Hello! im new im trying to repair my 34um95-C, i cant find the EEPROM is the hdmi EEPROM?
LG 34UM95 - 34UM-P - Board is LM94Q/34UM95/EAX65360306 (1.0)
Does anyone have version LM94Q/34UM95/EAX65360303 (1.0) here? I don't know if the EAX65360306 version causes any problems to my EAX65360303 monitor, thanks​Comment
Could you describe/provide a diagram of how you connected CH341a to IC205 (mx25l8006em2i-12g) ?Comment
Does anybody have a clue what could be the problem, left and right side of the monitor sometimes are not syncronised, and it is only noticed on moving picture. I 've repaired this monitor with flash dump couple months ago, and it works, but sometimes i get asyncronised left and right side.
Video at youtube I uploaded in slow motion: https://www.youtube.com/watch?v=fgUwzhhSpKQComment
Is it possible that having the wrong firmware (I don't have thunderbolt) is causing this, or is this a problem with something else like the scaler chip?1 PhotoComment
To answer my own question my problem was with the ic700 voltage regulator. That tiny thing was a struggle and it took me three tries to get a replacement soldered in correctly.
I shorted the original with my multimeter probes. The second put out 1.9v when monitor was off but dropped to 1.3v on. Third I cooked soldering in place. 4th finally workedComment
I'm not sure why I'm so astounded that the internet is helpful, but this is the best thing that's happened to me in awhile. I never realized how much I like this monitor before it wouldn't turn on.
I had a bit of trouble getting the clip to attach. It took me 5 or 6 worrisome tries before the MX25L8006E was detected. I used the binary from the zip in post #3.
FWIW, the SPI EEPROM on my board wasn't completely dead and flashrom (under Ubuntu 20.04) was able to read the contents. There was enough info to notice that the original binary contained source code files from July 30, 2014 while the binary in post #3 contained source code files from Jan 17, 2014, so it's not the latest version. Not a big deal. My monitor is back working.
Thanks all!Comment
hello everyone
my 34UM95P gives me a black screen
I have the backlight
I bought the CH341 and programmed the IC205 with the 3 .bins I found
with the lg34um95 and the lg34um95-p, I have the backlight, but nothing with the 34um95
I checked the 10V panel which is ok
any idea?
thank you everyoneComment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by penangitHey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
Steps taken so far:
Checked all...-
02-21-2023, 04:00 AM -
- Loading...
