HP IQ775-Asus A8SN-CF motherboard
  • suiramix
    • Mar 2011
    • 131
    This is my first post and I am asking for some help regarding Asus A8SN-CF mobo part of HP IQ775 touchsmart desktop. This computer does power on, but no video on display, no BIOS splash, all fan running on high speed. Can be turn off by press and hold power button for more than 3 sec. I removed the power cord and hold the power button for 30sec to drain the system. As soon the power cord was plug-in the computer starts with same blank display.
    The next step I removed the cover and I noticed on the motherboard 3 swollen capacitors- United Chemi-con KGZ-820uF/ 6.3V (near CPU and video card) and I did replaced only those one with new same capacity value …but same results.
    Question: what is the easiest way to verify which is defective … do I have to replace all of them?
    I am aware even I will change all capacitors still have the same problems !
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    Re: HP IQ775-Asus A8SN-CF motherboard
    you might be the victim of the nvidia 6100 northbridge solder going soft. reflow or reball
    or it could be some of the other KZG's, sometimes they die without bloating
    but most likely, its the nvidia chip
    • mockingbird
      • Dec 2008
      • 5484
      This is one odd looking motherboard:
      • Scenic
        o.O
        • Sep 2007
        • 2642
        no wonder.. it's one of those odd all-in-one thingys..
        http://www.ovi-online.com/bigpic/438...0703022223.jpg
        to see if the board still has some life left in it, remove the RAM and power it up. it should start beeping at you about missing RAM..
        if it's not even doing that, it doesn't look too good for this board :/
        • suiramix
          • Mar 2011
          • 131
          Hi guys
          Thanks for advice , and yes I agree with you about weird shape and basically everything is odd: the power supply , power supply connector , the video card (MXM connector) and there is no room for air flowing.....reading other forums those HP touchsmart PC are notorious regarding video card Nvidia 7600 which require reflow (reball) ...
          So I did remove the video card and RAM and unfortunately no change..no beeping...same thing it starts without pressing the power button...I will try to check the power supply voltages!?
          Cheers!
          • mockingbird
            • Dec 2008
            • 5484
            It's not just the videocard, it's the northbridge. I think the 6100 northbridges are the defective ones but better double check to make sure. 7100 I know for sure are defective.
            • Uranium-235
              Comrade Glimmer
              • Aug 2007
              • 5042
              • US
              ^the point I was trying to make. if the chip isn't dead, try to reflow or reball it
              • suiramix
                • Mar 2011
                • 131
                Uranium and mockingbird are 100% right..the northbridge is failing due to high temp, poor airflow and useless thermal pads (like all those HP laptop DV6000-9000 series) ...and hard to believe even after I "succeed" to damage the motherboard (see "cap"photo), the computer is running after reflow-ing Nvidia 6100 !
                Thanks guys for your help !
                • Uranium-235
                  Comrade Glimmer
                  • Aug 2007
                  • 5042
                  • US
                  congrats! I prefer reballing cause 80% of reflows iv'e seen revert after a few weeks
                  but then again, i've never reaballed anything before, something I hope to start doing in a few weeks
                  • richrow2
                    This is my first post and I'm afraid it's going to sound stupid, but since I'm having the same problem with my IQ770, I need the help. What exactly do you mean when you say to "reflow or reball" the northbridge chip? And how do you check for this problem?
                    • somervillearron
                      • May 2011
                      hi could you help me please i am purchasing a broken one of these it is the vga but it power on ok and boots into windows because you can hear it i was wondeing can i use the screen for another computer if the worse happens i know it plugs into the board with them stupid plugs what i need to know is the name of the plugs and if i could get a converter to vga or i could put a cable on it i just havnt seen the pc yet and i was wondering if that would be possible to use the screen on my other pc
                      thanks and sorry i know this threads really old and also what do you think the chances are the board has the same problem as this guys?if so what and where should i look for the repair i can solder ok
                      • projekt1
                        • Jul 2011
                        Just came across this thread. From the looks of the last two posts I would'nt expect to get much help either but its worth a shot.
                        Problem: I have a IQ775, at startup the screen immediately turns on but just has horizontal lines and never changes from that, no boot screen or anything. I did a quick search and followed a disassembly video on YouTube. So I removed the video card but now I don't know whether it'is the card or the motherboard since reading this thread.
                        Question: Now that it has been torn down, how can I pinpoint the problem? Should I jusr replace the video card and hope for the best or not?
                        Thanks for the help.
                        Edit: Added some pictures for reference and maybe you experienced ones can tell whether if something looks good or bad.
                        • glovecaps
                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                          by glovecaps
                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                          11-25-2024, 04:23 PM
                        • Docus
                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                          by Docus
                          Hi everyone 😀,
                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                          06-10-2025, 04:24 PM
                        • Archimedes
                          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                          by Archimedes
                          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                          Fans are spinning. Blindly could install windows11 and got the device manager...
                          07-30-2024, 05:14 PM
                        • dragon3x
                          After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                          by dragon3x
                          Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                          power on.
                          Here are some examples :
                          (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                          switching supply area).
                          (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                          than 6.3 V.)
                          1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                          I replaced capacitors with aluminum-polymer.
                          3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                          03-21-2025, 02:46 PM
                          ASUS P5GC-MX motherboard recap
                          by momaka
                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                          So here is what the motherboard looked like with its original caps:
                          CPU VRM area up close…...
                          01-27-2021, 11:59 PM
