Long shot, but Centurylink IPV6 users here?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Are there any Centrurylink IPV6 users here and still working?
    My IPV6 connectivity died, and wonder if anyone found a fix to it, or at least heard anything about it?
    • 31092
    Re: Long shot, but Centurylink IPV6 users here?
    check the router firmware wasnt updated.
    a lot of isp's here keep tweeking the router firmware without asking.
    no reason not to stick with ipv4 though.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I was actually doing the ipv6 routing on my own pfSense box because my functional CPE/Routers do not support IPV6. As far as I can tell at the moment, it's a Centurylink problem, I don't see any packets coming back from the 6rd endpoint...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I just got off of centurylink "chat". He said IPV6 is for business accounts only... WTF. Not only that, it contradicts their webpages. He told me to call tech support.
        So I called them, so far, not any better. So much silence, I hope she's actually researching vs hoping I go away... I'm fearing the latter...
        OH NO... "No need for ipv6" excuse!
        Transferred to PC support.... "Nope, not us, call back to internet support."
        Uuuuggghhh...
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          been on centurylink for a decade. IPV4 here, on an ancient DSL router.
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
            • 31092
            call the legal department.
            tell them they have a case of false advertising and you intend to sue unless it's sorted out in an amicable way.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              https://internethelp.centurylink.com...v6rd-faqs.html says:
              Originally posted by centurylink's webpage
              What is the cost for IPv6?
              There is no additional charge for IPv6. If you need your IP address to stay the same, this requires a static IPv4 lease. Once you have leased a static IPv4 IP or block or IPs, then you can use the 'derived IPv6' address. Charges apply to the IPv4 lease.
              I had an Actiontec Q1000 (which natively supports ipv6) and a PK5000 die on me. Does not appear to be bad caps unfortunately (the Q1000 keeps crashing and the PK5000 randomly loses packets destined for my own LAN). For now I'm back to a GT701WG (with wifi disabled because it doesn't support WPA) and using pfSense for IPV6 which had been working for many months if not years... which stopped last week.
              I have a GT701 somewhere which would be my last last resort, and I have a M1000 to play with. Maybe I should look into non-Actiontec modem-routers?
              The first DMT modem-router I had was a Cisco 678 (and I had a Cisco 675 CAP router before that). The firmware in these two are miserable, and the 678 died on me too.
              Of all the hardware that die on me, these three categories just kill me:
              - Video Cards (with high power GPUs)
              - Hard Drives
              and now
              - DSL modems
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I tried ipv6 6rd on my Linux box directly, still no go. Same behavior as the pfSense box - packets go out, no packets come in.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  I tried my Q1000 again... it seems to work for now...along with ipv6! wtfbbq. Did clink decide to only allow that Q1000 to do ipv6?
                  • magneh
                    NAS QNAP TS-651 - Long shot, anyone with BIOS dump?
                    by magneh
                    Hey guys.
                    I have this TS-651 NAS that turns on with no activity or POST.
                    These units have the Celeron clock problem, which is not the case of this unit as measured the 25MHz signal at PIN1 of LPC connector, and its fine.
                    But it does not post. all coils have power when turned on.
                    Does not bip without ram or any USB activity. No HDMI output.
                    I tried to look for a BIOS dump for this model, but unable to find.
                    Contacted QNAP support, they only accept repairing the board, they dont give BIOS files. amazing.
                    I know...
                    06-10-2022, 03:57 AM
                  • szreder6
                    HP Pavilion 14-ce0505sa, 5 long 3 short, no display. g7a-2g da0g7ambd1
                    by szreder6
                    Hello guys,
                    I have a problem with my laptop as in the title, black screen, capslock displays error code 5 long 3 short, no voltage on the coils above the CPU, before removing the drive I had 0.8v there, power led flashed 5x long and the battery would not charge (current jumped from 0.5a to 2.8a), now on the power led I have a steady white light or orange when the battery is connected.
                    What I did:
                    - Laptop was not detecting ram, loose pins on ram slot, error 3.2 disappeared, ram working tested in another laptop
                    As far as I know the laptop was in another service center...
                    11-22-2024, 05:17 PM
                  • Ferimonka
                    HP Envy 15-FH0501sa 3 long 2 short capls lock light
                    by Ferimonka
                    Hello guys,
                    As per title says I have a Envy 15-FH0501sa , Ryzen 5, 16 Gb version.
                    Motherboard number is JPB51 LA-M798P rev.1.0
                    SN CND3362R3S
                    The laptop is getting power and funs stop spinning after few swcconds. It was liquid damaged so we get it to turn on. However 3 long and 2 shor Caps lock lights showing. Power button turns the laptop on but not off.Battery is charging.
                    Please help and advice. I attachet the bios dumb in case the bios is the problem.
                    Many thanks.​...
                    04-29-2025, 02:17 AM
                  • Gjackson
                    Ps4 Pro long blue light of death
                    by Gjackson
                    I have an NVA-001 Ps4 Pro with long blue light of death, visual inspection looks fine apart from dust and the very dried thermal paste which I cleaned and replaced, I scoped the board around for any shorts on capacitors and there were none, no blown fuses either. Looking under a thermal camera, southbridge gets warm along with APU and phases for the APU. I cannot tell if RAM is too cold? maybe not powered? but RAM chips are all the same temperatures. At this point I removed NOR and enabled UART to diagnose further. The only thing I get from UART is this following message:
                    08-21-2023, 02:41 PM
                  • lapfix
                    Hp 15 capslock 5 long 3 short pb.
                    by lapfix
                    Hello friends.
                    hp 15 -da009nk ...la-g07cp.
                    got this lap with capslock 5 long 3 short.
                    Try new dump f.48 still the same.
                    try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
                    ​​​​all voltage are présent.
                    pl301/302= 3 and 5 volt.
                    pl1001 1.082v.
                    pla1 1.033v
                    plz1 vcc core 1.058v
                    plg1 0v..i think it s the Intel grpahic
                    plw1 1.373v.
                    plv 3/plv4 vga core 0.918v
                    consumption 0.498.
                    original bios version f.02..
                    any help!...
                    02-18-2025, 03:34 AM
