Troubleshooting LCD inverters: what makes them fail?
+ More Options
Posts
  • jpm
    • Aug 2009
    My Dell D610 Display started to go bad - it was purplish when starting up, then one day it blacked out. I was able to revive the display for a while by pressing the lid-close switch, but then finally it became unusable.
    I removed the inverter and tested it in an older D600 display and it worked fine. I pulled the D600 inverter and put it in the D610, and my display is usable, but something is still wrong with it. There's a very high pitched sound coming from the inverter. I also still get the purple tinge for a couple of seconds when it first turns on.
    So I'm suspecting that the inverter isn't the root cause, and that if I leave things as they are, I'm going to be replacing inverters every few weeks/months.
    Could the CCFLs cause this problem some how? I thought if the CCFL failed, the display wouldn't light up at all.
    If it's not the CCFL, then could the power to the inverter be the problem, or something else?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Troubleshooting LCD inverters: what makes them fail?
    bad lamp.
    • EGuevarae
      • Nov 2008
      • 1336
      Purple/Pink hue is a sign of a lamp in its final hours. Pitched sound can be voltage arcing from a broken end of the lamp, or an inverter saying that it is being overloaded by a faulty CCFL. Change the CCFL as KC suggested.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
      • Sus256
        HISENSE 65E7KQ PRO - no boot
        by Sus256
        Hi all!
        HISENSE 65E7KQ PRO
        RSAG7.820.13512 - chassis
        MT9618BAATAB - cpu
        RSAG7.820.12059 - power
        HD650Y3U77 - panel
        KLM8G1GETF - emmc
        Replaced emmc.
        Terminal log
        UART
        AC_ON
        E-B
        FDE enabled
        06-01-2025, 02:11 AM
      • x_orange90_x
        Vizio E55-E1 bad backlights or bad inverter?
        by x_orange90_x
        I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
        I don't know how exactly to test the inverter itself. Is it...
        01-29-2025, 09:24 PM
      • Gentian
        APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
        by Gentian
        I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
        It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
        03-06-2023, 07:07 AM
      • valvashon
        Insignia NS-LCD19-09 (PS OK, Inverter problem?)
        by valvashon
        For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
        History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
        01-04-2024, 01:44 PM
      • blues_spirit
        practical courses for troubleshooting pc motherboards
        by blues_spirit
        Hello from France,
        mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
        Do you think this is feasible for me? I...
        12-18-2022, 12:56 PM
