An inflexibility with Wi-Fi Protected Setup: band selection
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    On handheld and media devices, I found an inflexibility with Wi-Fi Protected Setup (PBC and PIN), which is band selection, which means you cannot manually select the 5GHz band with less interference in some cases.
    When you select one of your networks used by a dual-band router, you cannot use Wi-Fi Protected Setup in some cases.
    Also, when you use Wi-Fi Protected Setup, it does not allow the selection of band (2.4GHz/5GHz) in some cases, which means it locks onto the band with the strongest signal on your dual-band router when Wi-Fi Protected Setup is used on it.
    If I make dual-band wireless routers, I would include separate Wi-Fi Protected Setup buttons and PIN numbers (as well as separate PIN entries in the setup menus) for each band to address this inflexibility.
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: An inflexibility with Wi-Fi Protected Setup: band selection
    what kind of "handheld and media devices" are they? android has no problems neither does my IPAQ that runs linux.
    Follow the white rabbit.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      Why not just use WPA2?
      • BestofBad
        • Sep 2013
        Yeah. The WPS function actually doesnt give you any chance to change parameters. But it does seem to work pretty well when you try and set it up with a device which supports the WPS function. Not all devices support it. I played around with several devices with the WPS function. Most of them work fine. But there are some devices still trying to catch up with a good firmware version. I found most of the information from https://1080community.com.au/topic/4...-wps-function/
        Btw, they are also running a promotion on the site IF you are interested in a kaspersky key for 2014.
        https://1080community.com.au/?app=forums&ext=E239
          WPS is also vulnerable to brute forcing due to a design error, it can be broken in around 4 to 12 hours which allows the WPA2 key to be retrieved. Only way to stop it is to turn off WPS.
          • shadow
            • Feb 2007
            • 732
            With regards to devices auto choosing the 2.4Ghz connection over the 5Ghz connection which is usually better. What I normally do is setup the 2.4Ghz wifi and the 5Ghz wifi with exactly the same settings except for the SSID. Many devices will allow you to choose the preference of wifi connections, so you can make a device 'prefer' connecting to the 5Ghz network over the 2.4Ghz network. By separating the two wifi networks, you do not rely on the device making a 'decision'...(it probably just chooses the connection which is first in its list anyway).
            • LLLlllou
              • May 2011
              • 201
              You could also just turn off the transmitter you don't want to connect to, connect with WPS, then turn the transmitter back on.
              Whenever I setup a dual band router I always make the SSIDs the same, but add "-5GHz" to the end of the 5GHz SSID. It just doesn't make sense to have two access points with the same SSID.
              • cheapie
                null
                • Jul 2010
                • 849
                Am I the only person here that's still on 802.11g and has never used WPS?
                • LLLlllou
                  • May 2011
                  • 201
                  I run into a couple people a year that still have _B_ routers with WEP, although it's been over a year now since I've seen one.
                  Also the Actiontec Verizon FIOS Routers don't due WPS even though they have a WPS button right on the front, so there's at least a few million others out there who've never used WPS. I find it useless unless you run into a wireless printer that won't let you type in the WPA/WPA2 key, otherwise I usually don't bother. WPA on an Airport is retarded, you have to use the Airport Admin utility to initiate the connection. WTF, com-mon Apple add a damn button!
                  • shadow
                    • Feb 2007
                    • 732
                    I have only recently upgraded to 802.11n.
                    However I have never used WPS. I find that it has no use for me. I know how to setup a router from scratch and don't need an automated process.
                    • u271D
                      • Sep 2013
                      • 59
                      • Ukraine
                      Nope I never use wps either!
                      As for wireless G, maybe, I'm using AC now with beamforming tech.
                      • luke10050
                        • Mar 2013
                        • 209
                        WPS is horrible IMO... i mean its good but i just memorised my wifi key, its actually faster (my key is the default one with my router, just letters and numbers)
                        • japlytic
                          • Oct 2005
                          • 2086
                          When I was looking for instructions for performing a factory reset on my friend’s D-Link DSL-2544N dual band ADSL modem, I came across something quite useful to solve an inflexibility with Wi-Fi Protected Setup (of course, band selection) for this model: pressing and holding the WPS button for 5 seconds initiates a connection session via Wi-Fi Protected Setup only for the 2.4GHz band; pressing this button for 5-10 seconds initiates a WPS connection session only for the 5GHz band.
                          I think having separate WPS buttons (each labelled with their band e.g. 2.4GHz N, 5GHz AC1, 5GHz AC2) for each band/radio is a good idea, given that some devices (especially media devices) do not allow you to explicitly select the band (2.4/5) or SSID for connection with WPS.
                          • japlytic
                            • Oct 2005
                            • 2086
                            UPDATE: A NetComm NF8AC has separate WPS buttons for the 2.4GHz N and 5GHz AC - my idea of addressing the inflexibility of band selection with WPS has been fully adopted!
                            • Sus256
                              HISENSE 65E7KQ PRO - no boot
                              by Sus256
                              Hi all!
                              HISENSE 65E7KQ PRO
                              RSAG7.820.13512 - chassis
                              MT9618BAATAB - cpu
                              RSAG7.820.12059 - power
                              HD650Y3U77 - panel
                              KLM8G1GETF - emmc
                              Replaced emmc.
                              Terminal log
                              UART
                              AC_ON
                              E-B
                              FDE enabled
                              06-01-2025, 02:11 AM
                            • howardc64
                              LG 49UJ6500 LCD panel lighter band that goes away
                              by howardc64
                              49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
                              Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
                              02-19-2023, 12:13 AM
                            • Modify_inc
                              Locked Setup Fails to Unlock with Correct Password - Inspiron 11 3185
                              by Modify_inc
                              I have a Inspiron 11 3185, and in the BIOS setup under Security it shows "Locked Setup", which limits pretty much everything in the BIOS. I'm using bios-pw.org to generate the codes for the hash, but they never work for the Locked Setup password. The codes generated for the System password and the HDD password work fine, but the code for the Locked Setup password always fails. I don't understand, if it works for the first two, why is it not working for the Locked Setup p/w? Since I can't disable it, anytime I reboot, even after a Windows update, I have to go through the hassle of generating...
                              11-02-2021, 11:14 AM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
                            • notallbad
                              Samsung UE55JU6000K stuck at 'Setup Conplete'
                              by notallbad
                              Reset the tv as internet connection not working, connected to router but no internet.
                              Did a factory reset and completed the initial setup process but now just freezes on 'Setup Complete' page.
                              Going into service menu it says 'Failure' at the top of the page and unable to access the 'control' screen.
                              Its already on T-HKM6DEUC1570.0 fw.
                              Are the SVC reset options likely to help here?
                              options are
                              apps reset
                              svc reset
                              spi flash reset
                              data sync reset
                              Any help appreciated.
                              08-26-2023, 10:44 AM
