Help with dead Commodore 1802
  • R_J
    replied
    Re: Help with dead Commodore 1802
    I don't know how many times I have said it but you can NOT use the BEEP function for testing components. Most meters will beep between 0Ω and 150Ω
    As for the a/c or DC. You can check for A/C only to the two input (~) of the bridge rectifier, after that it is DC with reference to HOT ground (- of input capacitor C803) for any measurements in the primary side of T801, All DC measurements on the secondary side use the chassis for ground.
    If you are measuring 165v AC on C803 you are using the wrong ground!
    replied
    after the mains input diodes - it's all DC
  • roadrash
    replied
    Originally posted by R_J
    So did you figure out why R806 was checking shorted in circuit?
    Not entiely sure but might be because I had my meter on diode setting so it beeps, but when isolated, it gives a reading of 71.59k so its within tolereance isn't it. Its a a big grey cap and marked as 3w 68k. Another resistor I was suspicious about as it was showing as a short or beeping on my meter and I lifted one end to isolate was R808. But again when isolated measures ok at 2243 ohms so this I beleive is also ok. Could some of these readings be beacause these all go through the big transformer T801.
    Since then I removed the L805 again and reconnected the bulbs like we had before and powered it up again and looked back through this thread and took some voltage reading again now I have a better idea wheer everything is and here is what I got:
    At filter cap C803 =165V AC
    On T801 at pin 2 and pin 4 there is = 165 V DC on both
    At the pins 4 & 5 of the LOPT = 10V DC
    I hope these make sense.
    I get confused whether we are dealing with AC or DC voltages because although with AC there is no positive (+ ) & negative (- ) and I can use either of the 2 240v inputs from the mains. With DC voltage there is polarity and I dont know where I should be putting the black probe to. I usually connect the black probe to a heatsik or the outer connection on a RCA jack as the negative and these are usualy Negative. Am I doing this right? I am not sure at which point in the circuit (diodes) the voltage is recified and we get a Positive and negative voltage. Once I can get my head round this I shouldnt be as confused checking voltages whether AC or DC. Where is the best place to use as a reference negative side when taking a DC voltage.
    replied
    you cant really test the psu chip with a meter.
  • R_J
    replied
  • roadrash
    replied
    Your spot on its r806 and i removed it to check i was seeing those colours as reds and not an orange or something. Once i removed it and hooked up to my component tester it shows as 2.2k or within tolerence. Since then ive contined and checked every component within the psu area and nothing else is reading as abnormal. That surely leaves only things like inductors and transformers doesnt it?
  • R_J
    replied
    Maybe, it depends on what is across it in the circuit. I could guess where it is. The only 2.2k in the power supply circuit is R806 (they mark the locations) If it checks shorted Q806, C824 could be shorted.
    How are you checking it? What resistance does it check?
  • roadrash
    replied
    The "BONG" sound is just the deqausing coil. Unplug it. It has nothing to do with the power supply. look at the schematic, The deqausing coil is in series with the ptc PR801 and it is connected across the a/c line.
    Thanks for that info RJ.
    I decided that the only way I will find this hopefully is to check every single component one by one and any that dont give me the result I expect I remove from circuit to test again. So far ive tested quite a few caps, resistors and a few transistorsand so far all are testing ok except a resistor that is showing as a short. Its red,red,red & gold which is 2.2k I think. Should that be detected as a short?
  • R_J
    replied
  • roadrash
    replied
    Originally posted by stj
    worth a try, it;s obviously not drawing enough current to damage a resistor
    Well it blew the resistor again but not the fuse and once I solder the light bulb back in place of the resistor its still powering up in that I get that bong sound, but the tube heaters not glowing or anything. This is frustraiting. It the bong sound means its powering up then why doesnt anything ele. where do I measure the PSU output from, I want to see if when its going bong is it actually powering up and giving any power out and if so how much.
    replied
  • roadrash
    replied
    you should have 340v DC at the cap more or less.
    the sound is probably the degausing coil around the edge of the crt.
    Well I actually get 245v volts measuring between the filter cap we replaced and L802, but I measure between the filter cap and chassis ground I get 11v.
    Its encouraging that it makes that bong when its powered up as it just used to blow that resistor before but I still have the light bulb in place of the large resistor at present or should I remove that as well now so its back to what was original.
    replied
  • roadrash
    replied
    i'll go over the schematic again on saturday
    When i turn it on a can hear a faint bong sound which might be the audio amp. I checked and there is 240v at the filter cap..
    replied
  • roadrash
    replied
    so the only lamp is inplace of the inrush resistor?
    then it should be glowing.
    No the lamp thats in place of the resistor doesnt glow and the heater on the tube isnt glowing either.
    replied
  • roadrash
    replied
    Originally posted by roadrash
    Ok done that and it powered up without blowing anything but can see anything like the power light iluminate but at least i dont think anything blew.
    That was a bit unclear. Ive plugged it in and its taken power without blowing anything so thats got to be good. I still have the light bulb in place instead of the big resistor but I removed the light bulb and soldered back in the coil. I can sometimes faintly hear something when i turn it on but otherwise it doesnt do anything.
  • roadrash
    replied
    refit / connect everything other than the big resistor and try.
    replied
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • zunasthegreat
    Chieftec GPS-450-AA with dead 20N60C3
    by zunasthegreat
    Hello everyone hope all doing well!
    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
    09-01-2024, 07:12 PM
  • Beton
    Finding a dead short component
    by Beton
    Hi guys!
    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
    I have a bench PSU and if I try to inject voltage the voltage...
    12-10-2021, 01:05 PM
  • FiguringITout
    MSI Raider GE75 - Not posting, probable dead CPU
    by FiguringITout
    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
    07-25-2024, 07:27 AM
