AOC U28G2AE monitor can’t adjust the brightness
  • tehmatix
    • Nov 2012
    • 174
    Hi, I have this monitor with this problem: go to menu picture of monitor and try to adjust the brightness, the cursor is moving to 100 but the screen still darker, without any change. Inside of the monitor, on power board I measured 32.42V output voltage on backlight inverter, which is constant for any value of brightness cursor ( 0 - 100 ) . It's possible to have a memory error on the logic board?
  • tehmatix
    • Nov 2012
    • 174
    Re: AOC U28G2AE monitor can't adjust the brightness
    I had tested the led backlight with a different inverter, everything it's working. I have to check PWM signal at the input of OZ9998
      master hoarder
      • May 2008
      • 12175
      Also check any small caps around the LED backlight inverter circuit. If those are bad, that could also possibly mess with the PWM backlight adjustment.
      Pictures would help too, BTW, so we can see what you're seeing.
      • tehmatix
        • Nov 2012
        • 174
        Picture of powerboard inverter side
          master hoarder
          • May 2008
          • 12175
          The solder joints on some of the jumpers around U801 look bad. Probably not the problem, but certainly worth going over with your soldering iron.
          Were you able to check the PWM signal going to the input of U801?
          • tehmatix
            • Nov 2012
            • 174
            Thanks for your reply,
            I change IC U801 and what I got now is brightness on maximum but without control.
            I don't have any oscilloscope to see PWM on the input
            • R_J
              • Jun 2012
              • 9576
              Re check your solder connections on U801, maybe one pin is not soldered or two pins are shorted? Does the voltage on pin 16 change when the brightness is adjusted in the menu?
              • fixer1234
                • Mar 2023
                • Sweden
                @tehmatix Did you manage to fix the problem?
                I have the exact same issue on a Dell P2722H monitor.
                It feels like the brightness is stuck on 50%.
                If I can get it to 100% I'm considering adding a potentiometer to be able to adjust the backlight.
                  by momaka
                  03-15-2023, 10:17 PM
                • wattage
                  by wattage
                  Hello Badcaps Community,
                  07-13-2025, 04:41 PM
                • ant3202
                  HP 27es - LED monitor - Monitor Flashing On - Off
                  by ant3202
                  Hi Everyone
                  Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                  https://www.badcaps.net/forum/troubl...lashing-on-off
                  The monitor is HP 27es LED Monitor
                  https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                  The monitor will randomly blackout and display no signal and will recover again.
                  Sometimes need to power and off again to restore the display but...
                  03-20-2025, 07:30 PM
                • Rick_1234
                  by Rick_1234
                  Good evening, gentlemen.
                  Things I tried
                  06-22-2024, 04:44 PM
                  Wise Wing F199 19'' LCD monitor - recapped
                  by momaka
                  Looking through my repair pictures and notes, it's been a long time since I posted anything in the LCD monitors section. So here goes that.
                  I'm dedicating this thread to one of the very first LCD monitors I repaired (if not the first one), which was more than 10 years ago now. The monitor is a Wise Wing, model F199. It's a 19” CFL-backlit LCD. I got it for free off of Craigslist in 2009 from a guy, who said he bought it for cheap from Wallmart and the monitor worked only for a little less than 2 years before quitting.
                  When I saw the Craigslist post, I wasn't...
                  08-24-2020, 10:58 AM
