Weird HDD fault - data recovery
  • DoOm86
    • Nov 2022
    • 42
    • italia
    Hello, today I worked on something weird.
    Hard disk segate barracuda 3tb 3,5'' shows just around 4gb partition (no allocated and not working).
    Tried on Linux besides windows as an external hard drive and it's the same result. With disk manager or other software the same.
    Programs to test the HD often don't start or show bad status (included the segate test).
    Somewhere online it says it can happen due a corrupt firmware of the hdd (and segate has no firmware for this HD).
    Client is asking for data. At the moment I have don't have a same board to tried a chip/board swap.
    Suggestions?
  • stormanimal83
    • May 2014
    • 74
    Re: Weird HDD fault - data recovery
    customer has to be thankful this is not an hardware or even software encryptet SSD. there would be not a chance then...
    please do not change something like partitions partition table or do alike changes by any partiton managing software! not even in windows disk utility...
    if data is important and u are sure the fault has got something to do with firmware u can buy same drive in used condition and try to measure for a fault on the board...
    its very important to not change anything. i u already tried data ist lost and there is no chance...
    in case its something wrong with the partition table there is good (no freeware) software to buy for it. i used something in the past it recovered all the files but i cant remeber the name...
    • DoOm86
      • Nov 2022
      • 42
      • italia
      Yeah I think the only thing to try is the swap of the pcb, but I'm not convinced at all the board could be the problem since the HD has been recognized and I didn't find any problem on it (at least no shorts and the main components besides the chips are fine)
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8184
        I don’t think a PCB swap would work here either. I guess all you can do is to ask Seagate what your options are.
        • stormanimal83
          • May 2014
          • 74
          a complete swap wouldt work i think so too... because the partiton table isnt stored on hard disk itself... trhe newer the drive is the harder it is to repair. i got a toshiba 16 TB drive here bought for cheap from ebay (no spin)... the mainboard is paired to the mechanical part as there is another board inside. there are even two bios chips on the mainboard.... i´m waiting for solutions as its not that old yet.... i think in future there could be solutions for this....
          in your case it should´nt be that hard...
          • DoOm86
            • Nov 2022
            • 42
            • italia
            Since the client didn't give me much time to work on it and honestly I tried everything I could but being sure to not make things worse, i gave the customers the price for the HD to be sent to a company I work with for data recovery where they can open up the faulty HD. I'll update you all with the diagnostic if the client will accept the job.
            For segate, I try to talk with them but they regardless few useless advice and the basic stuff to try, they could not help me to understand the fault better even though they assure me that HD has no "well known" problem. On internet I found others having the exact same fault on the exact same HD, but no one seems to know precisely the cause, unfortunately.
            • volinakis
              Chromebook recovery failed - how to fix it
              by volinakis
              So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
              Finally I found a site where they suggested to try with an older image and ... it worked!
              What I did:
              - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
              09-18-2023, 03:26 PM
            • duwane
              A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
              by duwane
              Hi All.
              Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
              The issue:
              Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
              10-26-2022, 07:02 AM
            • welp
              PS5 Disk Tray issues.
              by welp
              I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
              Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
              Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
              So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
              With that knowledge I preceded to check all the fuses for the 12v rail on the main...
              12-19-2024, 02:04 PM
            • myth77
              macbook pro a2141 can not make recovery
              by myth77
              So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
              So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
              06-19-2022, 11:21 AM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
