Acer AL2423W LCD Monitor - Bad caps
  • blowing_in_the_watts
    • Jul 2010
    • 21
    Re: Acer AL2423W LCD Monitor - Bad caps
    man i love hearing about this!
    though the OP i am simply amazed you found rubycon and UCC in a "new" monitor
    my bet is it was 4 years old, it was already worked on once before
    it seems there are 3 or 4 of this psu/ inverter here in the forums with the same pcb boards
    mine is acer x241w sd mid 2007
    all the luck to everyone who comes across them in the cheap junk bin
    because i did not check everything it seems i have some other problems
    and now fixing it isnt much of a cost viable option either
    ...unless you have a spare xad306lr you want to ship to me!
    ha, yeah taepo and capXcon...
    luckily i can get pico fuses down the road also
    well my donated one gets to sit in its box until something else comes up
    meanwhile i get to work on a dell BENQ psu next
    yay me with my valuable knowledge and time
    • pjt
      • Aug 2010
      Can someone describe what a "pico" fuse is and what it looks like? I pulled apart my Dell SP2208WFPt, symptoms were no power, no front lights. PSU/inverter board has plenty of CapXon caps, but none look particularly suspect (ie bulging). Should I just change them all out?
      • retiredcaps
        • Apr 2010
        • 9271
        A pico fuse is just another type of fuse. It usually looks something like this
        http://media.digikey.com/photos/Litt...1%20SERIES.jpg
        It will be marked PF on the PCB board. Something like pf500. It could be the main fuse right by the AC input that is bad, but not likely the picofuse. A good fuse should measure 0.3 ohms.
        If you are not getting power (no power LED), your problem is unlikely to be a picofuse.
        Do you have a multimeter? If yes and you are experienced in electronics, you can measure the DC voltage across the main filter capacitor (the biggest one on the board). That DC voltage should be 1.4 * mains line voltage.
        Also post clear focused pictures of your boards (top down view - both sides) after reading
        https://www.badcaps.net/forum/showthread.php?t=1868
        --- begin sig file ---
        --- end sig file ---
        • xfeastonarsex
          • Dec 2010
          I have this same monitor and subsequently the monitor failing is how I came across this forum. Great information! My monitor was experiencing a cross-hatch (read flannel) pattern when I turned it on. When I took the back off I got the same bloated capacitors as shown in the pictures on the thread. I was just going to replace the whole power board if it was cheap enough, but I think I will replace the capacitors at this point so the monitor lasts a fairly long time.
          • retiredcaps
            • Apr 2010
            • 9271
            A power board will probably cost you around $60. New caps will cost no more than $10.
            In addition, the power board will likely be used and have used caps.
            • xfeastonarsex
              • Dec 2010
              #26
              This is exactly what I was thinking, not to mention I love to tinker, so it should be a fun little project that will save me some money.
              • pmichel
                • Nov 2010
                #27
                My AL2423 is starting to fail as described here...
                I will take pictures next time it does it...
                Good for me I have a fairly good 50Mhz Scope
                Anyone's got recommendation, since it's not totally dead yet ?
                For now, I removed the DPMS power save, so it should live a bit longer...
                • jetadm123
                  • 2169
                  #28
                  I would suggest you DO NOT wait until your monitor completely fails. If the current problem are only bad caps, then you'll get away with a $10-$12 fix. By waiting, you're allowing badly filtered DC voltage to reach other components, causing overheating, which can lead to a more costly and time consuming failure.
                  • pmichel
                    • Nov 2010
                    #29
                    Hello Jetadm !
                    You convinced me...
                    and by the time I receive the replacement parts, the monitor had become unusable...
                    I changed all the caps of the power board for Panasonic caps (5000h+ endurance),
                    that is:
                    C14,C15 : 1000uf 16v (mine were inflated exactly like shown on some pictures on this thread)
                    C22 : 4.7uf 250v
                    C13, C16 : 100uf 25v (one was severely inflated)
                    C23 : 10uf 50v
                    C24, C25 : 33uf 35v
                    C32 : 22uf 50v
                    C10,C11,C12 : 680uf 25v
                    C30: 22uf, 25v (this one though I didn't like my replacement part, so I installed a 22uf 50v)
                    I tripled-verified the weldings
                    and then put the power ....
                    ...back like new !!.... (which is an understatement because nowadays LCDs hardly outspec this monitor!)
                    For now, I didn't change the caps on the video board, they are all teapo ... I read they are bad...
                    but I bought the replacement anyway...for the future...in case problems start again
                    Thanks for all the info on Badcaps.net
                    Question...
                    In my mind, a 100uf 25v cap will behave exactly the same
                    as a 100uf 100v cap ( with signals <25v )
                    but... I never tried to measure the difference... has any of you experience a difference with caps of different voltages ?
                    tx
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16956
                      I just had to recap the inverter board....I turned it on today and about 30 seconds later I heard a loud POP, and the lamps on the left side had gone out (makes for a goofy looking screen)! ...one of the 3 180uF 30v caps had vented, another was swollen, and the last one still looked ok....I changed all 3 and once again, shes back in action.....but lesson to those working on this monitor, just go ahead and recap the inverter board while you're at it.
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                      • c_hegge
                        • Sep 2009
                        • 5219
                        On all the monitors I've worked on, the inverter board was part of the PSU
                        • Topcat
                          The Boss Stooge
                          • Oct 2003
                          • 16956
                          Not on this one....it has a dedicated board for that....its a huge ass board that runs the entire height of the monitor. If you look at the pics, its the board under the metal cover on the side with the vent holes in it.
                          Team : 49813
                          Join in!!
                          Team Stats
                          • vo_danh
                            • Sep 2010
                            • 10
                            #33
                            I should have read this thread first before closing it back up so I would have gone ahead and replaced the caps on the inverter board. Too late now, but i'll probably sell the monitor soon.
                            My issue was the monitor would be on, but take a while to light up, maybe a good 10-20 seconds of the Acer logo going, sometimes longer. When it finally displayed the image I would get the "No Signal" overlay from the monitor, even though it was still displaying the image perfectly. Every 5 minutes or so, it would finally detect the signal ( mind you its already displaying the image ) and restart and the "No Signal" message would go away. It continues to cycle through this every so often. Seemed like a power issue so I opened it up and found several bad caps. I only had time to replace the ones noticeably bulging, I did not ESR test every single cap.
                            Replaced the following bulging or pushing up from the bottom :
                            CS16 : 100uF 25V replaced with 220uF 25V
                            CS13: 100uF 25V replaced with 220uF 25V
                            CS14: 1000uF 16V 10mm replaced with 1000uF 16V 8mm
                            Replaced the two 680uF under the heatsink with 1000uF of same or higher voltage ( don't remember cap positions, I was relying on images on the first post for positions since I already closed her up ).
                            Obviously my caps weren't ideal replacements but they were all I had at the time. Monitor works fine now and is still extremely bright. Bought it a few weeks ago for $50. Didn't notice it even had speakers since they face down and don't show a grill. Accidently broke wires from the connector when I was trying to pull it off the board so it took a little while to figure out the wiring and resolder speaker wires to the crimps. Couldn't find pics for the wiring so I had to go ahead and just tried all the combinations until speaker worked again, although i have it set to stereo but both speakers go off when I test one or the other.... not sure if its because i rewired it wrong, or my audio cable is not stereo.
                            • Behemot
                              • 4845
                              • CZ
                              #34
                              This display is full of crap, besides the first one I got some time ago (with nasty cold joint under freewheeling diode on primary and crap caps on secondary), the second one I just repaired got the rest of caps bad. Namely the 4,7 uF/250 V sitting on primary PWM chip with 120 ohm ESR, than all those 330uF caps on signal board also with one 22uF/25V general purpose cap in there having 13 uF and 15 ohm ESR. Changed every single non-quality cap in there which was terrible work, soldering these Acer signal board is messy job.
                                by momaka
                                03-15-2023, 10:17 PM
                              • wattage
                                by wattage
                                Hello Badcaps Community,
                                Yesterday, 04:41 PM
                              • ant3202
                                HP 27es - LED monitor - Monitor Flashing On - Off
                                by ant3202
                                Hi Everyone
                                Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                https://www.badcaps.net/forum/troubl...lashing-on-off
                                The monitor is HP 27es LED Monitor
                                https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                The monitor will randomly blackout and display no signal and will recover again.
                                Sometimes need to power and off again to restore the display but...
                                03-20-2025, 07:30 PM
                              • Rick_1234
                                by Rick_1234
                                Good evening, gentlemen.
                                Things I tried
                                06-22-2024, 04:44 PM
                                Wise Wing F199 19'' LCD monitor - recapped
                                by momaka
                                Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                                I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                                When I saw the Craigslist post, I wasn't...
                                08-24-2020, 10:58 AM
