Re: "A Network Cable is Unplugged"
this is almost certainly hardware!
btw when the derecho came through here last year and took out the power i ran on backup till time warners pole mount ups gave out.was about 9 hours.no disconnected cable notice when it went.modem lights went to acquiring downstream and stuck there.any request from the pc timed out.
the live linux test is the first thing i would have done if i were the o.p.
Try the simple thing of downloading a live Linux install and let it run overnight and see if the link dies during this time while doing something that draws a lot of data ( torrent client of the distro hosting the download will do as a safe legit load).
If not then you will probably be best off to reinstall XP, otherwise delete the drivers for the card and reinstall them again using the latest versions from the card manufacturers site. This will ensure you have no old software that can cause problems.Leave a comment:
That message will only appear if the cable itself has become dislodged, is faulty/broken or if the router has crashed or reset, or has a power issue. If the net actually does go down, Windows won't even say there's an error (as you are still connected to the router).
I haven't had cable internet since around 1998, so I can't remember how cable modems work in this situation, whether they disconnect entirely when there's not net access or just sit there waiting for a connection to the outside world.
On a side note, hopefully you don't have bad caps like my old D-Link ADSL1 router did.Leave a comment:
Move on from that outdated OS. Windows 7 (or 8) Problem Solved!!Leave a comment:
I've been living with this for seven months. I've tried a lot of that.
-My modem is built into the router so a connection to the router is the simplest way to connect.
-See above
-Yes. I have attached my Toughbook and Thinkpad to the same lines and left my IRC client connected overnight. When I get up in the morning they are still connected. Try that with the PC and it will usually drop the connection sometime during the night.
-I don't see what a crossover cable will do
-This is the ONLY machine in the house that has this problem. No other system attached to the network suffers from this problem, including a machine at the other end of the house which mainly streams videos.
The cable I ran from the switch to my PC is from the same spool I used to network the rest of the house and supply my old roommates with an internet connection. If this was a shielding problem I would be seeing problems all over the house and my roommates would of been breathing down my back for almost two years but I'm not seeing them. No matter what external factor I consider and change the problem remains specific to this system and this OS installation.Leave a comment:
We just went over that when I mentioned I tried multiple cables. The stuff I built and crimped myself came from the same spool I used when I wired my apartment in Vancouver which had three times the run length (about 80') and it never had a problem.
Not trying to be rude but is it possible to narrow id down to a specific section of the OS? I can reinstall but I really would not be looking forward to it and if it's from the same install CD again, what if it happens again?
Since you're so convince that the problem is other then common sense;
Have you tried connecting to the modem directly?
Have you remove the modem leaving only router and machine connected?
Have you tried connecting another computer (one completely different) to eliminate faulty hardware?
Have you tried using a crossover cable?
Have you verified that you are not getting dirty power, causing switches, routers, modems to momentarily drop due to bad poco supply or a failing UPSes, those little bricks and wall warts can't handle a brownouts or surges as well as a atx power supply.Last edited by Mad_Professor; 11-15-2013, 09:33 PM.Leave a comment:
sounds like electrical or emi interference from something, try getting a shielded cable and see if that works.
sound like Xp is craping out.Leave a comment:
sounds like electrical or emi interference from something, try getting a shielded cable and see if that works.Leave a comment:
Technically I never changed ethernet hardware. There might be a different revision on the new board but I've otherwise never touched it.
I'm currently up to date on my SP3 updates though.
You do however remind me that this time around instead of installing from a shady burned pro CD I used an authentic Pro SP2 CD so I didn't have to fight the filesystem bug (XP partitons and formats up to 120gigs and after the install you need to use Partition Magic to expand the partition to cover the full terabyte of space).Leave a comment:
It may be a old bug in XP, especially pre-SP2!
If you changed ethernet hardware, I would get XP X32 with SP3 integrated, if using XP X32.Last edited by RJARRRPCGP; 11-15-2013, 03:06 PM.Leave a comment:
It isn't that problem this time around. I've completely eliminated that possibility with multiple cables and cards.
I can right now wiggle the cable ends to my hearts content while doing something like speedtest or a file transfer and the connection doesn't flinch.Last edited by pentium; 11-15-2013, 02:55 PM.Leave a comment:
Check the network cable (sometimes the jacks get loose).
Check the actual network jack on the motherboard, just in case there's some pins that no longer flex properly or maybe they're oxidized.Leave a comment:
THIS is wildly pissing me the hell off now.
What happens is that on a random (but still happening multiple times a day) occasion that little balloon will pop up on the taskbar.
Half the time nothing will happen and active connections don't skip a beat. The other half of the time everything dies and disconnects and it takes a few seconds for the network interface to go back to being connected and for everything to sign back in. If however you're doing something like file transfer or a remote session that all dies and you have to start over again. If you're in a game you have to reconnect and you can forget about hosting anything....
I've replaced EVERYTHING hardware related. I've used three different network cables (two custom made and one pre-fabricated), I've changed ports on the switch and even bypassed the switch and gone directly to the router. I've even replaced my motherboard (my last 865PE bit the dust so I bought another) as to make sure it's not a glitchy NIC. Yet after all that it persists. It worked flawlessly when I was living in Vancouver. After I was setup here with my parents again I did a fresh install of XP. THAT is when the problems started to happen. Yes I have uninstalled and reinstalled the network driver. What the hell gives??Tags: None
by PatriarxisHello.
i have this problem with a lenovo ideapade s145-15api.
The charging led stays on even when the charger is unplugged. Also in windows it shows that is charging.
Do you have any idea? -
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by davgI just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
Channel: Troubleshooting & Designing Networks
by Patch2I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...8 Photos
- Loading...
