Old Belkin 54g router bottlenecking speed
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    My ISP upgraded my service from 30 to 60 Mbps and replaced the modem with an Arris TM822. A PC connected directly to modem gets well over 60 Mbps (actually peaked at 100) but thru the router only getting 30. Router is running DD-WRT latest firmware. The 4 LAN ports are 10/100 auto negotiation and the PCs connect at 100. I am not using the wifi on this router right now and radio is off. I don't see any place in the router settings to fiddle with LAN speed so I am left to assume this old Blekin just can't go that fast. I realize that 100Mbps is a theoretical maximum and in real use will never have that much usuable bandwidth but I'd think it could still get up to 60Mbps. Looks like I'll need a better router.
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Old Belkin 54g router bottlenecking speed
    Ah, I see the problem. Duh, I was right on top of it all along, in my face so to speak. The modem connects direct to my PC at 1000Mb/s. The old router can only do 100. Yep, time for a router with faster eth ports.
      • 31094
      make sure the replacement has lots of led's on it - you can never have too many led's
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        I like LEDs. Especially blue ones. It's my favorite color.
        • diif
          • Feb 2014
          • 6978
          • England
          Everything is better with blue LEDs, apart from my Virgin Superhub...they really shouldn't use super in the name !
          I can recommend the d-link DIR-615, happily runs DD-WRT, does N band, has 4 gigabit ports...and it's cheap.
          http://www.amazon.com/D-Link-DIR-615.../dp/B000QD7B6W
          • retiredcaps
            • Apr 2010
            • 9271
            The above link you provided to Amazon says
            Interface Type: 4 Fast Ethernet LAN Ports (10/100)
            NOT gigabit.
            --- begin sig file ---
            --- end sig file ---
            • diif
              • Feb 2014
              • 6978
              • England
              My mistake, I use one at home, I thought it was gig ports.
              I was given it by Virgin Media when i upgraded to the 100mbit connection, they told me it was gigabit. i don't transfer files between PCs do i wouldn't ever see the bottleneck.
              • luke10050
                • Mar 2013
                • 209
                DIR-635 is a 615 with dual band N and gigabit ports, decent little router, and you get 100MB/s file transfers across its switch
                • double_DD
                  Why does my ISP router hate my "homemade" power supply??
                  by double_DD
                  It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
                  So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
                  For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
                  07-12-2025, 03:09 AM
                • harp
                  simple win network with optimization issue
                  by harp
                  simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                  06-23-2025, 11:01 AM
                • gtsamour
                  tplink vr600 modem router - Capacitor
                  by gtsamour
                  Anyone know what brand this is? Its inside a tplink vr600 modem router. Should I replace it?
                  https://imgur.com/XT0F70S...
                  11-22-2020, 03:59 PM
                • Babbar
                  1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                  by Babbar
                  My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                  11-13-2024, 01:54 AM
                  Sony VAIO VGN-FZ31J FZ Specification for Upgrade or Repair
                  This specification for the Sony VAIO VGN-FZ31J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-FZ31J boardview and VGN-FZ31J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO VGN-FZ31J...
                  09-06-2024, 05:27 AM
