Re: vp2130b cap help
What do you mean "High or low ripple level"? For caps, a higher ripple current rating is good, it means it can handle more ripple current. The higher the rating, usually = larger size caps.
vp2130b cap help
Originally posted by SplinterAl,
Thanks for your advice. The difficultly with the VP2130b boards is accessing them when the display is running due to the way in which the unit is constructed. However, I'll certainly give it a try.
I'm just about to order the replacement caps for the power board. I have identified caps that match both capacitance and voltage but its been difficult to pin down the ripple level for the originals so have had to go for a simple size for size match.
Is there any rule of thumb for caps used in this sort of power board? A dim question I know, but is it better to chose caps with a high or low ripple level if available?
Splinter
Al.Leave a comment:
Originally posted by alexannaSplinter.
If your problem is heat related, I have had some luck, with the tip of my voltmeter lead slightly flexing various points around the circuit boards to locate poor solders joints, you might be able to Recreate your problem .There have been some I have found that I could not find with my eyeball. Be careful there are some high voltages on the board.Also a sewing needle attached to a very well insulated object makes a good back prober.
Al.
SplinterLeave a comment:
Al.
Splinter.
Al.Leave a comment:
Originally posted by PlainBillYes, that's a limitation. At least post the link.
Suggestion: I've seen a lot of service manuals on Scribd. Perhaps upload it there so we can all find it? Something to think about.
PlainBill
VP2130b Service Manual
VP2030b Service Manual
I have attached plan view pics of the logic, power and inverter boards as you requested.
Regarding your suggestions. I'll can try reassembling the display and running it without the back cover. Might also try gently warming the individual boards with a heat gun in an effort to identify the faulty board. I don't have the correct multimeter probes for accessing the output terminals but will see what I can do to measure voltages.
That said, I really need the display up and running pretty soon so don't have the luxury of time here. So my fallback plans are firstly to replace all but the big 150uF cap on the power board, as you have suggested and if this still doesn't fix the problem, replace all the boards, starting with the power and inverter boards. Bit of a cop-out I know, but when needs must . . ! I have eventually managed to find new replacement components.
Thanks for your advice. I'll keep you posted on progress.
Originally posted by SplinterOkay, the VP2130b service manual pdf didn't stick. I guess at slightly over 5Mb it's a bit on the large size.
Splinter
PlainBillLeave a comment:
Originally posted by PlainBillYou are correct, all the caps look physically fine. The light brown cap is made by United Chemicon. The 'crown' logo is distinctive. Rereading the thread, I had a similar experience with an earlier version of your monitor - a VP211B. I 'fixed' that one by swapping the logic card.
A couple of suggestions come to mind.
1. Try operating the monitor with the back off to see if the improved cooling has an effect.
2. Try measuring the output voltages of the power supply while the monitor is working and again when it fails.
3. I prefer a single over-all shot taken from directly above rather than a series of more detailed pictures. I'd like on of those of the logic card (video processor, etc).
4. The Nichicon and United Chemicon caps are a good brand, the others are suspect. I suggest replacing them all. This is a process for selecting caps.
PlainBill
SplinterLast edited by Splinter; 07-01-2010, 02:02 PM.Leave a comment:
Originally posted by SplinterThanks PlainBill. I've attached detailed pics of the inverter board and power board on this post. I can get to the main board later if required.
Inverter Board INV20-6009
There are only 3 caps on this board - these were CapXon 180uF 35V 105ºC - and when the "on/off" problem first manifested itself I found these were well blown, so I replace them with Panasonic 180uF 35V 105ºC caps part number EEUFC1V181 (pic Invboard_1). However, this did not cure, or change, the problem.
Power Board EADP64BF B
This board is populated with a total of 7 caps, here are the details.
1 x 1000uF 16V Can't make out the name but its the horizontal light brown cap shown in the Pwrboard pics.
1 x 1000uF 25V Nichicon Black horizontal next to brown cap
1 x 220uF 25V Taicon Upright just behind aluminum heat sink
1 x 47uF 50V Ltec Along side the large cap
1 x 22uF 50V Ltec At the base of the large cap
1 x 150uF 400V Ltec Large horizontal cap - can't actually see the rating for this cap, but pics of replacement boards clearly show it as noted
1 x 470uF 16V Ltec Upright cap next to the horizontal caps
All of the above are 105ºC rated. I'm not sure about the series of any of these caps. How would this be indicated on the cap?
As said in my last post, visually all the caps look good. There is a slight heat discoloration under the heat sink next to the Nichicon and unidentified cap.
Splinter
Originally posted by retiredcapsOkay, so if you want to replace the main filter cap, look at the original cap for the manufacturer and series and then search for the datasheet. For example, if it is Capxon KF series 105C, look for that datasheet.
The datasheet will list the ESR ripple, etc. Then compare that to the Nichicon one your listed. If they are close then it is a suitable replacement.Leave a comment:
Originally posted by rachael7I figured caps are cheap and I have the thing apart, so it would be lazy of me to skip on that might be in question.Leave a comment:
Originally posted by retiredcapsWhat exactly is the problem with the monitor? It is rare that the big main filter cap goes bad. I'm not saying it is not bad, but rare.
EDIT: Worth noting that this is my 2nd VP2130b that's failed this exact same way and I have a third that looks to be on the way out. The first one was exchanged under warranty (for a refurb with a dim backlight), but this one and the next one aren't under warranty, so I hope I can learn to fix 'em.Leave a comment:
Originally posted by rachael7On my power supply board, the big 150uF 400V cap doesn't look so good and I think it could do with replacement.Leave a comment:
Originally posted by endeviteOk for the Powersupply, all my caps were good, however A Taicon existed that I did not trust, so I replaced it. Other powersupplies have been known to have bad caps however mine did not, but you can find those searching these forums.
Would this one make a suitable replacement? The physical size and obvious specs match up, but I know not the first thing about ESR, impedance, and whatnot. Thanks for any advice!Leave a comment:
Originally posted by SplinterWhat a great thread! Having just resurrected a VX924 by replacing a bunch of caps, I decided that I would have a crack at fixing one of my VP2130b displays that I use on my CAD systems - I'm a mechanical engineer by training so forgive my basic electrical knowledge.
Reading through the thread I don't see the symptoms that are effecting my VP2130b. It starts up okay but as the internal temperature starts to rise the display turns off and then back on with the "on" periods gradually getting shorter as time goes on and temperature rises. However,it never completely turns off.
In its self induced "off" state, the green power light goes off and at the same time there seems to be some low level backlight showing. In this state the display can be manually turned off completely by pushing the power button, at which point the screen goes completely black i.e. its really off! Let the display cool for a while and it can be used again before the temperature rises and the "on/off" cycle starts over.
I have already replaced the three caps on the inverter board which had no effect on the problem, so I'm guessing that problem is power board related. That said, how would I know as I'm way out of my depth here, so would really appreciate some expert advice.
I have carefully inspected all the caps on all four boards, and visually there's are no obvious blown caps.
SplinterOne of the more frustrating episodes involved trying to help fix a 'two seconds to black' problem. When a picture was finally posted, half a dozen bulged caps were obvious. Even worse, some Chinese manufactures have learned to make caps that fail without any obvious physical signs.
So the first step, what brands an series of caps are on the board? Also, if you could provide a picture of the board in your monitor, it may help us. Follow the link in my signature to the FAQ on attaching pictures.
The symptoms definitely point to overheating, if it wasn't obvious.
Thanks for that.
So i took a look at the Mainboard/Motherboard as well, and found the 6 Caps gone there as well. Just for everyone's reference, the VP2030B mainboard is identical to the VP2130B mainboard. So all instructions are valid for both.Leave a comment:
Most of this forum call them crapxon (instead of capxon) caps. PlainBill is partial to Panasonic FM caps and since FR=FM, and FM > Capxon, go ahead with Panasonic FR caps.
Other favoured options are Rubycon and United Chemi-con.
Originally posted by VandalixHi Plain Bill,
Not sure i understand your comment. I was more referring to the comparison of the Panasonic FR vs the CapXOn (which is the one on the Inverter board), would the Panasonic FR be comparable or better than the CapXon that i am replacing. CapXon features were listed by endevite earlier on..Leave a comment:
by chth96When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
Rubycon YK DataSheet (b...-
Channel: General Capacitor Questions & Issues
by iMicHi folks,
I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...3 Photos -
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by AntonynlI have here a HP pavilion hp 15-cs2975nd with a 1.095v power supply that is driven by a FDMF3035. I do see about 80mV of ripple on my scope. I searched through the datasheet to find possible values of the ripple but I don't understand the datasheet well enough.
So I have two questions:
1) what is the typical ripple voltages of gpu/cpu on a laptop or pc mobo?
2) what would be the max ripple of a FDMF3035 that drives an output of 1.095V?
Would be nice to have a rule of thumb of say a percentage of the supply voltage to be an acceptable ripple voltage....12-09-2022, 06:51 AM -
by momakaNormally, I never post repairs this quick after I do them, because… I am usually very slow.
But today, I’m making an exception here. Why? No idea. Perhaps only because the repair details are still “fresh” in my head… which is ironic, given this is a 16 year old monitor that hardly anyone will care about today. It is new to me, though.
I picked it up last November from someone on my local Craigslist. It wasn’t very close to where I live, but was close to a family friend that I had to go visit anyways. So after watching the posting on Craigslist for a few weeks and seeing it getting...
- Loading...
