Hello, i need bios for lg 34um95 monitor, having this monitor to fix 2nd time, i need bios dump for him. Already read the original one, saved it, cleared the chip, flashed again and it was working for few days. Now once again he's not turning on. Attaching dump what i got.
LG 34UM95 - 34UM-P - Board is LM94Q/34UM95/EAX65360306 (1.0)
Tags: None
Re: LG 34um95
here a working dump for this monitor, in case someone else has this problem.
It fixed it for me.
Cheers!Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: LG 34um95
@REpairAT thanks for the file, worked for me on my LG 34UM95C (I got a kick out of German being the default language).
Most of the repair info out there is for the 31MU97, where the IC205 chip is on the reverse side of the circuit board from the power plug. On the 34UM95C, it is visible as soon as you remove the back cover, on the upper-right hand side of the board.Comment
Re: LG 34um95
Thank you very much for the bios.
My board is LM94Q/34UM95C/EAX65360307 (1.1) and has the IC906 on short circuit.
On it is written 3410I TI 51K D2KH G4.
I can't find anywhere information about this chip or where I can buy it.
Please if someone can help me.
Many thanks in advance.Comment
Re: LG 34um95
IC906 - TUSB3410RHBR - Texas Instruments USB InterfaceThank you very much for the bios.
Many thanks in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: LG 34um95
Hello guys, I cant start a topic yet so I want to try it here. Maybe someone else needs it as well.
I bought a 34UM95-P. With the same EAX65360307. Someone already played around with a repair and they did not fix it. IC102 was shorted on pin 6 and 7. And they knocked of a capacitor CB11/C811.
I flashed the bios back and now the screen does give a sign of life. The power led turns on for 10 seconds and turns back off.
IC102 was short so I assume that the controller is damaged or the file on it is corrupted. Can someone send me a copy of the rom on that chip? And can someone tell me what the capacitor is on CB11.
Thanks in advance!Comment
Re: LG 34um95
Is not IC 902 actually ? You write IC 102 ? If yes I have the file, I will give you.
And for capacitor if is a small ceramic smd I guess you can put any, it will work.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re: LG 34um95
Yes its IC 102. I dont know why they touched it when they tried a repair but I am guessing they thought it was the reason the monitor would not turn on.
It's the one really close by the green audio jack.
Re: LG 34um95
Hi there, I'm new to the forum, I'm here to try and fix my 34UM-P.
Once in a while it would just "crash" half the screen would go black, 2nd half would show scrambled image. Usually a power cycle would fix the issue, then once it did not..
I've tried to find a board to buy/replace, but I don't see any available.
I have the LM94Q/34UM95/EAX65360306 (1.0)
I didn't know I could try and reflashing the board to fixing the boot up issue.
Is there a tutorial somewhere that shows how one can try to flash the chipset with the originally attached bin?
This is the board.
Re: LG 34um95
Hi there, new user here!
Just wanted to say that I also got my monitor working by flashing ROM file posted here!
I downloaded the file, hooked up CH341a directly on to the chip on the board without desoldering it, flashed, and it is working now!
Thanks!Comment
Re: LG 34um95
If you get half screen scrambled You might have to reflow the processor under the radiator that send signals to that part of the screen, this doesn't seems to be a firmware issue.Hi there, I'm new to the forum, I'm here to try and fix my 34UM-P.
This is the board.
Re: LG 34um95
Big thanks for IC205 dump. I have been repaired two Lg34um-p and one Lg34UM-c-p. Thanks for help, im sending IC 102 dump, Tostieapperaatask ask for it.
Re: LG 34um95
I fix it with dump from from REpairAT. O have one more from here https://www.elektroda.pl/rtvforum/topic3769527.htmlComment
Re: LG 34um95
Does anybody have a clue what could be the problem, left and right side of the monitor sometimes are not syncronised, and it is only noticed on moving picture. I 've repaired this monitor with flash dump couple months ago, and it works, but sometimes i get asyncronised left and right side.
Video at youtube I uploaded in slow motion: https://www.youtube.com/watch?v=fgUwzhhSpKQ
Do I need to reflash it again, or need to reflow the chips?Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
- Loading...
