Brightness Control on CRT Monitor
  • Thabto
    • Oct 2009
    • 32
    I received a 15” digital Acer CRT monitor for repair. It's model # 7234e to be specific. Everything else is functional except brightness control i.e. contrast, v-size, h-size, pincushion are all fully functional.
    For all of you who have repaired any CRT monitors before, can you please give me an idea where I can find brightness control circuit? The monitor has big IC marked “MYSON MTV112N-OTP”, I believe this is the controller. Unfortunately I could not get a datasheet for it, so if anyone out there has access to the datasheet they may give me. Alternatively one could get me the service manual for the monitor if it's not hard to find. Thanks in advance.
  • smeezekitty
    • Aug 2009
    • 32
    Re: Brightness Control on CRT Monitor
    Could be the potentiometer itself.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      not adjusting?
      iirc that one does not have osd so a failure outside the micro could stop it from adjusting but without osd for feedback.for instance low supply voltage to video amps.too bright and cant turn it down.control section is ok.btw i have seen a few of those with shorted crt's.a few way out of focus and a few g1-k
        by momaka
        03-15-2023, 10:17 PM
      • wattage
        by wattage
        Hello Badcaps Community,
        07-13-2025, 04:41 PM
      • ant3202
        HP 27es - LED monitor - Monitor Flashing On - Off
        by ant3202
        Hi Everyone
        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
        https://www.badcaps.net/forum/troubl...lashing-on-off
        The monitor is HP 27es LED Monitor
        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
        The monitor will randomly blackout and display no signal and will recover again.
        Sometimes need to power and off again to restore the display but...
        03-20-2025, 07:30 PM
      • tehmatix
        AOC U28G2AE monitor can’t adjust the brightness
        by tehmatix
        Hi, I have this monitor with this problem: go to menu picture of monitor and try to adjust the brightness, the cursor is moving to 100 but the screen still darker, without any change. Inside of the monitor, on power board I measured 32.42V output voltage on backlight inverter, which is constant for any value of brightness cursor ( 0 - 100 ) . It's possible to have a memory error on the logic board?
        02-16-2022, 02:34 AM
      • Rick_1234
        by Rick_1234
        Good evening, gentlemen.
        Things I tried
        06-22-2024, 04:44 PM
