How to check configuration on a modem
  • SteveNielsen
    Retired Tech
    • 2327
    Re: How to check configuration on a modem
    Manually configure terminal to the serial port you're using. It does not auto-detect.
    • ricosavy
      • Jul 2012
      • 457
      • united states
      One problem i have is the computer can not see modem since i am running windows 7 since latest drivers are for windows vista dont see any for windows 7.
      • ricosavy
        • Jul 2012
        • 457
        • united states
        It is manual configured i seems to be connected just not getting much of a response
        • fzabkar
          • Mar 2009
          • 772
          If you are using a USB-serial adapter, then you need to install the drivers for the adapter.
          Some Windows versions ship with HyperTerminal. Some people prefer PuTTY. In HyperTerminal you would create a "Direct to COMx" session. Choose 8 data bits, no parity, 1 stop bit, hardware handshaking. Select a baud rate of 115200bps to be safe. Some modems can go higher.
          Once the port is configured and the modem attached, keep typing "AT <enter>" until you see an "OK" response. This is to allow the modem to autobaud.
          For modem identity information type ...
          ATI0
          ATI1
          ATI2
          ... and so on. ISTR that ATI9 may be as high as you can go, but there is no harm in going higher.
          AT&F selects the default factory settings.
          ATL1M2 will select low speaker volume and speaker always on.
          ATH1 takes the phone off-hook. You should hear a dialtone. ATH or ATH0 hangs up.
          ATDT12345678 dials phone number 12345678. You could dial your own number and listen for the expected engaged tone.
          AT&V1, AT&V2, AT#UG, AT#UD are some of the diagnostic commands that provide information about the last dialup session. Not all modems support all these commands.
            LENOVO ThinkSmart M920q Zoom Rooms i7-9700T Specification for Upgrade or Repair
            This specification for the LENOVO ThinkSmart M920q Zoom Rooms can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkSmart M920q Zoom Rooms boardview and ThinkSmart M920q Zoom Rooms schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-12-2024, 01:58 PM
          • dreico33
            TL866 II Plus Check ID Error on various IC
            by dreico33
            Hellow guys , i really need your help here.
            Lately i have a problem with My TL 866 II Plus programmer, and to be more specific many times on various IC ( Winbond, Gigadevice Mx) i get Check ID Error while i am trying to read the IC. Has already been detected without any kind of problem, but the only to read them is to uncheck every time the "Check ID " option. After that i can read it erase it and re-program it only to get another error at then end saying that can not verify the programing went well so i have program failed. So i am trying to find out what is going on? I...
            11-04-2024, 03:13 PM
          • hasel17
            CH341a can erase and read but can't write and blank check
            by hasel17
            So I am trying to repair broken thunderbolt FW on X1 Yoga Gen 2. The EEPROM chip is WINBOND 25Q80DVNIG. I already do a back-up and erase. But when I try to wrote new FW, it was successfull, but when I tried to read it, it still blank. when I try to do a blank check, it gave me instant error in address 0. I already tried two CH341A, already did the 3.3v fix mod, using AsProgrammer, NeoProgrammer, Colibri, and CH341A 1.29. But the problem still occurred. What I did wrong here? Can anyone help me? Thanks in advance. Here is the log in Colibri :
            Code:
            Checking for blank...
            (Press
            10-26-2023, 06:20 AM
          • i440bx
            Elitebook 820 G3 engineering example: CMOS settings lost despite new cell
            by i440bx
            Hey there,
            I got a HP Elitebook 820 G3 Engineering Sample Laptop and I want to use it. Besides the difficult things at the ES-BIOS I have a big problem by saving the main BIOS settings.
            The laptop does not have a big battery because it was dead, but I already plugged in a new CMOS battery.
            It takes about 5min without power and the BIOS settings are lost. Unfortunatly I dont understand why the BIOS settings are only saved with power connected and this is the reason why I registered here.
            As written above, I plugged in a new CMOS cell and checked...
            08-19-2024, 02:28 PM
          • fixitforfree
            Samsung TV mu6179 with Mainboard BN41-02568B wont save configuration.
            by fixitforfree
            I have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
            Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different...
            07-21-2025, 09:07 AM
