I have here an AOC LM726 / TFT1780PSA+
When the picture comes up it seems fine (although this only happens for less than a second)
Symptoms:
At plug in, with no signal input I get:
Green LED for a few seconds
Changes to Orange LED
Screen/Backlight flashes/Speakers click
LED goes off
Repeat.
With Signal:
Green light comes on
Picture flash on screen and light goes off
Repeat
My first thought was that it's a PSU problem but since I have never tried to repair an LCD monitor I'm unsure if this behavior points to a fault in the backlight/inverter or not.
I opened it up and found 2 bloated Hermei on the PSU/inverter board. 470 uF and 1000 uF. There are actually 2x each of these caps but only 1 of each was bloated.
I replaced both 470 uF as that was all I had, but I noticed no change in the fault.
I have attached some photos
Can I unplug the backlights and power on to see if they are a problem? (Blue and pink wires on left side) Or will this cause damage to the inverter circuit?
Symptoms:
LED goes off
Repeat.
With Signal:
Repeat
