About network cards failures...
  • hikaruichijo
    • Aug 2015
    • 123
    • Spain
    Hi, I'm curious if when cable network card fail, it is always the chip what' get's damaged? are there other pasive components than can get damaged?
    I've seen a lot of integrated network cards fail, when the card is a realtek one, no problem but when it's another one, like an intel, 3com, broadcom... it's a shame and if it's a laptop it's is a real trouble.
    Thanks.
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: About network cards failures...
    Thanks.
    I've never ever seen a network card failure. I've heard/read people removing lightning-damaged NICs from motherboards when they were shorted and preventing the mobo from booting, but honestly 0 failures. Most NICs are really simple, so I image that yes, it's the actual chip that dies.
    • hikaruichijo
      • Aug 2015
      • 123
      • Spain
      I have an Asus A7N8X with the nvidia network card damaged, everytihing else works including the other integrated nic. And now I'm testing an old Compaq Evo N600c that has the intel nic damaged but everything else seens ok.
      Replacing the nic chip itself it's more than dificult.
      • R_J
        • 9535
        You could also check the jack itself as it could be a magnetic type (has built in transformer) its possible it could be an open winding, jacks are easier to replace if thats the problem
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          Simply removing it and using a pci-e card should suffice. I picked up a couple of these recently and they worked perfectly.
          http://www.ebay.com/itm/200892532413...%3AMEBIDX%3AIT
          • hikaruichijo
            • Aug 2015
            • 123
            • Spain
            Well, adding an expansión card to a desktop board is a common workaround but I was wondering if it was posible to repair the card because its integrated and on laptops like I said is a pain in the ass ....
            Anyway I allways avoid realtek network card like they were fire....
              • 30985
              that's my prefered card.
              avoid SMC cards
              • mariushm
                • May 2011
                • 3799
                We have brand name cards in reputable stores here starting from around $11, no need to hit eBay for them, here's just a couple as example
                TP-Link 3468 : http://www.pcgarage.ro/placi-de-retea/tp-link/tg-3468/
                Edimax EN-9260TXE V2 : http://www.pcgarage.ro/placi-de-rete...en-9260txe-v2/
                Also worth mentioning, there's USB 3.0 network cards, with chips that can actually go up to 1gbps, not just usb 2.0 chips with usb 3 connector.
                The ASIX AX88179 chip is probably the first that has built in usb 3 and they seem to work fine, here's just a couple of usb 3.0 adapters which should work fine :
                Cable Matters SuperSpeed USB 3.0 to RJ45 Gigabit Ethernet Network Adapter in White : http://amzn.to/1qqh4km
                Plugable USB 3.0 to 10/100/1000 Gigabit Ethernet LAN Network Adapter (ASIX AX88179 chipset, Windows 10, 8.1, 8, 7, Vista, XP, Linux, OS X, Chrome OS) : http://amzn.to/226Ldkf
                They're also backwards compatible with USB 2.0 ... Could be great to have around, for example if you have an old laptop or a PC and you want to backup data from them before formatting drives or whatever.
                The cpu usage would be a bit higher at high speeds compared to native pci or pci express cards but they're a decent alternative nevertheless.
                • hikaruichijo
                  • Aug 2015
                  • 123
                  • Spain
                  Well this is offtopic because I wanted to know if anybody repaired a damaged NIC.
                  But anyway I runaway fron any solution based on realtek/marvel etc... that kind of chips relly a lot on the cpu. They are a lot cheapper for some reason...
                  • hikaruichijo
                    • Aug 2015
                    • 123
                    • Spain
                    The transformer is that tipical black rectangular component that is usually close to the NIC chip?
                      • 30985
                      yes
                      • shovenose
                        Send Doge Memes
                        • Aug 2010
                        • 6575
                        lol... and that matters how when you have a multi-core processor?
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8698
                          I've had two NICs fail, two flaky NICs (one on PCI card, other onboard), one failed one that sort of still works, and rest have been very reliable. Not sure what's up with the onboard one (Realtek. Sometimes disappears from PCI table if you reboot computer, works fine on cold boot.)
                          • hikaruichijo
                            • Aug 2015
                            • 123
                            • Spain
                            So this transformer is present on all old nics i've seen, what is the function it has? If the nic got damaged because a lightning is posible that this transformer got damaged not the chip?
                            • hikaruichijo
                              • Aug 2015
                              • 123
                              • Spain
                              Well it's like when having and "hardware acelerated nic" or not, realtek chips send interuption requests to the cpu for a lot of thins and when the cpu get's interupted it does not do another things and a good nics don't do that, they have the hardware necesary to handle all the stuff necesary and only feed the cpu with the data.
                              When a cpu receives an IRQ request it doesn't matter a lot if it's multi core or not.
                              I'm don't have a good level of English and I can't explain it better sorry...
                              Maybe another forum member knows what I'm talking about and can explain it....
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8698
                                Much like in real life, interrupts are expensive. Realteks tend to require more of them to get any certain number of bytes through compared to more expensive chipsets that can handle mailbox/DMA. However on low utilization machines and OS that handles interrupts efficiently, this isn't that much of a problem.
                                That being said, most of my realteks work ok. Except that flaky motherboard and one PCI that fried its onboard LDO... These are both rtl8169 based...
                                • R_J
                                  • 9535
                                  The transformer is internal to the jack itself. I repaired a fta receiver that someone replaced the jack on and just used a regular rj45 jack, I could never get better than a 10mb connection, I did some checking on another one I had and found it used a transformer type jack, I found one and installed it and now it connects at 100mb like it should. they are easly checked with a meter
                                  I believe most motherboards use this kind of jack but I could be wrong
                                  I just checked a couple motherboards and they use magnetic rj45 jacks. like this site http://www.btoptech.com/products/rj45-usb/91.html the transformer is internal
                                  • hikaruichijo
                                    • Aug 2015
                                    • 123
                                    • Spain
                                    So old cards have this transformer on the board an newer cards have it integrated on the jack itself.
                                    That's a great step forward on what I was investigating.
                                    But I still don't know what's the function of this tranformer.
                                    I'm going to look if it's posible to buy this tranformers new.
                                    P.D. I know that a lot of people would say that this is a way of lossing time but I have the tendency to loose time in this kind of thins, don't know why.
                                      • 30985
                                      function of the transformer is to isolate each system from the network, and to increase the current of the signal at the expense of the voltage so as to boost the effective range.
                                      • hikaruichijo
                                        • Aug 2015
                                        • 123
                                        • Spain
                                        Thanks a lot for the info!!
                                        I'm testing the rj 45 jack on the board of the Compaq n600c and it seens to have the tranformer integrated an shorted because i don't see it on the board and the pins have continuity with the board.
                                        I'm goinng to look for another boards to compare the results and look for another jack.
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • davg
                                          Home network connection problem
                                          by davg
                                          I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                          03-06-2021, 07:13 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                        • XxMicroSoldering
                                          ASUS Rog Strix G17-712LV Laptop Liquid damaged
                                          by XxMicroSoldering
                                          Hello Guys
                                          I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                                          10-17-2024, 10:45 AM
                                        • harp
                                          simple win network with optimization issue
                                          by harp
                                          simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                          06-23-2025, 11:01 AM
