No power on a Acer AL1916
--- begin sig file ---
--- end sig file --- -
Re: No power on a Acer AL1916
While prepping the image, I realized that I can view the hi-res image in actual pixels.
Eureka! I see U406.
The part is in back-order at digikey until mid June. I removed it like the surgeon who took my appendix and voila, I have a working monitor!
I have another AL1916 at work. The boys requesting for dual monitors for their workstation will be happy.
Thanks to all who have contributed to this thread...
I'm contributing by attaching the board, boxed the location of U406.
I ordered the caps and will replace the Elite brands.Comment
Hi, i have the same problem my monitor has no power, my boards are different to all the pictures and i cant find the U406. I am confussed aldo to which board i am looking for it on is it the one where the monitor cable plugs into or where the kettle lead goes?
ThanksComment
There is a chance your monitor may not use a re set controller,Even if it did you would stil see 12-14V and 5 V on the connectors.
Have you checked all fuses?Some boards use some really small ones on the back of the power supply.
Post some good quality high detailed photos of your boards, using managed attachments.
and let us get our collective minds together,We will be able to help youWhatever I do, I consider it a success, if in the end I am breathing, seeing, feeling and hearing!Comment
Same problem here with the Acer AL1916. I removed the U406 Maxim reset circuit and it works no problem. I checked all the capacitors and visually they all seem brand new.
I want to replace that circuit but I can only find the reference MAX810MEUR+T from RS Amidata but I don't know if that's what I want.
I used a 26 Watts solder, I wonder if it's ok. Two more questions.
1.- Many people around the world seem to have just the same problem with that LCD. Can I be certain about most probably having the same problem in the future?
2.- Could that reset circuit has anything to do with refresh rate on the LCD.
Thank very much everybody at badcaps.net and special thanks to PlainBill.Comment
No, the reset circuit should not have anything to do with refresh rate.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
Never be afraid to try something new. Remember, amateurs built the ark. Professionals built the Titanic.Comment
There is a big mystery about this particular GPU. I'm coming to the conclusion that the reset controller should never have been installed, but I can't find any documentation to prove that.
PlainBill
Than you very much again PlainBill.Comment
Very short time before I found a problem that hadn't happened before.
I didn't realise yesterday as it was a quick test just to see if it turned on basically. The problem are some vertical stripes and I don't know if it has anything to do with not replacing the reset circuit E406 MAX810.
What do you think?
The stripes are not as clear and annoying on that picture as it is in reality. The screen look a bit foggy, mainly on the borders, but it won't show on a picture. It might be that I have damaged something while removing the E406 or something else.
I'll try to replace the Maxim reset circuit ASAP and see if that makes a difference. I'm afraid it won't solve the problem so any advice is welcome.Comment
No power on a Viewsonic VG920
Sharing my experiance and thanks. Had a dead VS VG920, no power up, no LED. Found this forum via Google and followed this thread. Tested U406 by shorting bottom pins and pressing power button several times and got some action. I then popped off U406 lower right as facing it and the monitor works perfectly. I reckon if it acts up more I'll replace the transistor then. But it seems that it functions acceptably without it. Thanks everyone! I will be bookmarking this site!Comment
I have this same monitor. When I take a reading from the large capacitor it comes back a 65 volts dc.
does that mean a capacitor is bad or something before the cap?
I am new to soldering and may request someone to assist me with soldering later so I would like to know exactly what I need to have done.
thanks for all the help.Comment
--- end sig file ---Comment
The first post in this thread has a picture of the power supply. Is your supply identical? If not, we will need a picture of your supply.
It could be either, or it could be 'technician error'. Depending on the line voltage it should be at least 100 volts higher. Are you measuring across the two leads of the cap?
PlainBill
I was posting from my mobile phone which wouldn't let me attach the pictures.
***Update***
I decided to just gently remove u406 and afterwards was able to get the monitor to turn on and work just fine. So for now the monitor is working.
***Update***
Actually I did read the whole thread. Twice. But as I mentioned in my first post to this forum yesterday I am new to this troubleshooting of electronic boards, so I posted in an attempt to get help understanding what, if anything I'm doing wrong in this testing. I appreciate your comment yesterday about testing the voltage between both polls of the capacitor, it was the first time I ever tested a cap. Prior to that I was testing from voltage to a common ground screw.
Maybe I'm taking this prsonally, but the tone of the people on this board has been a little bit... unwelcoming... Anyhow, thanks for the useful info. I'll ask my friend to help me with this. Maybe if I point him to this forum he'll get a more friendly response than I did.
Thanks...Comment
First of all, my congratulations on a forum this large and full of expertise.
Now, to present my problem.
I got this monitor from a friend, he did a caveman U406 fix, shorted the bottom contacts with wire, but didn't solder, instead he used duct tape to fix it in place(?!?!?)...
Needless to say, that stopped working after a while, he once more tried to bridge the contacts, with wax no less (?!?!?!), but then the monitor finally decided to die. So it's up to me to revive it (if possible), in order to use it in my soon-to-be MAME cabinet.
What I've done so far:
Soldered bottom U406 contacts, but still won't turn on. My suspect is the PSU, since it gives out there voltages:
Big Cap: 325V (that's OK, since I've got 220V AC)
after a few minutes connected to AC, gave ~350V
black - 0.00v
brown - 0.00v
red - between 13v and 13.20v, oscillates randomly, after a few minutes gave a bit higher reading, still in an oscillating fashion)
orange 0.00
green ~ 5v (oscillates, +- peaks a bit wider than red)
Yellow ~ 5v (oscillates, +- peaks a bit wider than red)
blue 0.00v
black 0.00v
Also, one more thing: the PSU emits a low volume click-like sound every 4 or 5 seconds (sounds like a relay or something, but I'm not really an expert in this field)
The caps look more or less OK, i really hope it's not a total goner.
Some bad pics (3.2MP camera and 1 AM, what can i do?)
If you need any more pics/measurements, feel free to hassle me, I got plenty of free time and solder.Last edited by ogisha007; 03-09-2012, 06:20 PM.Comment
black - 0.00v
brown - 0.00v
orange 0.00
blue 0.00v
black 0.00v
2) Your SMPS is not starting up properly which is causing the the DC voltage fluctuation.
3) Reasons could be (which will require a multimeter to test)
a) bad SMPS IC
b) bad startup cap
c) shorted component like a diode on the secondary sideLast edited by retiredcaps; 03-09-2012, 07:15 PM.--- begin sig file ---
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by Destroyer-Br[HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
I'm working on an Acer Nitro 5 unit with the following specs:- Motherboard: LA-J871P Rev: 1B
- Model: Acer AN515-55-59MT
- S/N: NHQ7JAL00403906A973400
- SNID: 03902728734
Initial Issue
The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by usbdeviceHi all
There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
https://www.badcaps.net/forum/showthread.php?t=50657
https://www.badcaps.net/forum/showthread.php?t=40512
The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
It's my dad's old monitor. He...-
- Loading...
