Weird color switching- Dell e171fp
  • Raji
    • Jul 2009
    • 6
    I've got an older dell 17" monitor that will sometimes change its color. its running in 1280x1024@60hz. I am fairly sure its not the video card or vga cable because I have ran a samsung (710 mp) 17" on the same exact system earlier in the day.
    sometimes it will switch back and forth rather quickly, sometimes the picture stays good and sometimes it look like its monochrome (of course now that I am trying to get a pic of it in "monochrome" its staying good, with a few teases). there seems to be no pattern in the color switching, i.e. it can be bad immediately after turn on or stay good after it has been on for hours. sometimes the screen will just flicker.
  • Raji
    • Jul 2009
    • 6
    Re: Weird color switching- Dell e171fp
    Here are the pics
    • Wizard
      • Mar 2008
      • 2296
      Looks like negative film look on that defanged image.
      Well, good idea to open it up (this is Samsung 170n/171n series). Opening case is started by taking the stand off (4 screws at VESA mount) then front up, carefully get under the bezel edge where LCD is and pull up carefully to unsnap hook, work along long sides, till you can get top two corners freed up. Then rest comes easier on bottom, when now apart, don't lift out yet, you have ribbon cable for the buttons snaking over the metal frame to the controller board is in the way. Make sure there are no screws left on back.
      Then carefully flip over on bath towel, lift out the back case. Gently unplug all the stuff except the power switch. Carefully lift LCD/metal frame out of the front bezel carefully because of fragile ribbon cable. Put LCD still facing down on towel. Undo 4 screws to get frame free from the LCD. Lift part-way, Feel around the LVDS cable plug for 2 tan color glue, carefully work these glue off and unplug the connector. Now you can seperate both power supply and controller as a unit from metal frame.
      And can see how the capacitors on the power supply are. (bloated or replace them).
      Cheers, Wizard
      • Raji
        • Jul 2009
        • 6
        I've replaced all the caps on the inverter, power supply, and I guess the logic board, I would send pics but my camera really sucks at fine detail
        • EGuevarae
          • Nov 2008
          • 1336
          I have a 15" wide "I-don't-remember-what-brand" brand LCD that is permanently in "negative mode".
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • Windows 10 Pro x64
          • GeForce GT1050
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            I had a problem like that but I use and old Gateway VX900 CRT. The color would go from brite and clear to washed out and then back to normal again for no reason at all. At other times windows and the internet would be colored right but if I started to play back a DVD it would be shown in black and white. The snake in my wood pile turned out being a bad stick of RAM. After changing out that RAM its been perfect ever since.
            "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
            Mark Twain
            "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
            John Paul Jones
            There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
            Rod Serling
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              shared video ram.
              thats how i got a nice board with 4gb xms corsair and a fx60.
              1 stick bad in the area the shared video uses.
              posted with stripes and blinking garbage.corsair rma is great by the way.
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                This is a good question for you Kc8adu. This mobo doesn't have onboard video at all. At the time of the color problem I was using a little 32meg AGP ATI card. How did the onboard ram failure screw up my video on the AGP card that has its own Ram? I'm now using the Nvidia Geforce FX5200. Its isn't the best card in the world but at least its 128 meg.
                Mark Twain
                John Paul Jones
                Rod Serling
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  the geforce fx 5200 needs a batter heatsink. one with a fan. i bought this for mine. i had a REALLY nice one but the bracket smacks into a couple capscaps. when mine come in ill post how it fits/performs.
                  sigpic
                  (Insert witty quote here)
                  • Junk Parts
                    Court Jester
                    • Jun 2006
                    • 8953
                    Mine already has a nice fan and sink on it. My brother put it on there when he was using it.
                    Mark Twain
                    John Paul Jones
                    Rod Serling
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      good. mine burnt my finger. ouch.
                      sigpic
                      • Junk Parts
                        Court Jester
                        • Jun 2006
                        • 8953
                        When I have something running hot enough to burn me I don't use it.
                        Mark Twain
                        John Paul Jones
                        Rod Serling
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          I'm using one 24/7 at the side of a 8500GT with stock HS and no fan and it does not get that hot.
                          • GeForce GT1050
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            mine is an xfx one: with 4, not 8 chips since i had the 128
                            i bought this for it (still being shipped):
                            will that be enough? my nice one does not fit. bracket too big.
                            sigpic
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • SuperJames
                              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                              by SuperJames
                              This one's a weird one, and still unsolved despite it having gone back to Dell once.
                              Specs
                              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                              Backstory
                              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                              10-23-2023, 04:09 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • mo000
                              DELL 3576 weird issue
                              by mo000
                              hi
                              i have dell 15 3576 i7 8th comes with weird issue
                              the laptop each random period maybe after 1 or 2 weeks not power on unless remove the cmos battery and reset the bios
                              i try update the bios but the same issue
                              what is the reason ?
                              is something about RTC circuit ?
                              any idea before i start the diagnostic .
                              05-22-2024, 04:20 AM
