To restore a glorious one: Dlink DI-624+
  • teppei
    • Aug 2012
    • 51
    • italy
    Hi friends!!!
    I first of all apologize if my English is not correct but I am Italian and I desire your jewel support.
    I have decided to open this topic to look for to restore this modem (purchased to londra) that is not mine but of one colleague of mine, that returning in italia has forgotten the power supply to london.
    The model in matter is: Dlink DI-624+ On the connector is written 5V 2.5A.
    I have also found the manual.
    Here it is as introduces him to the inside:
    I in the meantime am trying to retrieve a substitutive feeder....and to change the swollen caps, as is seen by the photo.
    Naturally I replace them with condesatori low esr.
    Other suggestions?
    Thanks!
    master hoarder
    • May 2008
    • 12175
    Re: To restore a glorious one: Dlink DI-624+
    Originally posted by teppei
    Other suggestions?
    If your friend finds the power adapter, make sure to check the caps in it as well. I had a DI-614+ go down due to a faulty cap in the power adapter (and this is the thread). Eventually, I got the adapter fixed and running, so my router is now working fine.
    • teppei
      • Aug 2012
      • 51
      • italy
      Momaka Thanks for your response.
      My friend has forgotten the power supply in london and now I bought a 5V 2A power supply, even if the original is 5V 2.5A.
      I do not think half milleampere can make a difference.
      Of course, correct me if I'm wrong momaka.
      Momaka believe me it is not for the value of the router which is now almost non-existent but for the satisfaction of repairing it.
      thanks again
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        thanks again
        Half a milliamp = 0.0005 amps
        Half an amp = 0.5 amps
        I think it would make a difference, and also, it is good to get a PSU that will easily handle the load. The reason is because it should run cooler - therefore less stress on the parts!
        Muh-soggy-knee
        • teppei
          • Aug 2012
          • 51
          • italy
          Ben7 thanks for your response.
          Unfortunately I could not find a power supply with the same characteristics 5V 2.5 A, which is why I bought this one 5V power supply 2 A.
          I look forward to come this supply.
          I will keep you updated.
          Thank you all!
            master hoarder
            • May 2008
            • 12175
            Yes, I know how that is. My DI-614+ is even older than this, yet I repaired it for no other reason other than for fun.
            It *may* not make a difference when the router is sitting idle, but when there is heavy traffic and lots of wireless and/or wired activity going on, it *may* make a difference.
            And even if it doesn't, ben7 has a point - the power adapter will likely run hotter so it's better to have an adapter than can properly handle the load.
            • teppei
              • Aug 2012
              • 51
              • italy
              Boys the power supply from china with fury I arrived today after a month of waiting!
              I fed the router .... but unfortunately performing a simple ping 192.168.0.1 I always request expired!
              I thought maybe .... I can re-inserting the firmware to restore it??
              What do you advise me??
              Thank you all!
                master hoarder
                • May 2008
                • 12175
                Try resetting its settings first, if there is such option. On my D-Link router, I *think* all I had to do was hold the reset button for 10-20 seconds to fully reset all settings.
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Might be 192.168.1.1
                  • teppei
                    • Aug 2012
                    • 51
                    • italy
                    Thanks pentium 4 and momaka for your swift response.
                    I also tried with this address 192.168.1.1 but unfortunately the answer is always Request timed out.
                    I also tried to reset the router, unfortunately nothing.
                    • teppei
                      • Aug 2012
                      • 51
                      • italy
                      I tried to make a nice ipconfig, the result was this:
                      Ethernet adapter Local Area Connection (LAN):
                      Connection-specific DNS suffix:
                      Autoconfiguration IP Address: 169254145190
                      Subnet mask. . . . . . . . . . . . . : 255.255.0.0
                      Default gateway. . . . . . . . . :
                      C: \>
                      • retiredcaps
                        • Apr 2010
                        • 9271
                        Hook up your computer to the router using an ethernet cable.
                        Download wireshark from
                        http://www.wireshark.org/download.html
                        and see if the router responds to the arp packets.
                        If you are unsure of how arp works, take a packet capture of a working session (say another router) so you can compare.
                        Disregard. I didn't see your other message. Your DCHP isn't working.
                        --- begin sig file ---
                        --- end sig file ---
                        • retiredcaps
                          • Apr 2010
                          • 9271
                          C: \>
                          The above indicates you are not getting an IP address from the router via DHCP.
                          You can manually assign your etherent adapter an IP address like
                          192.168.0.99 255.255.255.0
                          • Flasman90
                            Macbook Pro DFU Restore Issues
                            by Flasman90
                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                            08-30-2025, 10:27 AM
                          • iMuhtaseb
                            820-02020 A2338 Restore/Revive Failed
                            by iMuhtaseb
                            A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
                            Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
                            I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
                            09-11-2023, 08:43 AM
                          • yheriatovych
                            A2338 820-02020-A 5V, no screen, unable to revive/restore
                            by yheriatovych
                            Hi. I need some help troubleshooting the issue (which is a bit odd to my limited experience) with the A2338 Macbook.
                            Initial symptoms:
                            One day the laptop refused to wake up (as it seemed at first), spinning the fan on full blast, with no picture on the screen.
                            Force rebooting didn't help. To check if it boots at all I connected the external display and surprisingly it booted to the system, and I was able to log in to the system.
                            However, I noticed that it was in some weird state:
                            • The fan was still blasting at full speed. It's blasting even when the system
                            01-31-2024, 10:22 AM
                          • Stephen
                            iMac M1 DFU restore issue
                            by Stephen
                            iMac turns on no drops no cracks, tried to DFU Restore the iMac, logo turns on great! however iMac turns itself off and then restarts to the (!) icon and won't post the restore. Tried thunderbolt 3 cable, tried regular USB C cable and nothing.
                            this is the message it gives me with the error
                            Unexpected device state 'DFU' expected 'RestoreOS' (Probably forced into DFU mode externally) [com.apple.MobileDevice.MobileRestore – 0xFAE (4014)].
                            Any thoughts what this could be? I will open it up and repair it but I am not 100% sure since this iMac doesn't...
                            03-07-2025, 12:19 PM
                          • harp
                            is it possible restore data from the hdd with removed rom ic?
                            by harp
                            is it possible restore data from the hdd with removed rom ic so, is there any way, theory or practice, to restore or calculate missing data in flashrom ic from actual data stored on disk platers? In other words, is data on disc somehow reachable, recover without original rom firmware, using exactly donor board, special lab hardware, etc?
                            12-26-2024, 05:00 PM
