Starlogic HD20W
Re: Starlogic HD20W
But what is the chance of that open being on both sides of the board? when I move those lamps to the other side of the inverter to the D120 section, the higher voltage problem stays with the lamps. Wouldn't that tell us its both the lamps? Or is it possible we are barking up the entire wrong tree?Comment
Re: Starlogic HD20W
1. Either the new lamp is defective, or a mistake was made while installing it.
2. There is a problem on the board. You have three transformers driving 6 lamps. At least one of them must drive lamps at both ends of the board.
I'd rather suggest that there is a bad solder joint on the board than that you somehow failed to connect the new lamp properly. With all the hard work you've put in on this saying "Hey, you must not know how to solder, or are so clumsy you broke the lamp" sounds very harsh. I'd rather reserve my rudeness for people who deserve it.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
Re: Starlogic HD20W
There are several possibilities.
PlainBill
You are right...the one transformer drives 2 lamps that have white wires and are in circuit with the D121... Since it has different connectors I wasn't able to easily swap lamps around to see if the voltage changed on that part of the board, but it was similar to the other voltage so I ignored.
So I'm back to my original idea. There are 2 lamp powered by D122 and related inverter. I replaced the one lamp with the blue wire because it appeared to not light so well during the 2seconds to black. Now when it lights it looks MUCH brighter than its brother that is also powered by the same inverter. Swapping these 2 lamps, the one new and the one old, to the other side of the board yeilds similar results when measuring D120. I think I either had 2 bad lamps. (now down to one bad lamp since I replaced one) or both sides of the board have the same bad solder joint problem. But that doesn't seem logical when swapping sides put the voltage readings similar to the 3rd set of lamps. Make sense???Comment
Re: Starlogic HD20W
My soldering is not all the great, that is for sure....but I'm thinking I didn't break it....
Re: Starlogic HD20W
[QUOTE=bsweasel;118900throw it in the dumpster.[/QUOTE]
May I suggest you post it on your local kijiji or craigslist. Someone else might be able to use your parts.--- begin sig file ---
--- end sig file ---Comment
Re: Starlogic HD20W
I work some old 20 inch Dell & Nec + gateway LCD monitor, inverter board had 3 set quickdisconnect for 6 CCFl backlight, on normal condition 2 CCFL outside on top & bottom will on & one on mid is backup (that mean one CCFL backlight out both mid backlight on top & bottom will turn on)
I think you problem is inverter board had:
1/ bad cap (most time small cap will blow at bottom) replace all cap
2/ make sure check fuse F101 & F102 if one blowed will not turn on top or bottom backlight & will auto shut off
3/ bad transformer take close look see some burned
If you want quick fix google inverter # or LCd monitor model# & parts or ebay or
http://www.shopjimmy.com/
good luckLast edited by hoadle; 08-17-2010, 01:16 AM.Comment
Assuming...7 Photos -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by chth96Hello
I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor.... -
by khelaneHello
I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
Is there a way... -
by chronic519Hello.
GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
Found issue with a RAM block
Replaced, green lines gone.
Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
Used a good card to test and same results low errors 32+.
I am just search for some form of command to do a full test on the GPU.
I just ran the mats command with my good GPU and passed after roughly 40 min.
The repaired one, ran... - Loading...
