Netgear WNDR3300 Issues
  • Toasty
    • Jul 2007
    • 4171
    Re: Netgear WNDR3300 Issues
    Eggcellent!
    veritas odium parit
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      spoke too soon. my dad is complaining that his netbook keeps getting dropped.
      Any more ideas other than a sledgehammer or a shotgun?
      sigpic
      (Insert witty quote here)
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        TNT
        Can you put the original firmware back on?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by shovenose
          TNT
          yes, but it's a pita. also a good way to ruin the network (netgear stock FW is no good for file sharing or IP printing, esp under linux).
          ive had no issues... maybe I'll reinstall dd-wrt...
          sigpic
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            Yes, I understand that DD-WRT is better (in most cases)... I have used it on many routers and have had a great experience with it.
            HOWEVER the Netgear stock firmware isn't so bad...
            Why? Because of the recent update.
            A while back, I logged into the cotnrol panel of my WNR2000 and it said I had a firmware update. I did it, and HOLY COW what a difference! They literally redid the entire interface!
            Besides, we know the stock Netgear firmware is 100% compatible, so it's worth using just to test the hardware of the router - if you still get dropped connections using the stock firmware we know something is wrong with the router.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              I read it is a common issue with that model router and DDwrt.
              however, I am not going back... going back would kill all the printers in the house , which are all network printers (one IP, one hooked to the file server). I have not had dropping issues myself... and my dad is using a azurewave wifi module
              I may try a 30/30/30 reset tonight and see if that has any effect (I forgot to do that when I installed, DOH!).
              sigpic
              • shovenose
                Send Doge Memes
                • Aug 2010
                • 6575
                It was just a suggestion :P
                IMO, you learned something: test a router thoroughly BEFORE installing aftermarket firmware or modding it
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  Those are pretty much junk. My eeePC came with one of them.. nothing but trouble and poor reception. Replaced it with a Broadcom miniPCIe card and never had problems since (and got the added bonus of out-of-the-box OSX compatibility )
                  edit: the Azurewave also only used one antenna (only had one socket) and claimed n-WiFi capability, the Broadcom card is only 802.11g, but has sockets for two antennas. Bought a chinese internal laptop one from ebay and hid it behind the LCD. Can't say it makes a lot of a difference (probably because of the antenna being cheap & cheesy), but it definitely did something.
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    would an intel 3945 be a sizeable upgrade then?
                    his has 2 antenna sockets on the card... not that that means anything...
                    sigpic
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      upgraded the card, the POS won't detect it... maybe you HAVE to use the junk card under windows?
                      sigpic
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        Are you both running wired and wireless in the house from different routers?
                        veritas odium parit
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          the router has 2 radios... but all the routing is done from that router, including wired.
                          put the azurewave card back in the eee pc... installed the latest drivers as well, so far no issues.
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            added heatsinks, no impovement
                            I read that axing the 2.4ghz radio and setting the 5ghz radio to 2.4ghz fixes it...
                            that means no more 5ghz
                            but other than some old wireless A cards I have somewhere, 5ghz had no use... two of my laptops could see it but the performance was not that much better than the 2.4ghz setting... TBH, I don't see the big deal about 5ghz... it is only good in wide open spaces, which my house is not.
                            any other advice?
                            sigpic
                              NETGEAR and issues with it forgetting password or just going off line fairly new
                              by sam_sam_sam
                              I have for many years have used NETGEAR routers and most of the time I get about 2 to 4 years of service before I have issues with it but this one is a pain in the a** to say the least
                              First of all it goes offline for no reason at all
                              Or it has an error message that says no internet connection
                              The other issue is that sometimes it asks for the password also for reasons that I can think of
                              Power cycling it helps but a week or maybe longer then you have some kind of issue like website loading very slow or can not access the printer or whatever it decides...
                              03-18-2023, 07:36 PM
                            • spleenharvester
                              GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
                              by spleenharvester
                              I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
                              07-08-2025, 06:02 PM
                            • SoulFreeze
                              Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                              by SoulFreeze
                              Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                              After repairing the above issue, I realized the following remaining problem,
                              Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                              The computer recognizes headphones are connected and displays a popup in windows
                              Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                              06-21-2025, 09:53 AM
                            • UADmytro
                              Lenovo T14 Gen1 i7 10  nm-C931 (brick)
                              by UADmytro
                              Hey! I bought a Lenovo T14 Gen1 i7 10 nm-C931 (a brick). The previous owner said he got it on eBay as a password-locked device and took it to a repair service, where they tried flashing something. The result: it doesn't turn on.
                              When I plug in the charger, the charging LED lights up, and the power button indicator blinks three times.
                              I downloaded the firmware from the official website, but it's incomplete. However, there is a firmware for the embedded controller (MEC1663). I did a mass erase via OpenOCD, wiped MEC1663 along with the EEPROM, and flashed an image from the...
                              03-23-2025, 03:45 AM
                            • Nagyesz
                              Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                              by Nagyesz
                              I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                              All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                              How can I extend its lifespan? Could reflow help?
                              It has ryzen 5 5500h, rtx 2050, no soldered ram.
                              Example of the artifacts:
                              03-01-2025, 11:11 AM
