DD-WRT software help.
  • ivtec
    • Dec 2008
    • 1967
    Re: DD-WRT software help.
    Originally posted by goontron
    i think he is seeing something like this.
    Thanks goontron; exactly that, i was trying to do a screenshot of the desktop in winxp but can't do it, i was able to do it once before but now can't do it, in Linux is so easy.
    • ivtec
      • Dec 2008
      • 1967
      Hi guys: i have Good news: I was able to figure out this DD-WRT configuration on the Buffalo WHR-HP-G54,and Updated the Firmware from build 13521 to build 21286, and i've set up a Secure WPA2 and you know what All my wireless machines work great and have a very good Wireless signal,i almost screwed everything if i went with Tomato that has no secure we-pa,besides i probably would brick the router.so i'm very stubborn never give up that's lots of work but that pays off.
      thanks you all that tried to help.
      • mockingbird
        • Dec 2008
        • 5484
        Stick with DD-WRT.
        I just tried to flash Tomato, it won't work. It will give you a message "Incorrect Image File".
        • diif
          • Feb 2014
          • 6978
          • England
          Glad you got there in the end, from your screen shots it was clear you were almost there even if your terminology was a little off.
          If your devices support it, just use AES and not TKIP for your WPA2 encryption.
          • mockingbird
            • Dec 2008
            • 5484
            Was searching high and low, all I had to do was change the .trx to a .bin extension for it to flash in DD-WRT.
            I would say DD-WRT is better for the router I was using, (Linksys WRT54GS v1.0), but Tomato is better for the Buffalo. If DD-WRT doesn't work out for you, you know what to do.
            • SteveNielsen
              Retired Tech
              • Jun 2012
              • 2327
              Good news. I'm glad you got it working.
              By the way, there are ways to unbrick a router from a bad flash by flashing via JTAG connections and a "wiggler" LPT cable.
              • ivtec
                • Dec 2008
                • 1967
                Well,i bought this Buffalo WHR- router 5 years ago for 60 bucks at Amazon and Flashed DD-WRT firmware,but i could never make it work ,so i put it on my scrap, to tell you the truth i thought i had bricked it,and could never get it to Factory Buffalo Firmware,all this because of lack of understanding English and DD-WRT configurations of Firmware and software,besides i went with the Crappy Verizon DSL and Phone and with Verizon Routers never needed another wireless router,so by necessity i just started to reed and Google about the matter,and at this time i understand a little more about Computers and software and that helped a little bit as so the clues i've got from forums like badcaps forum.
                I've resorted last to Buffalo cause i tried to Use these Routers that i also had in my scrap, but could never do a secure Wep or WPA ,Toshiba WRC_1000, Net gear WNR2000,
                Belkin F6D4230-4 v1, these old routers only worked ok on my old machines open Secure protection,and i had to shutoff the routers when in use with wireless to avoid worse damage by someone using my Wireless,also these routers open secure only gave me 4gbits out of the 30gbits that i have,happy ending.
                • ivtec
                  • Dec 2008
                  • 1967
                  Hi guys; update on DD-wrt on my Sony Vaio Pentium M WinXP sp3,
                  the Wireless on DD-WRT is great,but i can't get the Wire LAN working! when i boot to Linux Mint 17.1 xfce it works great on both Wireless and Wire Lan,when i connect the wire cable, i can see the wire connectivity activation icon with good connect.i don't mind it just working on wireless, but as i'm geek perfectionist,i will not sleep till i have everything working 100% right.even if i have to re-install WinXp again.
                  Is there anything i can check, also when i restore to an early date it works,but i get all my browser set up all screwed,internet explorer 8 won't let me install Google chrome, so i have to revert to this restore point which is working great, thanks.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    #29
                    Press the windows key and r and in the run box type cmd. In that type ipconfig/all and post back what it says under ip address.
                    Is it a clean install of Windows XP ?
                      • 31204
                      fixed i.p. or iritating DHCP ?
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        This sort of thing is commonly caused by malicious software, which as we know Windows and IE out of the box are quite vulnerable to. If this is the case (and in my mind there's no doubt about that) the appropriate course of action is:
                        Remove computer from network.
                        Clean install of Windows (activate later)
                        Install good current version of anitvirus from an offline full installer
                        Install Chrome or Firefox from an offline installer
                        Get on network
                        Update antivus
                        Activate Windows
                        Update Windows
                        Do not run IE. Ever.
                        • ivtec
                          • Dec 2008
                          • 1967
                          Get on network
                          Update antivus
                          Activate Windows
                          Update Windows
                          Thanks; it's not virus or malware, i solved the issue by entering in, Internet Protocol TCP-IP-Properties , and ticked box,
                          Changed to; Obtain an IP address Automatically, Obtain DNS Server address Automatically.
                          What happened was when i tried to flash DD-WRT with TFTP, i went in TCP-IP and changed IP address to run TFTP, and did not change it back.
                          • SteveNielsen
                            Retired Tech
                            • Jun 2012
                            • 2327
                            Ah, yeah that happens once in a while I'm glad you found and fixed it.
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              On the topic of DD-WRT firmware I have run into an issue using:
                              Router Model
                              Netgear WNR3500L v2
                              Firmware Version
                              DD-WRT v3.0-r27520M (07/17/15) kong
                              Kernel Version
                              Linux 3.10.84 #67 Fri Jul 17 08:06:51 CEST 2015 mips
                              What happens is after some hours of use, which seems to depend on how much wifi traffic there is over time, the login to the web page of the router itself fails to connect and requires a reboot of the router to fix. This appears to be a known issue on the DD-WRT forum but has not been resolved quite yet but Kong is aware of the issue and I think still looking into it.
                              As a temp work around I have cron reboot the router every 24 hours and that mostly works unless wireless traffic is heavy for a while and then the page not found error resumes at login.
                              • Gabriel
                                • Jan 2010
                                • 620
                                • Norway
                                #35
                                I also have a wnr3500l, I'm using ' DD-WRT v24-sp2 (08/12/10) std-usb-ftp - build 14929 ' and have never seen the web page problem - I have been using it for 2-3 years so far without any complications.
                                • digge
                                  • Apr 2006
                                  • 296
                                  #36
                                  Router Model
                                  Netgear WNR3500L v2
                                  Firmware Version
                                  Kernel Version
                                  I used to use that router with dd-wrt and from what i remember some of the builds had a problem with the usb driver. Some kind of memory leak wich would make it slower over time. Just turn the usb feature of if youre not using it and see how that works for you.
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    That's interesting. I haven't been using the USB at all and I'll look into that. Thanks.
                                    USB is already disabled.
                                      • 31204
                                      maybe try this?
                                      http://www.gargoyle-router.com/index.php
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        It's not on the list of supported routers, v1 is but v2 is not and they are apparently different enough to need different builds. It's kind of a bummer because I bought this router specifically because it is supposed to be OpenWRT compatible. I may try Tomato or another type but I am used to DD-WRT and like it.
                                        • SteveNielsen
                                          Retired Tech
                                          • Jun 2012
                                          • 2327
                                          Thought - would enabling the log show anything relevant to this problem? I'm gonna try that and see just for the heck of it. I'm gonna look at some different open source OSes for this thing, I'm not totally against trying something new to me.
                                            Copy DMI info easily with Hex editing software and Macro script
                                            by SMDFlea
                                            Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                                            Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                                            02-28-2023, 02:14 PM
                                          • NeedsPractice
                                            Backup To OneDrive Software? Everything! Best Software?
                                            by NeedsPractice
                                            I contacted Microsoft and they said they do not have software to where you could backup all your files to one drive. I mean you can copy some of your files to your one drive folder and back stuff up. However, it does not do this automatically.
                                            I have around (10) hard drives I want to backup to the cloud with One Drive. What is the best software to do this with?
                                            AOMEI Backupper
                                            I Drive
                                            Easeus
                                            I do not want a Cloud Plan. I just need the software to take my DATA and Transfer it to the cloud in a nice, readable, viewable fashion. I wish...
                                            02-04-2022, 06:04 PM
                                          • BMCappelletti
                                            iMac fan ramps up after shutting down. Software? SMC? FET?
                                            by BMCappelletti
                                            Hi everyone.
                                            There are some topics here (also on a lot of other places) regarding this issue, but I believe none has a definitive answer. At least I didn't see anyone saying it really worked for them.
                                            In my case I have an iMac A1418 (late 2012) that the fan goes full blast (or at least ramps up the speed) after going to sleep or turning the computer off.
                                            It's not a software issue, cause it was formatted and it happens with any MacOS version I test.
                                            At some places people say it would be an issue with the S5 rail. Others say it's the S0 rail. And some others say it's an SMC...
                                            01-17-2025, 08:11 AM
                                          • Russ17
                                            JVC LT-55C870(B) Corrupt Software??
                                            by Russ17
                                            I have a JVC LT-55C870(C). All that happens upon applying power is the red led flashes slowly (1Hz).
                                            If I hold the OK on the remote while powering on, the led flashes at 2Hz, but without a USB Device attached, it obviously does nothing, no screen or backlight.
                                            Any thoughts on this being corrupted software?
                                            Owner says the TV experienced a power surge.
                                            If software is a possibility, can someone point me in the right direction to download the correct software. Is there a procedure to force software to load from USB?
                                            10-10-2023, 12:34 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
