Powerline Adapters
  • bigbeark
    • Jan 2010
    • 661
    Powerline Adapters
    This device allows you to use a power outlet as a Network Adapter!
    How can this work? Is it safe?
    http://www.tigerdirect.ca/applicatio...&sku=N100-1433
  • ryanhull76
    • Jan 2012
    • 7
    Re: Explain This Please
    These are "safe" products, but to be honest, I would never use one.
    The powerline solutions are usually meant for last-ditch-effort when you just can't run network cable and you need "something."
    However, I've also found them to be very unreliable. Also, if you look, you'll see that their speed is only rated at 85Mbit/Sec. Real-world, expect appx 30Mbit/Sec. That's less than 10% of the speed available to modern ethernet connections and you'll definetely notice a drop in connection quality during large file tranfers, (i.e. movie files from a network share to a DVR, HTPC, etc.)
    It won't affect internet speed much at all, as most of us don't have >30Mbit download speeds, and the latency is fairly negligible.
    My recommendation, run cable and connect it that way.
    Hope that helps!
    • mariushm
      • May 2011
      • 3799
      They are safe, but as said above, the actual speed varies a lot.
      And, as it works by introducing "noise" in the power cables, they won't work well if you're using an UPS or any device like a surge protection socket.
      Speed is also much lower if the wall sockets are on different circuits in the house, if you're using microwave ovens or any device that's poorly designed and introduces noise on the power wires... they can disconnect or degrade the signal.
      There are newer generation devices that work on a newer standard, but even those can reach about 60 mbps but on average they stay at around 30 mbps:
      http://www.anandtech.com/show/4695/h...ices-working/1
      ps. One "flaw" these devices have is that they heat a lot, so if you plan to use them you must keep that in mind and not have carpet near them or other heat sources which would fry them, they need air around them to keep the temperature in check.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        I have an old set of netgear ones.
        It wasn't reliable. it liked to overheat. (edit- I was posted over, its not as uncommon as i thought)
        those look better built.
        they work as long as you don't plug them into a power strip with a surge protector... surge protectors kill the signal.
        I would personally stick to wifi do to greater bandwidth but if you need super security and cannot run some cat5e, it works.
        (it may be used in the future for people's internet connections...)
        edit- thread moved and title fixed to reflect topic
        sigpic
        (Insert witty quote here)
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Re: Please Explain
          I use to use one. It worked fine but I had one that the other end was a wireless access point. It got a little hot, not the best signal strength, but it worked. The only reason I got rid of it is because AT&T sent us these new wireless Uverse TV boxes and they allow you to tap into the back of them with ethernet cables for internet.
          • japlytic
            • Oct 2005
            • 2086
            Re: Powerline Adapters
            Not even the latest powerline networking standards compare to wiring dedicated to networking, and powerline networking should only be used to supplement your wiring dedicated to networking, not replace it.
            There can be issues about the use of powerline networking in rental properties.
            • kaboom
              "Oh, Grouchy!"
              • Jan 2011
              • 2507
              It's the EMI/RFI filter that just happens to be included in most surge suppressors. Cheapie "plug strips" usually just have a .47 - .68 uF cap across the line. Better ones will have a proper CLC filter. Both will eat up the carrier-current signal from the 'add-a-plug' devices.
              And if both units are on opposing phases, that signal's not getting past the XL of the distribution transformer. X-10 sold a 'line coupler' so your Powerhouse controllers would work no matter what phase they were on. I think it was (mostly) just a cap.
              Before the "plug-in-ethernet" toys, there were "phone-anywhere" gadgets. If you used them to 'extend' a phone line to a better location for a modem (also marketed as a miracle solution in this case), you'd be lucky to get 9600 bps.
              "pokemon go... to hell!"
              EOL it...
              All style and no substance.
              guilty,guilty,guilty,guilty!
              guilty of being cheap-made!
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Hi- I have no idea but google "powerline ethernet diagram"
                there are number of articles on Wiki
                Here is one: http://en.wikipedia.org/wiki/HomePlug
                Lots of technical stuff here:
                http://www.datasheetarchive.com/sche...datasheet.html
                Including attachment if you want to build your own!!
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  My best guess would be that using a homes wiring as a data network wouldn't workout so well. I'll stick with my hardwired DSL modem. It works for me.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • seanc
                    • Nov 2008
                    • 1319
                    I've used these all time time, they're safe and useful.
                    It's true, the speed sucks.
                    I live in rented accommodation so I can't run cables all over the house and most of the older houses are built properly with thick block walls.
                    They're good for printers and I used them to connect from the house to my garage...
                    • uffda_oi
                      • Dec 2011
                      • 18
                      My first gen powerline/ethernet adapters served their purpose safely and worked in my home network. Mine were slow but faster than our local DSL.
                      You need a pair or more for home networks. I've used Tiger refurbs before with no problem. The price is right.
                      The older ethernet bridges were to be plugged in directly--not into a surge protector. The noise prevention caps (EM and RF) created a problem.
                      Every circuit may not communicate with every other circuit in the building and some of your circuits may communicate with a neighbor's wiring.
                      Hard wiring is the most secure and pristine.
                      Uffda
                      • Amraks
                        • Nov 2011
                        • 725
                        Interesting I have thought about the possibility of that you may be able to access someones network if you are close enough by doing this.
                        So Im living in a block of units so you're saying seems my next door neighbours power box is next time mine they can connect to me via power.
                        • uffda_oi
                          • Dec 2011
                          • 18
                          So Im living in a block of units so you're saying seems my next door neighbours power box is next time mine they can connect to me via power.[/QUOTE]
                          It depends on how your own circuits are set up. Sometimes, a circuit may be isolated. Sometimes, a circuit may link to another box.
                          If memory serves, I read this in a review of home wiring ethernet bridges somewhere. Since my understanding and memory of this are both fuzzy , I should have kept my mouth shut.
                          I side with the folks who recommend ethernet cable (but I use a couple of DSL modems or a wireless router depending on mood or traffic). My computers are on different floors and a good 50 feet apart.
                          Uffda
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5015
                            • New Zealand
                            Never tried one but I don't like the idea. I much prefer my wired ethernet network.
                            Also I think a lot of them are badly built with crap capacitors... Certainly haven't seen anyone praising one for high quality construction yet!
                            -David VanHorn
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              I had a set of netgear xe102 adapters... and I recently received for free another 2.
                              haven't used them in a while... but i opened one and found nothing but UCC and nichicon caps...
                              the last time i used them, they would overheat under heavy usage....
                              looking at the size of the main chip, I think one could get a set of stick-on heatsinks and stick those on the chips to cool them... next time I am at Fry's, I may grab a pack and see...
                              (posted this using the adapters)
                              sigpic
                              • howardc64
                                Samsung UN55JU650DF network/streaming problem
                                by howardc64
                                Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                07-09-2025, 12:44 PM
                              • davg
                                Home network connection problem
                                by davg
                                I just bought a new ThinkPad laptop and I need to connect it to my home network. I have several computers on my network and can see each other in File Explorer and the older ones can communicate with each other (even with the new one) but the ThinkPad can see the other computers but can't communicate with them. I get the (network error 0x80070035 The network path not found). I tried several scenarios that I found on line but none of them worked?? Since the other computers on the network can communicate fine I'm assuming the problem is with the setup of the ThinkPad? All computers are running Windows...
                                03-06-2021, 07:13 AM
                              • japlytic
                                Maximum speed should be marked on network ports
                                by japlytic
                                I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                12-19-2024, 05:04 PM
                              • hikomalek
                                SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                                by hikomalek
                                Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                                When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                                Transformer:
                                |Info| Primary | Aux | AB | CD|
                                |Ratio|1|25|40|12|
                                |Voltage AC|230V|9.2V|5.8V|19V|
                                |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                                I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                                09-19-2025, 03:30 AM
                              • harp
                                simple win network with optimization issue
                                by harp
                                simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                06-23-2025, 11:01 AM
