that you try to find out why the MOSFETs are getting hot before replacing.
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Re: BF6 Mosfets
                Another thing to look out for on some MOSFET datasheets is that some vendors give the continuous current rating of the die, but the true rating is limited by the package - TO-220 and D2PAK are typically 75A or 80A, though STMicro has some parts that are package-limited to 90A or 100A.
                High gate capacitance (or gate charge) can cause problems two ways. If the driver can't handle it, turn on and turn off can be slowed and the driver may get hot. If the driver can handle it, this still uses extra power to drive the gate.
                PeteS in CA
                • davmax
                  • Dec 2005
                  • 899
                  Re: BF6 Mosfets
                  True Pete. The STB200 is rated for 120 Amps @ 100C case temp, that is very good and determined mainly by the very low ON resistance.
                  I guess in the Smiffy case if there is no increase in load we will get lower heat generated in a lower ON resistance device as long as the switching losses are kept down. It seems the main issues are:
                  1. Is any increased loading causing a temp rise? Like faulty caps.
                  2. Is there anything preventing the heat from being dissipated? Like insufficient cooling.
                  3. Is the original design placing too much stress on two MOSFETs? It seems a low number of devices. What is their role? Or is it just two getting hot out of six?
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                  • Smiffy
                    • Feb 2006
                    • 16
                    Re: BF6 Mosfets
                    HI Guys
                    Thanks for all the help and info.
                    Heres a link to a pic of the BF6 as I havent got a dig camera at the mo
                    http://www.firingsquad.com/hardware/bf6/images/bf6.jpg
                    The blown caps are the three in front of the row of 12.EC10,EC11 and EC12.I'll replace them and then see what happens to the mosfets which are the 2 on the right of the atx connector.Im running at the mo in bios at 113Mhz fsb for 1470Mhz on 1.40v.Will possibly have to lower cap size as cant find 1500Uf 8mm andthose three are a bit tight on space.Can fit 10mms in all the rest by the look of it.
                    Ta for help
                    Smiffy
                    • Rainbow
                      • Aug 2005
                      • 1374
                      Re: BF6 Mosfets
                      It's easy - that board is not designed for Tualatin CPUs, there are only two MOSFETs for CPU power so they get hot when the current draw is high.
                      • Smiffy
                        • Feb 2006
                        • 16
                        Re: BF6 Mosfets
                        Hi Rainbow
                        So its basically not designed to supply the current the Tualatin core needs.
                        Smiffy
                        • Smiffy
                          • Feb 2006
                          • 16
                          Re: BF6 Mosfets
                          Hi Guys
                          Replaced the 3 caps.Only had 1000 uf but looks like Davemax was right.Mosfets much cooler now.
                          Ta all
                          Smiffy
                          • Smiffy
                            • Feb 2006
                            • 16
                            Re: BF6 Mosfets
                            And have found out that the other 2 mosfets(55N03LTs) are providing the 3.3v line so as Rainbow says its pushing it for 2 mofets to supply the current.Will replace all the caps and heatsink the mosfets with some airflow over them as well and will see if it can cope with it then.
                            Thanks for all that helped with info.
                            Smiffy
                            • Neo2_000
                              • Apr 2005
                              • 180
                              Re: BF6 Mosfets
                              Hi Guys,
                              Some time ago I finished a fun project where I used a slotket adaptor and a tualatin adaptor on a stock ASUS P2B mobo (Pentium II 350 MHz) to convert it to a Tualatin. The project was a success and my mates would spin out when they saw the display flash up 1200MHz on this old piece of crap
                              I was thinking of using the Tualatin CPU adaptor on an Intel D815EEA mobo, but am now having second thoughts after reading this.
                              Any thoughts?
                              • gg1978
                                • Dec 2004
                                • 431
                                Re: BF6 Mosfets
                                Originally posted by Neo2_000
                                Hi Guys,
                                Any thoughts?
                                THe thing with Tualitin core chips is not just that Vcore went down, and Icc went up, though not much, the thing is that they changed the GTL bus reference voltage, i believe for VRM 8.2 8.3 and 8.4 GTLREF is 1.5V, but for VRM 8.5 (Tualitin) they dropped GTLREF to 1.25V, and added another VID input. This is going from memory now though. Presumably having Vcore at 1.5, if the CPU expects 1.45 or 1.4V is no big deal, but i've heard that the .25V difference in GTLREF may be bad for the I/O buffers of the CPU itself. If you only have VRM 8.2 support, i believe minimum Vcore for those boards is 1.8V, which is very much in Tualitin frying range.
                                I never though Tualitins were very heavy on the Vcore Icc though, no more than a Katmai core chip anyway.
                                The thing is that most, if not all P3 class motherboards typically use a single phase VRM design, with the 8 pin SOIC MOSFET packages that don't do nearly as well as dumping heat as the TO218 or TO220 package provides.
                                • Rainbow
                                  • Aug 2005
                                  • 1374
                                  Re: BF6 Mosfets
                                  Hi Guys,
                                  Any thoughts?
                                  It's Intel board - any CPU not specified to work by Intel will probably not work. Intel boards can happily start up and say in the POST that the CPU is not supported.
                                  Asus P2B is not a piece of crap, I'm running Celeron Tualatin on that too. At 1.8V as mine can't do less (the latest versions can, however).
                                  In fact, most non-big-brands-like-Intel P2 and P3 boards use TO263 mosfets.
                                  • Neo2_000
                                    • Apr 2005
                                    • 180
                                    Re: BF6 Mosfets
                                    http://www.hardwarecooling.com/produ...ket_370_FC-PGA
                                    Thanks for the replies guys. Here is the type of adptor I am talking about.
                                    Adapts Socket 370 motherboards made for FC-PGA processors for use with FC-PGA2 (Tualatin) processors
                                    http://hardware.mcse.ms/message195198.html
                                    In reference to the D815EEA:
                                    the Tualatin adaptor (Upgradeware and Powerleap) have both been tested to work on this motherboard using BIOS P10, which I have.
                                    (I have yet to verify this experimnetally)
                                    The adaptors do have some circuitry so I think that they must adjust the voltage down for the Tualatin core - otherwise what possible use are they?
                                    My general concern is with Rainbows statement:
                                    After reading this, my concern is not that the motherboard bus voltages may stress the processor, rather the opposite: that the demands of the processor might stress the motherboard. Shoud I be comncerned about this and how can I determine whether the D815 has the necessary hardware to supply the Tualatin? Do Tualatin boards have more FETs than copermine boards?
                                    P.S.
                                    From memory you can mod the older boards to deliver the correct voltage. If you are interested, I will see if i can dig up the web reference.
                                    • Rainbow
                                      • Aug 2005
                                      • 1374
                                      Re: BF6 Mosfets
                                      If it was tested on that Intel board, then it should work for you too. Maybe they forgot to disable that in the BIOS
                                      Some Tualatin boards have 4 MOSFETs, some only 2, but better (lower Rds(on), higher current rating).
                                      I've had BE6-II for repair with shorted MOSFETs that was used with Tualatin for some time.
                                      • Neo2_000
                                        • Apr 2005
                                        • 180
                                        Re: BF6 Mosfets
                                        http://hardware.mcse.ms/showthread.php?threadid=208649&perpage=10&pagenumber=1
                                        Unfortunately the problem could be that the Intel BIOS simply doesn't
                                        support Tualatin processors correctly - certainly they aren't officially
                                        supported. The Tualatin also uses a lower Vcore than the minimum
                                        specified for the motherboard (1.5v vs 1.65v), and draws slightly more
                                        than supported current (~20A vs 18.2A) What does the BIOS show for
                                        processor type and speed when the Tualatin is installed?
                                        You could try the latest BIOS version (P11), but I doubt that will help
                                        - in fact it may stop the board from booting at all since one of the
                                        changes between P10 and P11 was "Added prevention of using Blocked
                                        unsupported processors."
                                        Looks like this guy had stability problems. Reference to BIOS upgrade locking out unsupported processors as Rainbow said.
                                        Note also the reference to the supported current for the D815EEA being exceeded by Tualatin demands. ~20A vs 18.2A
                                        • BlackScreen_22
                                          Harman Kardon sub TS11 (ds15 amplifer) blows fuse and mosfets
                                          by BlackScreen_22
                                          Hi, I'll start by saying that I'm not an expert and I've reached a point where I don't know what to try/do anymore...
                                          Starting from the beginning: I opened this subwoofer for the first time with a very strong smell of burnt electrical components, I realize that on the amplifier board there is a hole between V+ OUT and GND about the size of a finger, the damaged components were the shorted mosfets, two damaged zener diodes and two capacitors. I bought everything, I fixed the hole by cutting the pcb and putting a piece of a perforated board.
                                          I had no problems connecting mosfets and capacitors,...
                                          08-27-2024, 12:46 PM
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • flerre
                                          Gainward Phantom GTX 980 - mosfets w/ integrated driver NCP5369
                                          by flerre
                                          Hi!
                                          Managed to get a Gainward Phantom GTX 980 in an auction for a bin with components.
                                          No video out so I started fault finding and found a blown fuse for 3 mosfets. Started checking for shorts and found what I think is a short through all of those 3 mosfets; 0.1 ohms between "VIN" input and "VSWH" output. All mosfets in this gpu are the same ones (NCP5369) with integrated drivers and when I tried measuring the other ones through these ports they were somewhere in the kilo-ohms range.
                                          So, could I safely assume all of these 3 mosfets are...
                                          03-13-2022, 12:14 PM
                                        • NanoTesting
                                          Lenovo Ideapad 15IIL05, turns on and off with charger BUT works by injecting 20v after main mosfets
                                          by NanoTesting
                                          I got a 15-IIL05 that failed to turn on BUT IT DID TRY TO TURN ON and then turned off after 30+- seconds, i disassembled it and found a screw loose inside the case.
                                          With charger it turns on, fan spins but gives no image.
                                          Tested main mosfets no short, tested 3.3v,5v,DRAM, CPU etc and they were present.
                                          Reflashed BIOS, same problem.
                                          Replaced both main mosfets.
                                          Checked main mosfets again and i noticed that they closed once the laptop shut down, so i decided to bypass them and used a bench PSU to check how much power the laptop was drawing while trying to turn on, 20v@3A,...
                                          10-30-2024, 10:48 PM
                                        • debruina
                                          Pioneer VSX-859RDS with all mosfets gone
                                          by debruina
                                          I am working on a pioneer VSX-859. It started with only one problem but i ended up with a lot more. Probably caused by me
                                          Anyway it started with a DSP NG message on the display. That one was easy and was caused by a bad 5v rail. Replaced the capacitors and the message was gone. Everything seems to be working except for a blob sound every time i switched from source. Eventually i tracked that down to a leaking battery on the analog board. Repaired some via's and lines and everything worked ok. That same circuit also caused a not working DCdetect protection. ...
                                          08-29-2023, 11:54 AM
