Re: Hyundai L90D+ inverter mosfet problem
Just received the FETs yesterday - will give this a go in the next few days...
I too have the same problem with this board. Did you get it working by replacing the APM9932 FET's and C23 and C53 cap's?Leave a comment:
Hello! The APM9932 is available through Ebay, item 200446667412. It also looks like the seller ships worldwide. Hope this helps.Leave a comment:
Hi Lydux,
I have an identical monitor with exactly the same symptoms and am going to attempt to repair it - did you have any success with yours?
CheersLeave a comment:
Just try this, and it seems that U4 is shorted on P channel. I've got 0v from D to S and S to D, that's it ?Originally posted by KrankshaftTest the driver FETs with a DMM are either of them shorted?
Thanks to ecking767 and dondrusco for your tips guys ! I do not know this ability on Fairchild website ! Unfortunately, it doesn't return me anything with APM9932.
So, a 0.1 uF capacitor for C23 will be good ?Leave a comment:
It's discharge capacitor, I think.
But exact value - I don't know. I found correct value by searching MOSFET datasheet.
https://www.badcaps.net/forum/showthread.php?t=5346Leave a comment:
Test the driver FETs with a DMM are either of them shorted?Leave a comment:
to solve one of your problem C53 and C23 should have the same value. The circuit is symmetrical. As for the AP9932 try FairChild website cross reference
Hope this help
ecking767Leave a comment:
Hi there !
I would like to thank you first for this great forum, I learn a lot here on LCD repair !
I recently found a dead 19" Hyundai L90D+ that I really would like to fix and I think I'm getting closer to this.
Here is what's the problem : just after plug in the power cord, the blue power led turns on. About 5 seconds later, this same led quickly turns to orange and everything shutdown like if a short has come (I can also hear a tick at this time). So, this process restart and loop forever. No Backlight at all.
Looking to the power/inverter board doesn't show me bulged caps, and anyway it looks like more a MOSFET issue.
I disconnected it from the logic board, the ticking stop and I get a good 12V and 5V at pins header without shutdown.
Then, I hooked SLP to 5V and the backlight starting to flash.
This drive me to the solder side of the board where I can find two dual NP mosfet (U4 and U5) named APM9932 (datasheet here ). Looking closer, I can also see a damaged smd capacitor just nearby U5 (C23). So I suspect something in that area to be the failure.
Since I cannot find service manual for this monitor, I don't really know what value is C23 nor what kind of mosfet can substitute these APM9932 (can't find them on Digikey or Mouser). And anyway, I'm not an hardcore mosfet calculator.... :p So I need your help on this point !
Am I right on what I have done ? Any advices else ?
Many thanks in advance !Attached Filesif you find these attachements useful please consider making a small donation to the site
Tags: None
by JaneI tried to use this method:
Testing an N-channel MOSFET:
Step 1: Discharge the Gate (turn off the MOSFET)
Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
Step 2: Charge the Gate (turn on the MOSFET)
Now, place the red probe on the Gate (G) and the black probe on the...09-27-2024, 03:31 AM -
by NooyHello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet... -
by redbaron1007I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...1 Photo -
Hey guys,
i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
Now i thought something... -
by MicroSMD LabThe board number is GU502DU. I repaired this a couple weeks ago and it came back with the same issue, same mosfet failed (PQH9201). I'm hoping that the GPU was spared this time.
I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the... - Loading...
