re-cap network equip
  • mattch
    • Mar 2010
    • 121
    I never thought of this, but i really like the idea...
    i wonder if i could get some "non-working" cisco equip and re-cap the life out of it? that way i could hopefully get a cheap lab out of it all
    im goign to check the net for market of not-working equip if theres even one out there, then take a peek at the 2600 and 2800 i have to see what i might be working with. but if rough memory serves me right then i dont recall many caps inside them though..
    bad idea?? i guess i would never know what im getting like that since it would be doa as-is, or i could check the local collage for bad equip ? ?
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: re-cap network equip
    maybe bad psu sometimes too.
    hp procurve is interesting also
    • AudioCraZ
      • Sep 2009
      • 147
      The best place to pick up stuff is at large auctions, or when colleges are having a public auction. I scored 4 bay networks, 24 port 10/100 rackmount switches for $15, plus whatever else was on the table. Keep an eye out for public auctions. There are always tons of them, and every now and then, you will get a score, just keep the radar open.
      • NxB
        • Feb 2009
        • 1595
        You don't only have to recap it. You can replace transistors and ICs too. Haven't seen these kinds of problems on real pro networking gear.
        The large companies who use it also tend to replace and not repair.
        • retiredcaps
          • Apr 2010
          • 9271
          Most large companies (98% if i recall correctly) that have Cisco gear have SMARTnet maintenance which includes next business day or faster hardware replacement. So companies tend not to repair.
          Cisco will repair the defective item either itself or through some 3rd party and then put it back into the SMARTnet pool. If that exact same item (they have all unique serial numbers) is repaired more than 3 times, it is junked/recycled.
          So if you find junked Cisco equipment, the chances for "recapping" for a fix is very slim. It is probably more serious than that.
          If you want Cisco gear, you can try and find used CCxx equipment or use a software/website that simulates the Cisco IOS CLI and do you work from there.
          --- begin sig file ---
          --- end sig file ---
          • shadow
            • Feb 2007
            • 732
            Cisco have the software package Packet Tracer which simulates a full network and simulates the Cisco IOS Operating System. Having said this, it is not exactly the same as the real hardware...there are some differences between the simulated IOS and the real IOS running on hardware.
            • NxB
              • Feb 2009
              • 1595
              Thanks! Didn't know about the simulator. I need to learn this as I feel like a newb when I console into these.
              • mattch
                • Mar 2010
                • 121
                Packet tracer has come a long way, its a 5.2 now. Its good for basics, thats about it. OSPF can cause to crash if you look at it the wrong way, frame relay is buggy specially sub-int, no bgp, lot of switching capability stripped.
                From what i hear, the simulator is made by seperate company, and only select cisco features are implimented, BUT WAIT! NOT only that: the features are implimented how ever that company wants, so sometimes its not exactly how the IOS behaves!
                sometime causes headaches for profs becasue some people teach them selves by actually simulating in PT. Sooooooo Students read the book and jump to the simulator, packet tracer, and things dont work and/or different.
                I would suggest a cisco emulator. The ONLY one that i know of it
                GNS3, which is combo of dynamips,dynagen,pmu all in once nice gui.
                GNS3 uses REAL IOS IMAGES, so its the real deal. you can setup very complex networks as long as your CPU can handle it.
                my c2duo 1.8 is %50 with 7x 3750s idling.
                • ant3202
                  • Jun 2006
                  • 275
                  • Singapore
                  ya you are right, most they brought service contracts,
                  when equipment were bad, we replace them, either by buffer stocks or few days later by cisco.
                  To NxB:
                  packet tracer is great for beginners.
                  GNS3 is great to start as it supports real IOS.
                  ios software may be harder to get / download @ cisco as you need an account to access
                  • mattch
                    • Mar 2010
                    • 121
                    To NxB:
                    find the name of the IOS image and google that, you will get:
                    -documentation on that image from cisco
                    -file sharing sites that host it.
                    • NxB
                      • Feb 2009
                      • 1595
                      GNS3 it is.
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        This is due to security regulations set out by the USA. Many IOS images contain 3DES or equivalent and certain countries are not allowed to use these images.
                        That is why you have to register, verify your country of origin, click on agreements, etc.
                        This restriction was in place well before 9/11.
                          • 31070
                          stupid restriction,
                          most encryption was developed by hackers in other country's - maybe the u.s. shouldnt be allowed to use them!
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            funny, I actually got a Cisco SRW2048 from goodwill for $20 today (MSRP ~$800). It turns on, and actually boots up, but does act kinda wierd after a while (dropped packets, etc). True enough, 22 bad 6.3 1500's. I just ordered some ruby's from topcat and I bet it will work since he switch does generally work, but has stability issues. the outside is VERY scratched up so I probably won't sell it unless I run into a local business that needs one for work. other then that, i'll probably use it in our shop
                            way to go linksys, fail an $800 switch, with $10 worth of cheap Chinese or Japanese caps
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Wow, TopCat gets a Mac for $10 at Goodwill and now this. I should drop in my goodwill once in a while to check this out. :-)
                              You definitely snagged a great deal for $20.
                              What brand are the failed caps?
                              Don't forget that these switches run 24x7 and depending on the AC or lack of AC, these switches can be cooked to death all day long which would accelerate the death of the caps.
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5042
                                • US
                                haha.
                                I also got one of these
                                http://www.superwarehouse.com/Promis...15100/p/341172
                                for $100. totally works, and had 7 working 200gb drives in it. its good to know the guy who runs the place
                                the caps are "Stone". which look almost like an american brand. Actually every cap is Stone, but only the 1500 6.3's are bad
                                hehe. if topcat is looking for more space to store peoples attachments, i'm sure I can sell it to him and he can fill it with 2tb drives in a massive 28tb raid 5 array. Uses a scsi 160 ultra high density connector (external)
                                • retiredcaps
                                  • Apr 2010
                                  • 9271
                                  I thought goodwill was just about clothes? I don't expect to see electronics there. I'm definitely go to drop by and see what I can get for $10 or $20.
                                  How about a pic of the "stone" cap? The first hit on the search engine is
                                  http://www.ystone-led-capacitor-manu...nufacturer.htm
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    well, there is also good will "Computer Works". In our area (DFW) All the computer equipment donated gets shipped to he goodwill HQ store, which processess it, tears it down, and re-sells it by the pound, some to Dell, some as 'refurbished' to the community, and sometimes if you can kiss enough ass and know enough people, you can get stuff good priced. but then again, some stuff is priced insane. I got the vtrak for $100 but a 512M stick of PC-133 untested can be $50. the head guy there is good at making deals with independent buyers of stuff by the pound, but does not know that some stuff isn't worth crap
                                    and yup, that is the brand. These are the 'XR' and 'XS' series. I should not judge it by the fact there is no Chinese characters on it, and its written in a nice 'times new roman' font
                                    • retiredcaps
                                      • Apr 2010
                                      • 9271
                                      Both XR and XS series are rated for 2000 hours. So if the switch has no AC I can see the temp rising. I believe I read for every 10C temp increase, the life of the cap decreases by 1/2.
                                      8760 hours/year. Assuming this switch is 3 years old, that would be 26,280 hours. So with some rough "math"
                                      2000 hours @ 105C
                                      4000 hours @ 95C
                                      8000 hours @ 85C
                                      16000 hours @ 75C
                                      32000 hours @ 65C
                                      Linksys switches are typically NOT found in an AC environment.
                                      • Uranium-235
                                        Comrade Glimmer
                                        • Aug 2007
                                        • 5042
                                        • US
                                        it has 3 side fans, which are in working condition
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                          ASUS P5GC-MX motherboard recap
                                          by momaka
                                          Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                                          This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                                          So here is what the motherboard looked like with its original caps:
                                          CPU VRM area up close…...
                                          01-27-2021, 11:59 PM
                                        • harp
                                          simple win network with optimization issue
                                          by harp
                                          simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                          06-23-2025, 11:01 AM
