Help with dead Commodore 1802
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    #161
    Re: Help with dead Commodore 1802
    Originally posted by R_J
    Check if ic801 is shorted, pins 3 to 4
    I think your right RJ, there is a dead short for sure. I also have a new STR54041 here as well we can use.
    Edit: Just removed it and when removed it doesn't show a short
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      #162
      made a few more checks and it turns out that pin 3 on the IC has continuity with the metal backing of the IC. Also pin 4 on the PCB has continuity with the heatsink the IC is bolted to.
      So if there was contact between the back of the IC and the heatsink it would cause a short between pins 3 & 4. I cant see how that can happen as there is a bit Mica between the IC & heatsink. But still its a thought.
      • R_J
        • Jun 2012
        • 9535
        Continuity could mean anything, What is the resistance?, Look at the schematic... Between ic801 pin4 and ground there is a 2watt "continuity". If IC801 pin 3 is shorted to ground what do you think that is going to do with 330vdc on C802? The mica insulator is likely damaged and the ic could be damaged by now.
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          #164
          Thanks for your patience with this RJ. I meant in saying continuity that there was no resistance. Sorry if I miss desrcribed that. I thought that continuity meant a perfect conection with no resistance. The Mica piece looks fine. It was coated each side with heat sink paste. Other than that I couldnt see anything. Tomorrow I will put that new IC in and check it for a short before testing it. Should I apply heat sink paste to both sides of the mica again?.
          • R_J
            • Jun 2012
            • 9535
            Between ic801, pin4 and ground there is a 0.27Ω resistor. so it will check close to a short.
            Well if the mica was'nt damaged what was causing the short. It would be a good idea to identify what caused the short. Check if the ic itself is shorted between pins 3 & 4. If you just replace it you won't know what is causing the problem.
            The pin 3 is connected to the metal on the back of the ic, that is why you need the mica insulator.
            If you don't apply heatsink paste to the mica, the ic will run hot, The paste is to help conduct the heat from the ic to the heatsink.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              #166
              Looks like good news l as when i powered it on after putting the IC back in carefully and making sure of no short or too much heatsink paste squeezing out and getting over other things, it powered up properly I believe because it its making a sound like its powered up and I can hear a hissing from the audio stage which i think was the only thing not isolated after removing that inductor and replacing it with a bulb.
              there is 240v at filter cap and output of L802 is flickering between 9 & 12v DC but psu is not completely stable which is why its fluctuating using the bulb instead of the resistor. Even though the bulb is flickering its outputting voltage because I can definitely hear a sound coming from the speakers.
              What should I try now?
              • R_J
                • Jun 2012
                • 9535
                L802 is the inductor before the resistor. It will have AC NOT DC voltage. If you have 240vdc on C803. that is close to what it should be
                Do you have one bulb or two in place of the resistor? if only one try a second one in parallel. I suspect everything is working, so make sure everything in the secondary is connected as it should be, Then Check the voltages (DC VOLTAGES) on C812 (121VDC) and C814 (12VDC)
                If those voltages are close, then remove the lamps and replace it with a jumper wire for now. If the monitor works, then replace the jumper wire with the proper resistor.
                C806 & C825 when tested give the following results:
                C806: c=233nf vloss=1.5% ESR=1.6 ohms
                C825 c=12.25uf vloss=0.7% ESR= 3.0 ohms.
                Did you recheck these caps, and compare the values to the new ones? I will bet that C806 was the problem.
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #168
                  Thanks for the info, I fitted a different 60w halogen bulb i got the other day and it almost starts the PSU without another bulb. But If I add another with this one it wont start up. its certainly starting the PSU in as much as its powering up the audio section definitely.
                  C812=121VDC and C814=9.9VDC So its not far off.
                  I did try bridging across the R801 resistor but I was a little cautious about what gauge of wire to use so as not to do any other damage somewhere else if there is still a short.
                  So I used a single strand of copper from a small twisted wire and when I plugged the monitor in it went crack! and blew it up. So either its still shorting or it might be the wire I used couldn't handle the current. What thickness of wire should I use?
                  Iv'e tested it since then and it is still working ok so no harm done by that.
                  • R_J
                    • Jun 2012
                    • 9535
                    If the wire is too thin it won't work, If the monitor still had a power supply problem you would not be getting the 121 volts for the monitor.
                    I suspect the original problem was a bad C806, then when you changed ic801 you caused the short that blew the resistor. If you install a wire in place of the resistor and there is a problem, the 4 amp fuse should blow.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      #170
                      Sorry in delay ive been ill. I plugged it in with resistor bridged as you said and it popped a 5a fuse straight away.
                      • R_J
                        • Jun 2012
                        • 9535
                        I would get it back to where this is working. I don't know how you have things connected so I will assume you have the bulb in place of R801, correct?
                        You were getting 121 volts on C812, Were you getting 121v all the way to the deflection circuit and Q402 collector? or just to the lamp across C812?
                        FROM post52: Ive removed L805 and connected the bulb across C812.
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #172
                          Just been waiting for some 4A fuses to come as i only had 2A fuses left.
                          Yes its back to the same as when it was working but its not now of course
                          Not sure and anyway I cant find Q402 in the PSU area where its it connected too?
                          Bulb across R801 is lit up but the monitor seems dead again and no hissing from audio like we had. Putting that bit of wire across R801 blew something else other than the fuse I bet.
                          • R_J
                            • Jun 2012
                            • 9535
                            So what is the voltage across C803?
                            Check if there is a short between pin 3 and 4 of ic801
                            Check if Q806 or Q805 are ok and not shorted
                            Something was not working properly or the wire across would not have been an issue.
                            Check that IC801 is not shorted to the heatsink again.
                            • roadrash
                              • Oct 2015
                              • 490
                              • U.K.
                              #174
                              Thank you RJ, Luckinly now I am back to full health again (well apart from having MS) woopee!
                              No nothing
                              No short
                              I removed these two yesterday and checked them with my component tester which recognised them and said no problems.
                              I was afraid this might happen with a thick jumper and that's why I used a small thin wire the first time but I guess that thin it probably would have blown just under current draw through it.
                              Thanks again for all this RJ.
                              • roadrash
                                • Oct 2015
                                • 490
                                • U.K.
                                #175
                                Ive removed IC801 to be sure and there is no short.
                                There is a resistance between the pads 3 & 4 of IC801 that changes value like its connected to a cap or something which the Schematic seems to suggest and I think you mentioned before 27 ohm.
                                am I right? could this short we are looking for be in this area?
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #176
                                  I have got it back to where we were now and i have the psu working and audio section now working again.
                                  I replaced the IC801 and now its back working and i have a display now look.
                                  What now?
                                  • R_J
                                    • Jun 2012
                                    • 9535
                                    Good to see it's working. Feed it some signal and see what it looks like, One capacitor I have changed a lot is tv's and monitors it the drive transformer filter cap. C430 (1µf/160v) If you have one I would replace it.
                                      • 30979
                                      you should check the B+ voltage and compare it to the manual - it can be ajusted.
                                      it's DC btw.
                                      • R_J
                                        • Jun 2012
                                        • 9535
                                        it's DC btw.
                                        The voltage is regulated by ic801 but there is no adjustment, I agree on checking that the 121vdc is ok across C813
                                        • roadrash
                                          • Oct 2015
                                          • 490
                                          • U.K.
                                          #180
                                          I still have the light bulb in place of the resistor and I still have that other bulb in place of the indictor which was done to isolate the psu from everything else except audio so I dont get it how is the screen powering up?
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
