Re: Help with dead Commodore 1802
So would have been better with a standard incandescent bulb like in a bedside lamp cos i thought about them but they are quite big still.
it will work for the task, although a not-halogen bulb has slower inrush.Leave a comment:
is that really a 240v lamp? i thought the ones with straight pins where 12v?Leave a comment:
yes, it will act like a resistor but instead of blowing it will just get brighter.Leave a comment:
yes,
but it's a pain in the ass.
replace the 10w resistor with a 15-25w lamp to save resistors,
then remove the transformer T801 and see what happens.
if the lamp goes full-on then we start to lift things 1 by one to find the cause.
my suspicion is a diode is failing at full voltage but looking o.k. on a meter that only tests with about 3v
i have seen this a number of times and it's a pain to track down.Leave a comment:
yes,
If I cant resolve this I will have no choice but to dump it which I absolutely hate doing to such rare items. Is there one last thing I can try before I have to give up?Leave a comment:
desolder coil L808
then you only have the psu running.
the str device could be bad btw, you cant test those with a meter properly.Leave a comment:
Please anyone how to I isolate everything except the PSU to trace this fault..Leave a comment:
you can lift L808 to isolate the audio stage.
im starting to wonder if the transformer could be breaking down, but few people have the equipment to check one,
(although i do)Leave a comment:
Yes thats right. Ive done as was said and checked all componnets in the PSU area for shorts incuding ceramics caps ansd cant find anything shorted. I wonder is there a way we can also isolate the audio section so we can just make sure its in the audio section.Leave a comment:
so a refresh of the facts,
with the coil out and just the psu & audio sections running your still burning resistors??Leave a comment:
Do you think its in the PSU area that could be causing this or ius it in the Audio amp area? Can you point me where I should look for theis short next?Last edited by roadrash; 07-12-2019, 08:56 AM.Leave a comment:
Ok i've checked all components in the PSU area again including ceramics and all I could find causing a short was resistor R805 (0.27ohms) This was all I could find that could be responsible for that wire wound resistor to keep popping.Leave a comment:
coils should look short - they are just a bit of wire,
ceramic caps are a bastard, they can go short without external signs, and withstand a LOT of current.
i have seen shorted ceramics blow tracks off the board!Leave a comment:
I only checked inside the marked area of the psu and didnt check the ceramic caps. I checked all diodes and electrolytic caps. I didn't know that ceramic caps went short circuit. It is ok when the coils (Lxxx) show as a short I think isn't it?Leave a comment:
so no shorted diodes or ceramic caps?Leave a comment:
I am not sure where to look now after not finding any shorted components in psu area of the pcb. Can you point where else I should check?Leave a comment:
by double_DDHi all,
As the title suggests, how can I be sure that my EC chip is really dead?
I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard... -
by disorderhello guys,
i need help to repair a edm-033 ps2
history : as always hdmi port and usb ports destroyed after unplugged
after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
so i changed it
now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
i don't see any projection of liquid metal on pcb.
by BetonHi guys!
I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
I have a bench PSU and if I try to inject voltage the voltage... -
Hello everyone hope all doing well!
I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...3 Photos -
Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)... - Loading...
