macbook pro a2141 can not make recovery
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
    So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I check all the voltages and everything seems fine...I only dont have vccgt but i am not sure is that ok for this model?
    I detached lcd connector and used usb-c to hdmi and i get the picture on the external monitor. On the external monitor i saw a question mark and some message to go to the apple store to see how to start it. So i google how to recovery but the ineresting thing is it only gives me internet recovery...So i connected to wifi...downloading was fine...but i believe when it tries to install it with apple logo it starts recovery but only get to 1/3 then stops...nothing. I tried several times but nothing. I used different combination of the keys but allways i only get the option for internet recovery. I did NVRAM reset...but it didnt help. Keyboard, touchpad, speakers, fans and battery working...though i dont have backlight and access to that upper part of the keyboard...i am not sure is it coming on after installing MacOs? I dont have access to utilities on start and so on...Dont get it? someone help?
    My thinking is ....maybe recovery will not finish because ios is not detecting the original screen...I know that similar issues were with iphones...but as i wrote i am not expirienced in macs...So any help how to make a recovery is appreciated. The nephew is considering buying a new screen but i can not confirm that it is the only issue because recovery is not possible...for now. So any help appreciated. Thank you!
  • mon2
    • 14631
    Re: macbook pro a2141 can not make recovery
    A question mark means the logic board does not see the SSD. You can check if all the SSD voltages are present or not.
    A replacement screen will not stop the logic board from working. There are many on AliExpress.
    A suggestion is to debug this unit to perfection using the external monitor. Once it is stable, then buy the replacement screen.
    The part of when it installs seems to be the same as the question mark...you have a flaky SSD operation. Start with inspecting the SSD voltages noted in the schematics. Post your measurements.
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • sofles
      Macbook Pro 16" A2141 screen artefacts, kernel panic
      by sofles
      Hi there.
      I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
      I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
      Now situation looks like this, If...
      02-05-2025, 05:05 AM
    • reformatt
      by reformatt
      07-31-2025, 08:37 PM
    • myth77
      A2141 no signal on external screen while recovery
      by myth77
      I dont do Macs, so i really dont know their specific behavior, but i received one (from the title) with smashed screen. It is turning on..but i dont want to buy a new screen to find out it is locked or dead or something. So, i removed lcd connector from motherboard and i am using adapter from usb-c to hdmi to connect laptop to external monitor. It seems that laptop is wiped because it goes to recovery (internet) and at first it seems all ok...i can see apple logo and downloading ios, then when it goes to installation i can see progress bar, and after couple of seconds it goes to "no signal"...
      06-27-2023, 07:14 AM
    • MagJ_
      MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
      by MagJ_
      Hello Everybody,
      I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
      10-09-2024, 02:51 PM
