Iiyama ProLite E4315
  • luggie
    • Mar 2010
    hi folks
    First of all, I have to say that I'm really new to this topic but I'll try my best (:
    My Problem: My LCD switches itself off after 4-5 seconds. The LED still shows that it's on, not even stand-by.
    However I've read through several threads and found out that I'll have to replace some capacitors, but I'm not sure which one of them. (or all?)
    Therefore I made a picture
    Legend:
    -2x red circle: 470uF, 16V, Hermei LT 105°c
    -2x blue circle: 1000uF, 16V, Elite EB(M) 105°c
    -2x yellow circle: 150uF, 25V, Hermei LZ 105°c
    -2x gray circle: 220uF, 25V, Hermei LT 105°c
    -5x green circle: 470uF, 16V, Vent HG 105°c
    -2x purple circle:10uF, 50V, CD81 TL 105°c
    -1x double red circle: 4.7uF, 50V CD81 T2 TL 105°c
    -6x double blue circle: 10uF, 16V, 0515(s), SM 85°c
    -1x double yellow circle: 100uF, 16V, 0515s, SM 85°c
    -2x double gray circle: 47uF, 16V, T2 T3, CD11KW 40/105/10
    -1x double green circle: 47uF, 16V, EL CD110 40/085/21, T2
    /edit: -1x the big black one (don't know how I could overlook that one):
    400V, 100uF, HT 105°c(v)
    As you can see, there's no bulged capacitors, so I don't know which one could be damaged. It'll be also nice, if you could give me some advise, which electronic shop I should prefer or which producer.
    Please don't mind my English mistakes, I'm from Germany
    According to this, it would be nice, if you could answer me in an easy language, so I don't have to put out my dictionary all the time
    luggie
  • FIXITNOW
    • Jun 2008
    • 128
    Re: Iiyama ProLite E4315
    replace the
    use good qualty low esr caps panasonic FC or FM range or sim
    these are usually problems
    • luggie
      • Mar 2010
      okay ... some other opinions for my lcd? (:
      or does everyone agree with fixitnow
      • Scenic
        o.O
        • Sep 2007
        • 2642
        i'd give it a try..
        you can get panasonic FC caps on reichelt.de (10eur minimum order though.. so look around if you find something else that you may need)
        • Scenic
          o.O
          • Sep 2007
          • 2642
          damn edit limit..
          http://www.reichelt.de/?;ACTION=2;LA=2;GROUPID=4000
          hope that link works..
          • mikey5791
            Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
            by mikey5791
            Got this working ips led monitor by the brand of
            Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
            Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
            09-04-2023, 03:50 AM
          • howardc64
            TCL 49S405 double image
            by howardc64
            LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
            This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
            06-23-2025, 03:20 PM
          • Cornito
            Samsung UE55RU8000 reboot and then double image after heating up
            by Cornito
            Hello team,
            I'm back with another tv and another problem.
            I try to improve my knowledge on fixing TV, and all technics used until now are not fixing correctly the problem.
            First, reboot issue, I use tape Method to find out the right side that cases the issue.
            Then using this it's working for quite 1hour30, then at some point of time the image became double on the bottom for half the screen.
            Then double image reduce in height and move to the top.
            The image is like folded on around 1cm and the bottom has been moved to the top by 1cm.
            When I...
            03-31-2024, 01:37 PM
          • Xristakis795
            le40b530w colour problem and double letters
            by Xristakis795
            hi to all on the above model i have solarized picture and double letters
            it uses tcon board FHD60C4LV1.1
            i think as about as the double letters maby the problem is the same display
            but as about as the colours it likes as solarized picture
            i look to find the schematic for the above tcon card without success
            has anybody measure the voltages from the above tcon card to advice me how can i measure the gamma voltages ?
            thanks on advance
            07-10-2023, 02:31 PM
          • tuantu01
            IIYama NH55HP No Audio
            by tuantu01
            I have iiyama brand computer. Modem NH55HP currently does not recognize the sound card. Looking forward to support in bios. Sincerely thank you...
            02-13-2025, 09:16 PM
