ECS K7S5a PRO wierdness
  • bigbeark
    • Jan 2010
    • 661
    So I have this K7s5a PRO, no bad caps, but it wouldn't load Ubuntu via the CD Drive. Tried switching drives, cables ets but no luck.
    A couple of weeks ago i recapped it, got rid of all the OST and G-Luxons.
    Had to move the SCSI card around but finally it likes a PCI slot and I'm off to the races, board works good, runs a bit hot (53C).
    The other day it wont boot. I note the CD Drive is blinking. I pull the cable and it boots up fine. But it can't read the SCSI drive. Pulled the board out of the case, went over my solder joints. Decide to try a different CPU. So I try a Sempron with 333FSB. This should not work as board only has 266FRB. But the thing boots. I put the board back in the case, it boots up at 100FSB, try to reset to 166, no boot. Pull the battery to reset CMOS, nothing. Go back to 266FSB Athlon XP, boots OK. Put the thing back in the case, boots fine, reset to 133FSB, boots fine. I can hear the SCSI drive click, but it cant find the device. Pull the SCSI drive and card for known good, no action. I then note that the SCSI card is doing the same LED flashing as the CDROM was doing!!
    I'm thinking this is some timer fault.
    Other than dissing ECS (I know), anyone care to comment on this odd behaviour (mine and the boards )
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: ECS K7S5a PRO wierdness
    the SIS 735 chipset can't handle that high a clock, and you're risking it by trying
    • Pyr0Beast
      • Feb 2009
      • 406
      It might handle it with ddr ram
      • Sparkey55
        • Jan 2010
        • 1523
        Maybe it could use updated bios flash. Had wierd problems with ECS KT600-A boards like that latest bioes fixed it.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Agree.
          Update or at least reset the BIOS.
          Mann-Made Global Warming.
          - Dr Seuss
          • Uranium-235
            Comrade Glimmer
            • Aug 2007
            • 5042
            • US
            I've had a few K7S5A's in the past, not a pro, but its the same chipset. the 735 northbridge cannot stably run that fast
            • bigbeark
              • Jan 2010
              • 661
              I wasn't actually expecting it to run @ 333FSB.
              I was surprised it actually booted at all.
              I was also surprised that it wouldn't reset itself on reboot.
              I removed the Bios battery - no effect. It did the same thing with a 100FSB
              Athlon that I tried to set to 133 in error.
              The CPU survived the mistake.
              Just peculiar behaviour all around from this mobo.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Try reflashing the BIOS even if it's to the same version.
                - Dr Seuss
                • bigbeark
                  • Jan 2010
                  • 661
                  Re: ECS K7S5a PRO wierdness - GONE
                  So I swapped out the ECS board, tried my recapped SOYO, same deal, Then an Intel board, same thing. Finally gave up, used an IDE drive and that worked fine.
                  Took the same parts that had a problem, put them in another case, bingo everything works!
                  Somehow the non-working case must have a current leak or ground somewhere that only affects SCSI.
                  Could it be that SCSI, because it uses LVD (low voltage differential) is very sensitive to insufficient voltage?
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Not likely.
                    LVD refers to the signal voltage, not power.
                    - Dr Seuss
                    • pepebmx
                      ThinkPad T14 Gen 3 - Boots Only on Charger
                      by pepebmx
                      Subject: Lenovo ThinkPad T14 Gen 3 - Boots Only on Charger, Fan Spins Full Speed with Battery
                      Laptop: Lenovo ThinkPad T14 Gen 3
                      Serial No: PF-437QTG
                      PCB: NM-E441 Rev 1.0 (JT4C1/JT6C1/JP6C1)
                      Extracted BIOS: Will upload tomorrow
                      BIOS Password: None Issue Description:
                      • Boots only on charger โ†’ Works normally when connected to AC.
                      • With battery connected:
                        • Fan spins at full speed, no display.
                        • Not all voltages present (some missing).
                      • Battery charges correctly (detected in Windows, shows percentage).
                      • When battery is plugged in while in Windows:
                        • Laptop shuts
                      05-08-2025, 01:53 PM
                    • abajor
                      A2141 Screen replacement. Boots screen freezes on Apple Logo 1/3 status bar unless connected to second monitor.
                      by abajor
                      Having this very weird issue.
                      The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
                      I swapped with a working screen from an A2141 waiting for parts.
                      The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
                      The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has...
                      04-27-2024, 01:37 PM
                    • Andrew Bower
                      BIOS Unlock for HP zbook studio x360 g5
                      by Andrew Bower
                      I've been working on this for about a week. I've read the threads and ordered and attempted to use a programmer to pull the BIOS dump from the laptop with no luck. I tried using RcUnlocker, but keep getting a dll error even after reinstalling the C++ Redistributable. I also tried NeoUnlocker and another program. None would pull up the chip.
                      That leaves me asking for help unlocking this BIOS. The laptop boots up to the Domain login with no issue. I can pull up the boot menu. Any attempt to open the BIOS or the BIOS upgrade menu is met with a password request....
                      12-04-2024, 05:55 PM
                    • abrahim110
                      [Help Needed] Acer Aspire 5 A517-52G โ€“ Removed Onboard RAM, Now Working But Battery Not Charging
                      by abrahim110
                      ๐Ÿงต [Help] Acer Aspire 5 A517-52G โ€“ Onboard RAM Removed, BIOS Mod Done, Battery Not Charging
                      I have an Acer Aspire 5 A517-52G-53NB laptop.
                      The onboard (soldered) RAM was faulty, so I physically removed the chip.
                      I also successfully modified the BIOS using the SPD Removal Tool โ€“ the laptop now boots fine and works with an 8โ€ฏGB DDR4 SO-DIMM installed.
                      โœ… System status:
                      • BIOS mod is done (SPD removed)
                      • Laptop boots to Windows normally
                      • RAM is detected and stable
                      โŒ Problem:
                      The battery is not charging:
                      • Power adapter
                      Yesterday, 06:15 AM
                    • James Boden
                      ps5 edam 330 boots but no video? ..changed HDMI port and ic ...ddc clock help?
                      by James Boden
                      Good evening, I've been stuck on a problem for a smidge now and not sure how to proceed..
                      Ps5 boots etc but just doesn't have any video .. put a new hdmi connector on and a new encoder.. and all the diode readings are good except
                      15- DDC clock - 671 - Iam getting 677
                      16- ddc data - 671 -iam getting 677
                      And hot plug (19) is 695 when should be 686..
                      Any ideas on what could cause this ? I have no knowledge of hdmi signals or EDM 033 board view to track where they go etc ..
                      Jimโ€‹
                      05-10-2024, 02:16 PM
