So I have this K7s5a PRO, no bad caps, but it wouldn't load Ubuntu via the CD Drive. Tried switching drives, cables ets but no luck.
A couple of weeks ago i recapped it, got rid of all the OST and G-Luxons.
Had to move the SCSI card around but finally it likes a PCI slot and I'm off to the races, board works good, runs a bit hot (53C).
The other day it wont boot. I note the CD Drive is blinking. I pull the cable and it boots up fine. But it can't read the SCSI drive. Pulled the board out of the case, went over my solder joints. Decide to try a different CPU. So I try a Sempron with 333FSB. This should not work as board only has 266FRB. But the thing boots. I put the board back in the case, it boots up at 100FSB, try to reset to 166, no boot. Pull the battery to reset CMOS, nothing. Go back to 266FSB Athlon XP, boots OK. Put the thing back in the case, boots fine, reset to 133FSB, boots fine. I can hear the SCSI drive click, but it cant find the device. Pull the SCSI drive and card for known good, no action. I then note that the SCSI card is doing the same LED flashing as the CDROM was doing!!
I'm thinking this is some timer fault.
Other than dissing ECS (I know), anyone care to comment on this odd behaviour (mine and the boards
