How to measure a 100/1000BASE-T transformer module ?
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    I have a router that all the lan ports + the wan port is dead.
    How can I test the transformer modules to see if they are working or not ?
    I have the Delta Lf9402 modules.
  • japlytic
    • Oct 2005
    • 2086
    Re: How to measure a 100/1000BASE-T transformer module ?
    Did the WAN port get connected to a phone line? Some people think the "internet" port is for the phone line, and many are not marked to warn people not to connect it to a phone line.
    Ethernet transformers can be a bit hard to test, considering that the windings show as shorted at DC or low frequencies. I found that fact useful in tracking down a defective network port in our new house, and the cause was a wire (used for Gigabit) missing its target on the wallplate connector.
    • Gabriel
      • Jan 2010
      • 620
      • Norway
      I found this router in the garbage at work so I do not know what happend to it but it has had a hard life - https://www.badcaps.net/forum/showth...3177#post93177
      I replaced the two blown caps but the lan and wan port was still dead.
      I was up all night and removed and measured all the electrolytic caps but they were all fine. I did notice the ip101a ethernet transceiver was really hot, I will get one on ebay and see if replacing it helps.
      • double_DD
        Why does my ISP router hate my "homemade" power supply??
        by double_DD
        It's gonna be a long intro, so please buckle in, as it's a problem that's been bugging me for several days now. Thanks in advance.
        So, I have 2 modems/routers, whatever the proper nomenclature is, one from ISP and one mine. I want to power them via USB-C rather then their original mains adapters (for reasons, that are hard to explain to sane people). Both routers come with 12V/3A mains adapters.
        For this purpose I acquired USB-C charger with 250W and 5 ports, 2 of which can supply max 20V/3A. Since 12V isn't a standard PD voltage option (and to future proof,...
        07-12-2025, 03:09 AM
      • AlexVG
        Replacing the WiFi module on a vacuum cleaner iROBOT i7
        by AlexVG
        I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
        I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
        (This board does not respond, only the LEDs light up in a circle.
        The liquid damage is catastrophic and restoration is impractical).
        (I bought this board to get the WiFi module and camera).
        The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
        If...
        10-22-2024, 07:20 AM
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • m1ch43lzm
        70mai Dash Cam A510 - help identifying connector on camera module
        by m1ch43lzm
        Hi everyone
        I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
        The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
        I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
        05-11-2025, 06:02 PM
