Re: Sceptre x22wg-Gamer 22" LCD
I made a mistake before and I measured Pin 25 (VD0) and you wanted 48 - VDD. But now I looked at the datasheet and I can tell which it is. No worries though, because the measurement is exactly the same.
Regarding the resistance check... Which Ohm setting should I have the meter at? Also am I correct in assuming that common probe will go on the regulator and red probe on pin 48?
