benq fp783 help
  • milstr
    benq fp783 help
    Hi folks,
    I need shematic diagram of inverter board because I have two small IC's (8 pin) totaly burned I don't know what is it. I can see only number 4431 on it and it's all.
    Thank's .
  • FIXITNOW
    • Jun 2008
    • 128
    Re: benq fp783 help
    these are Si4431
    try google search for data sheet
    • Krankshaft
      • Jan 2007
      • 2328
      Re: benq fp783 help
      The 4431s are backlight On/Off FETs made by Vishay Siliconix. Try Farnell for them I think they have a warehouse in the UK.
      They blew because one of the inverter driver transistors shorted also be sure to check the inverter fuse. If it's a Benq build and it uses those FETs the drivers are probably 2SC5707s. Also resolder all of the inverter transformer pins replace any bad brand caps on the secondary the Benq builds I worked with used Elite crapacitors.
      Usually both of the FETs don't blow only one does (the one in the same circuit with the shorted driver). You may be looking at 2 failed driver transistors or something external caused this failure like badly cracked transformer joints or the monitor was hit by some kind of power surge.
      • milstr
        Re: benq fp783 help
        Thank's All,
        I try all steps mentioned above and then we will see )
        • x_orange90_x
          Vizio E55-E1 bad backlights or bad inverter?
          by x_orange90_x
          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
          I don't know how exactly to test the inverter itself. Is it...
          01-29-2025, 09:24 PM
        • Gentian
          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
          by Gentian
          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
          03-06-2023, 07:07 AM
        • valvashon
          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
          by valvashon
          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
          01-04-2024, 01:44 PM
        • eccerr0r
          A modified sine wave inverter + a grid tie inverter?
          by eccerr0r
          If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
          Next thing is trying to charge the batteries using solar power, but that's another issue ...
          08-31-2023, 09:14 PM
        • caseyjay_48
          Sony KDL-46BX450 Inverter Troubleshoot Logic
          by caseyjay_48
          I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
          I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
          09-23-2022, 08:08 PM
