Iiyama E511S blown SMT caps on PSU board
  • fergal
    • May 2008
    • 4
    Hi
    I have a Iiyama E511S which switches on for a fraction of a second and during that time the picture looks ok. All the electrolytics on the PSU board look ok, but on the underside there are a couple of blown SMT caps (see picture). These caps are so burnt so I can't see what value they were.
    Any ideas of what value these are likely to be? If it helps, the 8 pin chip next to the caps is an APM9435 P-Channel Enhancement Mode MOSFET. I've looked for a reference circuit which uses this chip but had no luck so far.
    Fergal
  • fergal
    • May 2008
    • 4
    Re: Iiyama E511S blown SMT caps on PSU board
    As I don't know much about SMT, I've been reading up and here's a bit more info.
    It looks like the caps are in a 1206 package and one side is connected to ground so maybe they're doing some decoupling? Would 0.1uF or 1uF be a reasonable value to try as a replacement?
    Fergal
    • gonzo0815
      • Feb 2006
      • 1600
      Yup, 0,1Uf -1uf should be sufficient, depending on the purpose the capacitor was placed there.
      But probably there is more bad then simply the MLCC`s.
      • Krankshaft
        • Jan 2007
        • 2328
        Are you sure that they are caps?
        They could be protection diodes for the FETs.
        One of my monitors with those SMT switching FETs had diodes in close proximity like that too.
        • fergal
          • May 2008
          • 4
          Yes, they're definitely caps. They're still recognisable as such plus they have C7 and C28 printed next to them on the PCB.
          I realise there might be other problems, but as I got this monitor for free I thought it's worth a try.
          Fergal
          • tjmatt
            • Jun 2008
            • 1
            I have a monitor with exactly the same problem. Where you able to solve it by replacing just the cap? Mine has only blown C28 but has also broken the track where it blew.
            Cheers,
            Matt
            • Wizard
              • Mar 2008
              • 2296
              When this happens, this means your other capacitors (electrolytics) are going too, putting too much noise into power plane, eventually that 2 high capacity ceramic caps fry.
              Cheers, Wizard
              • JEWilson
                • Sep 2007
                • 369
                • Scotland, United Kingdom
                I repaired one of these today. Different sympton
                The display was rendering artefacts such as shadowing and random lines.
                I opened the VDU up and found the PSU board to be in good condition
                Notwithstanding the UCC KY O/P filter caps, the remainder were all
                Elite, various series and values.
                The ESR was good on all of these caps but I have noticed this
                VDU gets hot. Puts out more heat than my HP1130 CRT!
                Anyway, I replaced these with Pana FCs and found furthermore, one
                of the caps on the logic pcb beginning to dome. There were two others,
                three in total 16V 470uF - Elite GPs 85 deg C right beside the power
                stage on the logic pcb. Why oh Why? These are getting fried (possibly).
                Suffice to say, these were summarily replaced with Pana FMs and I
                further replaced the remaining two lytics worth a mention on the logic pcb.
                These again were Elites, 16V 330uF - again replaced with Pana FMs.
                The remainder of the lytics are all 25V 47uF bypass caps for the
                ICs and such like.
                Guess I was lucky and got to this VDU prior to major issues.
                Anyway, I'm using it presently and no problems thus far.
                • WojtasJD
                  • Jan 2009
                  • 1
                  the blown decoupling caps near APM9435 are 1uF, maybe 50V MLCC with Y5V dielectric (I'm not sure). You may put here 1206 1uF 50V X7R
                  Does anybody know what two THT caps are on the other side of the pcb near two small fuses ?
                  I think they are 220uF / 35V - is that correct ?
                  • FIXITNOW
                    • Jun 2008
                    • 128
                    had one of these
                    These caps were so burnt C7 and C28 0.1uF 50v 1206 sm check case broken the track . plus replace all electrolitics in psu if ESR measures 16V 470uF etc
                    • wreeve
                      • Nov 2010
                      • 1
                      I have two E511S monitors side by side! One was showing the switch on problem (back-light not working) the other the artefacts / noise on the screen. Fixed one by replacing the two SMT capacitors on the PSU board (they looked OK but now replaced monitor works fine). Fixed the noise on the other monitor by replacing all the caps around the PSU area on the micro-board, again they looked OK but replacing them fixed the problem! Thanks guys.
                      • Greeno
                        • Feb 2011
                        • 36
                        • Scotland
                        I also have a faulty E511S - it has the same obviously overheated surface-mount capacitors on the underside of the board and I found a faulty transistor beside them. Capacitors seemed to be OK so I only replaced the transistors.
                        It worked for a minute then failed again - pulsing on and off. The replaced transistors appear to be OK so I fear I may have pushed the fault elsewhere.
                        There are two suggestions above for the value of the capacitors: WojtasJD says 1uF, FIXITNOW says 0.1uF.
                        Can anyone say definitively which it should be?
                        Thanks.
                        • bouncingboffin
                          • May 2018
                          • 1
                          I have just encountered the same problem on the exhibit I run at a computer museum. I couldn't find instructions on how to disassemble the monitor, so after a bit of head scratching I worked it out.
                          I took the monitor apart, usual screws on the back and unclip the case, run a blunt knife, from the centre of each side back and forth and the two halves split, then remove the RF conductive tape, remove the bottom screw and then remove the outer shielding box.
                          This monitor has burnt up its SMD MLCC and taken a chunk of PCB with it (some more adventurous rework needed!) The problem seems to lie with the ESR of the capacitors increasing as their capacitance is decreasing (age/heat/electrolyte related). I pulled every electrolytic capacitor from the board and measured its ESR and capacitance, just to be 100% sure to avoid parallel capacitance. It seems the small value capacitors (Elite branded) suffered the most in this respect. Their ESR went from 0.05R to as much as 6R with a loss of capacitance of around 20-30%
                          This photo shows the caps that I am going to replace
                          This photo shows how only half of this board failed, the ESR value of the 47uF electrolytic was about 1/3 of the failed side.
                          This is a close-up of the burnt C29 MLCC - it shows typical overheat and arcing damage. Probably worth replacing its counterpart...
                          Of course, I don't know if this is all that is damaged, I am awaiting components to do this fix. This is the list of capacitances and ESR of the electrolytics on the board, might be of help to someone.
                          Code:
                          Name	uF	V	uF read	ESR 	Replace?
                          C134	10	50	8.36	2.62	YES
                          C133	10	50	8.46	2.44	YES
                          C4	10	50	8.71	1.47	YES
                          C35	47	25	41.42	2.92	YES
                          C34	47	25	32.44	6.28	YES
                          C27	220	35	237.48	0.05	NO
                          C2	220	35	241.31	0.04	NO
                          C144	10	50	11.42	0.62	NO *on daughterboard, may replace
                          C126	680	35	693.78	0.03	NO
                          C127	680	35	694.54	0.02	NO
                          C130	220	35	242.36	0.06	NO
                          C132	680	16	705.14	0.02	NO
                          C141	680	16	710.46	0.04	NO
                          C129	2200	10	2392.33	0.02	NO
                          C131	330	25	323.19	0.06	NO
                          C121	10	50	9.24	1.52	YES
                          C154	100	25	88.82	0.75	YES
                          C106	47	450	45.54	0.55	NO
                          • Stefan Payne
                            • 1267
                            Remove the MLCC Cap and check the traces for resistance...
                            Sometimes when those things go, they make everything close to it conductive...
                            • printerman
                              • Sep 2020
                              • 1
                              • United Kingdom
                              Hi
                              I also have an E511S I think the problem started with one of the 3 high voltages caps at the end of the inverter arcing through the insulation under the board also 2 of the 2sc5103 transistors failed. and 1 of the 3A fuses had failed.
                              I have changed all 3 of the high voltage caps, the 2 2sc5103 but still have no inverter, what seems to be missing is the high voltage driving the transistors, not sure what value this should be as I do not have a manual so I do not even know where the voltage comes from.
                              Would anyone have a circuit diagram of the PSU showing the area in question and saying what the voltage should be.
                              I have also carried the suggested repair the the wiring of the caps by bending over of the wires to these caps and then resoldering.
                              Any suggestions would be appreciated
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • odtech
                                Asus UX490U laptop blown (caps?) on power board.
                                by odtech
                                Greetings friends.
                                I was given this nice little laptop and would like to revive it if possible but i'm stuck identifying blown components. I'm very new to the repair game so i'm proceeding very cautiously.
                                I don't know the history of this laptop and the donator didn't elaborate what happened but it seems some moisture got into the USB C charge port and the result was what looks like some blown caps. The tell is some gunk inside the USB C port and corrosion on the outside as well as what looks like corrosion around the blown components.
                                Any guidance...
                                08-06-2023, 10:29 AM
                              • Dani_2024
                                by Dani_2024
                                10-28-2024, 05:06 PM
                              • black6host
                                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                                by black6host
                                Good day!
                                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                                I'm going to replace the caps and I'll be the first...
                                02-06-2024, 08:22 PM
                              • Noodneek
                                Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                                by Noodneek
                                My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                                I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                                08-30-2024, 12:52 PM
