Actiontec GT701 modem
  • lti
    • May 2011
    • 2547
    This modem died a couple days ago. It lost the DSL signal, and it wouldn't start up after being powered off for a couple minutes. Inside, there are two bad CapXon caps.
    Here are the caps in this modem:
    C453: CapXon GF 1000uF 16V (bulging/leaking)
    C406: CapXon KM 470uF 35V
    C446: G-Luxon LZ 470uF 6.3V
    C427: CapXon GF 330uF 6.3V (bulging, bung blown out)
    C424: CapXon GF 22uF 6.3V
    C425: CapXon GF 100uF 6.3V
    C400: G-Luxon LU 47uF 35V
    C432: Panasonic FC 22uF 35V
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Actiontec GT701 modem
    We have a similar version (actiontec, same style of case design), and it had suffered from exploded capXons also. It still has a few capXon in there, but they are only the tiny ones - <10uF.
    There were a bunch of 330uF 6.3v and 220uF 10v CapXon GF that had bulged, and pushed the case off the bung - leaning even more than the tower of piza!
    Could we get some pics? Include a pic of the PSU too, some PSUs had bad caps also (like ours).
    Muh-soggy-knee
    • lti
      • May 2011
      • 2547
      Here are the pictures. It appears that the 1000uF cap is actually C413. I think C453 is an empty location for a surface mounted cap.
      There are some odd cap sizes. The 330uF cap is the only one that appears in the CapXon GF datasheet. The datasheet shows that 22uF caps start at 50V, and the size of the cap in this modem matches the size listed for a 63V cap. However, the voltage rating on this cap is clearly 6.3V. The 1000uF cap in this modem is only 12.5mm tall, and the 100uF 6.3V cap is 6.3mm in diameter.
      The power supply is a linear 12V 600mA wall wart. I don't want to open it to check the caps. Its case appears to be ultrasonic welded together.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        And caps rarely fail in linears anyway, so you should be good just replacing the caps in the modem itself.
        A working TV? How boring!
        • bluto
          • Oct 2007
          • 560
          Is it just me or does the printing on that FC cap look a little cartoony and thus possibly fake?
          • lti
            • May 2011
            • 2547
            It does look strange. I might be able to get a better picture, but my camera sucks. It always focuses on the last object I would ever want to take a picture of.
            • lti
              • May 2011
              • 2547
              Here is the Panasonic FC.
              In case you can't tell, this is what is printed in red:
              6N22
              FM
              • zaphar
                :-D
                • Oct 2010
                • 19
                Hi all, this is an old thread but I had this device stop working due to bad caps. Recently had a bad lightning storm in the area and the power went out for a few hours. When the power returned, the DSL modem showed the power LED as red so I though the phone lines where out. Long story short, called the DSL provider a couple days later to see if everything on their side was OK, it was, and did a few checks on the modem. They said it needed to be replaced. Figured I'd crack it open and take a quick look and see if anything looked out of the ordinary.
                After opening, noticed two of the caps where bulged, one with some crust. The bad caps where:
                CrapXon 1000uF@16V at position C413 replaced with a Suncon 1000uF@25V
                CrapXon 330uF@6.3V at position C427 replaced with a Matsushita 330uF@6.3V
                Replaced the bad caps with some that I had salvaged from old electronics and the modem is working again. Petty sure that the caps when bad a while ago but did not notice because the power to this device is rarely turned off.
                Just wanted to leave this info here in case someone else runs into this problem.
                I'm just glad that I don't have to buy another modem
                • lti
                  • May 2011
                  • 2547
                  I didn't repair this modem, but I always thought that replacing those two caps would fix it.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8690
                    I keep on seeing these modems show up being sold, used, for around $5, mostly from people who probably went cablemodem or 3g/4g/... Ugh. I kept on buying them in hopes of finding one that I can hack the firmware but no such luck. At least I don't have to worry about running out of DSL modems:
                    Currently using: Actiontec Q1000
                    Still have: Actiontec PK1000
                    Still have: Actiontec GT701WG
                    Still have: Actiontec GT701 (which replaced the Cisco 678 that died on me... which was a replacement for the Cisco 675 that was no longer supported)
                    I wonder if that old Cisco 678 died of bad caps, then again I despise CBOS, crashes constantly from DoS attacks. The GT701 was a little better but not great. The PK1000 was better still, but the Q1000 is worse. Alas it has 802.11n...
                    • Uranium-235
                      Comrade Glimmer
                      • Aug 2007
                      • 5042
                      • US
                      I bought a bad $30 network switch (Linksys SRW2048) from goodwill computer works.
                      ALL caps in it were bad (22!). "Stone" brand. Replace them with nichicons that were a little too wide so I had some fitting issues. Still managed to get all replaced in an hour and a half and it worked perfectly (would freeze up before after a few mins). It was a managed switch I managed to find a an old enough computer with serial port and reset it back to default with telnet
                      blazingly fast, but right now I use an 8-port GB linksys cause I have no need for a rackmount 48 port switch when I only have 6 things hooked up
                      • Longbow
                        • Jun 2011
                        • 623
                        Since the subject of wall worts was mentioned, there IS a way to open them up without destruction. Yes they are welded together. To separate the halves, find a solid smooth flat surface such as concrete, a vice anvil or the like. Use a small sized ball peen hammer to tap the weld politely all the way around the wort. Don't smash it open, just tap on the weld firmly. It will separate along the weld line and will be easy to re-assemble with super glue. That's how to do it. Most of the time, the simple ones get an open winding in the transformer and are trash. The more expensive ones with switching regulators can usually be fixed.
                        Is it plugged in?
                        • cap__
                          Can I replace 15uf capacitor with 22uf?
                          by cap__
                          "If I wanted to replace an old 15uF/400V capacitor with a new one,
                          I have a new 15uF/400V and a new 22uF/400V capacitor. When measured, the new 15uF reads only 13uF, and the 22uF reads only 20uF. Can I use the 22uF capacitor?"
                          11-29-2023, 11:16 AM
                        • dahm
                          tenda v12 ac1200 modem
                          by dahm
                          please need me tenda v12 ac1200 modem bios dump 8mb
                          05-23-2025, 12:15 PM
                        • rbvndonh
                          Lenovo T440s 1802 WWAN modem error
                          by rbvndonh
                          I had factory installed Ericcson modem. It was working, but later was changed into Dell 4G modem. It was working good.
                          Now, after BIOS repair (to the same which was rapaired in past in this machine) it shows 1802 error.
                          Does somebody have whitelist or know how to correct it or proper no-1802 tool or solution for this board?
                          Thank you
                          12-04-2022, 01:09 PM
                        • Cory Marqusee
                          MacBook Air 820-3209-A Missing (3) AGX 22uF Decoupling Capacitors
                          by Cory Marqusee
                          Hi Everyone,
                          I have a MacBook Air I've repaired, a mid-2012 13-inch 820-3209-A. It works. My only concern is that it is still missing (3) 22uF (0402 4V 20%) VAGX decoupling capacitors. Specifically, capacitors C1730, C1731, and C1732.
                          How necessary are these capacitors? It has (11) 22uF to begin with; missing (3), my board now only has (8).
                          I've been having difficulty sourcing new replacement capacitors without paying too much. Does anybody have any vendors state-side to recommend? Mouser charges parts + $8 shipping + $7 cutting fee (unless I buy an...
                          09-15-2022, 02:03 PM
                        • playit
                          broadband ut300r2u modem,link light stays on forever
                          by playit
                          ut300r2u modem,link light stays on forever no matter if if dsl phone wire connected or not.i dint mess with any firmware ,it started to be like this for past few months until it stopped all together to work anymore,so learned that flashing might help, need dump file for this modem, i have only ch34a1 programmer.so i erased and flashed with few bin or ras files i got from internet but nothing worked.so further reading let me know that have to flash a whole full dump .if any idea, pls share, thank you.
                          08-11-2022, 01:44 AM
