VA912B Viewsonic, photos, need some help.
  • capacap
    • Jun 2010
    Viewsonic VA912B, screen appears dead, speakers click every two seconds or so, green power light flashes. Nothing else remarkable happens.
    Have seen a lot posted about bad capacitors, but I've never replaced one and don't know if that's what it needs. Could someone knowledgeable please look at this photo and give your thoughts. I suspect they're all swollen a bit and that one leaks, but for all I know that's as they should be.
    I'm game for trying to replace them to keep this screen out of a landfill, but only if they're suspect.
    Thanks for your help.
  • lucky13
    • Aug 2007
    • 412
    Re: VA912B Viewsonic, photos, need some help.
    Yup, these caps are definitely BAD. See that brownish stuff on top?
    Replace all of the CrapXon caps on the board (except input 400V one) and 95% chance that's all you nned to do.
    I know there are several previous threads outlining what caps you need (value & size). You should update your profile to show your location so we can suggest which online retailer you can get the caps from.
    Good luck.
    • EGuevarae
      • Nov 2008
      • 1336
      Originally posted by capacap
      ...but only if they're suspect.
      Hell yes, they are.
      I suggest you to see the FAQ on posting pictures. You might be yelled at for inline pictures.. it happened to me too.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • capacap
        • Jun 2010
        Thanks for the expert advise. Will replace them all.
        I didn't mean to post the photo... it a link to tinypic .com and I don't see any way to edit, nor do I recall a "preview post" option.
        Added: unexpected that this post has a "edit" button which I just used and that the original post does not.
        • Bobdee
          • Jun 2008
          • 461
          Hello
          You only have 10 minutes to edit a post
          After that nothing can be done to alter it
          • Wrog
            • Oct 2009
            • 472
            Upload a smaller size pic onto tinypic with the same name (overwrite the original huge one). Then, attach the regular picture using "Manage Attachments" here in the forums.
            • lostone
              Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
              by lostone
              Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
              First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
              When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
              05-19-2024, 11:40 AM
            • saimom
              Asus FX507ZC4 DANJLFMBAB0 REV B I need photos
              by saimom
              Hello everyone!
              Please help me determine which microcontroller was in this place.
              Logically, I guess that this is a ddr4 PWM memory controller and some kind of Richtek, but which one?
              Thise motherboard came after another service, where they say that water got on the controller and it burned down and they dismantled it.
              They did not take photos before the intervention
              The DANJLFMBAB0 REV B board, schematics, boards and photos of the motherboard were not found on the network, but I may have searched badly-((
              Maybe someone has a photo of this piece,...
              12-17-2024, 08:51 AM
            • Davi.p
              Reduce the size of photos please..
              by Davi.p
              Hi all, i'm asking all to reduce photos to a more comfortable resolution before post, the better like around 2000x2000, otherwise many PC / Tablets / phones refuses often to load them or has strong defection... today's digital cameras integrated in phones especially are a mockery because them saves photos at enormous resolutions with much less the real definition, so reducing them is only a good deal.. THANKS!!...
              05-16-2024, 12:53 AM
            • StefanNg
              Viewsonic VX2718-PC-mhd SG2701B01-8
              by StefanNg
              Hi, Badcaps.
              I am troubleshooting a monitor
              Viewsonic VX2718-PC-mhd.
              Panel model SG2701BSG2701-8
              Symptoms is no image.
              This panel has 2 panel board connected by a U-ribbon.
              When I disconnected the ribbon, I get a perfect half screen image.
              I took some test point voltage, when ribbon disconnected.
              HVAA 8.38v
              FVDD12 1.21v
              FDD33 3.3v
              VIN 11.79v
              VAA 16.85v
              VGHF 30.16v
              VGL -8.02v
              CK1_I ~ CK8_I 1.403v
              CK1_L ~ CK8_L 8.26v
              When I connect both panel board
              HVAA, VGHF, and CKx_L...
              05-17-2025, 01:43 AM
            • Fagauthier
              Viewsonic power supply model #EADP-64BF B Need circuit diagram…
              by Fagauthier
              I have à defective Viewsonic monitor. I can't find a circuit diagram for it' power supply.
              Model #EADP-64BF B
              The user manual have all diagram except for the power supply. I would appreciate help to find the circuit diagram, thanks...
              07-08-2023, 08:02 PM
