Hp 15 capslock 5 long 3 short pb.
  • lapfix
    • Mar 2020
    • 2750
    • my workshop
    Hello friends.
    hp 15 -da009nk ...la-g07cp.
    got this lap with capslock 5 long 3 short.
    Try new dump f.48 still the same.
    try another dump f.04 power on..no display..consumption 0.498..no caps lock blinking.
    ​​​​all voltage are présent.
    pl301/302= 3 and 5 volt.
    pl1001 1.082v.
    pla1 1.033v
    plz1 vcc core 1.058v
    plg1 0v..i think it s the Intel grpahic
    plw1 1.373v.
    plv 3/plv4 vga core 0.918v
    consumption 0.498.
    original bios version f.02..
    any help!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Consumption is same with ram/without ram?
    Have you checked 2.5V rail is present or not?
    Ram reset checked?
    Communicated on SDA/SCL pins of ram slot checked?
    Ram slot pins failure is quite common on this mb-so check under microscope.
    • lapfix
      • Mar 2020
      • 2750
      • my workshop
      Sorry to be late and thank you
      YES same consumption with or without ram = 0.480 V
      2.5 v is present
      No ram reset , RC32 1.2V from 1 side
      pin 108 ram slot = 0.057v and 0.831 KOHM
      CD92 not exist
      So the DDR_DRAMRST# is not present
      i can t take if SDA/SCL communicate or not
      anything else to check !
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You dont have DSO? If yes, measure atlest voltage on SDA/SCL pins.
        Have you tried touching up the ram slot pins?
        I beleive you tried another ram stick and bios flash.
        • lapfix
          • Mar 2020
          • 2750
          • my workshop
          Thx mcplslg
          yes don t have dso
          Clk and data have both 3.4 v
          Yes i change ram and bios..with a New Virgin bios consumption don t reach 0.280 amp and no capslock blinking..
          yes i make a heavy press at ram and ram slots no change
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Very very likely its SOC fault.
