Viewsonic monitor - debug strategy and help
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Viewsonic monitor - debug strategy and help
    Originally posted by dantm
    Hi, the item number was: 230343529282
    I think it says broken screen so I don't know if that will help you.
    I wanted to place a bid on that unit (is on my watch list), but the shipping was high. That is like a standard practice nowadays.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • dantm
      • Mar 2009
      • 26
      Ha, so I've had the color fix for the last few days and all of a sudden today it's back to the missing colors/etc.
      It just happened while I was working -- all of a sudden the colors disappeared and I got part of the blueish hue as I showed in Page 1 of this post. Still over VGA only; no DVI.
      Waiting for the other LCD to show up.
      If it turns out it has a good screen I will let you guys know.
      What could be wrong with this one I have now - any thoughts?
      Thanks!
      • lucky13
        • Aug 2007
        • 412
        So I've cleaned the oxidation off using Flux cleaner and strangely enough the color issue went away. This is on the old motherboard (I'm still waiting for the dead monitor so I can swap out boards).
        The DVI connection still doesn't work, and I noticed what looks like oxidation underneath the DVI connector pins - where they solder to the motherboard. I tried cleaning that from the sides since I can't take that connector off (for now) and no go.
        Will keep you guys posted.
        Thanks for all the help so far!
        Hey, Viewsonic has lots of issue with DVI EDID problem. Did you try to swap a live DVI connection to test or you tried from boot up?
        • dantm
          • Mar 2009
          • 26
          I tried both and no luck. Along with the color problem I really think this monitor has a motherboard issue (I found lots of oxidation/etc. on the motherboard as per above posts).
          • Bobdee
            • Jun 2008
            • 461
            I would go with kc8adu advice, it makes sense looking at the condition your board was in before you cleaned it
            • ShyrikG
              • May 2009
              #26
              reconnect cable from motherboard to LCD (clean it)
              • dantm
                • Mar 2009
                • 26
                #27
                So I got the new (dead) LCD which turns out has a good motherboard. Swapped the motherboard into the one that I had with the color and DVI problem and it's working for now...let's see for how long!
                This new one has a screen that's in a pretty good shape but I don't know if it's useful at all. Maybe it has an inverter problem? The guys on eBay said it has a 'bad screen', but it's no physical damage/etc. to the monitor.
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Congratulations on your now working unit.
                  As for the dead one, normally they have either a bad PS or a bad inverter. Post a pic of the inverter of the dead one and maybe I can send you one from my dead units.
                  • GeForce GT1050
                  • dantm
                    • Mar 2009
                    • 26
                    #29
                    Here's the dead one; let me know your thoughts!
                    Thanks!
                    • lucky13
                      • Aug 2007
                      • 412
                      #30
                      Check those SMD fuses on the inverter board. Should be labelled F1, F2, etc..
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        They are thru-hole, like the green one on top of the upper Taicon Cap. Check them and see if they are open or not. And the inverter is not like the ones I have. The Lamp connectors are not the same. Yours have one narrow and one wide. Mine have three equal sized connectors on each side.
                        • GeForce GT1050
                        • lucky13
                          • Aug 2007
                          • 412
                          #32
                          Check F1 and F2 labelled "FP" on the top. They are on the left and right side of the power connector.
                          These should be 2A fuses.
                          • dantm
                            • Mar 2009
                            • 26
                            #33
                            Interesting -- mine are not like that at all - there's one F1 on one side and no F2 on the other side of the inverter power connector.
                            If they are blown is the component just burned out or can they be bad regardless?
                            Thanks!
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Thanks!
                              I've seen some open without being burned. And I agree that your board is not like the one in the pictures. Check to see if under the lower TAICON there's a fuse (I've seen all of the inverters for the VP102/211 with two fuses, but then again, anything goes ....)
                              • GeForce GT1050
                              • dantm
                                • Mar 2009
                                • 26
                                #35
                                Nope no fuses under the TAICON caps (there's two of these TAICON caps -- one on each side of the power connector).
                                See below for detail and the location of F1:
                                • dantm
                                  • Mar 2009
                                  • 26
                                  #36
                                  Also note the model of the inverter -- L20C-3, highlighted above...
                                  Is that the same one you have eguevarae?
                                  Thanks!
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Thanks!
                                    Nop. Lucky13's, mine & yours are completely different inverters (one uses 330uf caps and the other ones use 220uf caps but are arranged differently). Sorry.
                                    • GeForce GT1050
                                    • lucky13
                                      • Aug 2007
                                      • 412
                                      #38
                                      dantm,
                                      Can you summarize what is and what is not happening on this "dead" one?
                                      Is the power LED on?
                                      You have a meter to monitor the voltage on the fuse (try both ends). I suspect when the green light comes on (power), there should be a voltage here at the inverter board.
                                        by momaka
                                        03-15-2023, 10:17 PM
                                      • valscu
                                        EIZO SW3031W monitor blue color instead of black
                                        by valscu
                                        I have an Eizo SX3031W monitor and after a period i had problems with the tcon board. I did reflow, it went well for a while after but the problems appeared again. The second reflow attempt was a failure, the tcon board stopped working. In the meantime, I bought a perfectly functional Samsung 305T monitor from which I took the tcon board and installed it in the Eizo monitor. Since I turned on the monitor, the blue color appeared in the background instead of black. And also in Windows, appears blue instead of black. I tried various settings from the monitor and driver settings but...
                                        08-10-2022, 02:08 PM
                                      • wattage
                                        by wattage
                                        Hello Badcaps Community,
                                        07-13-2025, 04:41 PM
                                      • ant3202
                                        HP 27es - LED monitor - Monitor Flashing On - Off
                                        by ant3202
                                        Hi Everyone
                                        Lately I am experiencing the deja-vu incident on one of the led monitor like this.
                                        https://www.badcaps.net/forum/troubl...lashing-on-off
                                        The monitor is HP 27es LED Monitor
                                        https://h30434.www3.hp.com/t5/Deskto...e/td-p/6804692
                                        The monitor will randomly blackout and display no signal and will recover again.
                                        Sometimes need to power and off again to restore the display but...
                                        03-20-2025, 07:30 PM
                                      • Rick_1234
                                        by Rick_1234
                                        Good evening, gentlemen.
                                        Things I tried
                                        06-22-2024, 04:44 PM
