HP L1906 no backlight
  • lameck chilila
    • Apr 2009
    • 6
    My monitor has a backlight problem it comes on and I can see everything else in the background.What could be the problem?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: HP L1906 no backlight
    time to open it up,have a good look at it,and post good pics.
    iirc bad caps and a blown fuse were the issues on the last ones i fixed.
    • PlainBill
      • Feb 2009
      • 7034
      Operator error? According to your post, the backlight? monitor? comes on and you can see everything. What is the problem?
      PlainBill
      • lameck chilila
        • Apr 2009
        • 6
        I meant to say the backlight comes only for a feel seconds and after its gone I can still see stuff but its dark.
        • PlainBill
          • Feb 2009
          • 7034
          That is much clearer. This can be either a problem with the inverter or with the CCFLs. I've explained the problem elsewhere, but here is the short version.
          The logic board controls the inverter via two lines - on/off and brightness. When the inverter is commanded on it turns the CCFLs on at full brightness, then after about a second it begins to check the current draw of each CCFL. If the current draw is too low or too high it will shut down all CCFLs.
          One technique for testing CCFLs is to buy a CCFL case mod kit. This consists of two CCFLs and an inverter. By hooking the monitor CCFLs to the case mod inverter you can see if all of the CCFLs are working. And by hooking the case mod CCFLs to the monitor inverter you can see if the inverter is working properly.
          Note that I didn't think this up myself, far brighter people than me came up with this idea. And it's not an absolute test. I've got one monitor that all CCFLs work with an external inverter and the internal inverter will light external CCFLs at approximately the same brightness.
          PlainBill
          • lameck chilila
            • Apr 2009
            • 6
            hai,I tryed using an external inverter and the backlight worked just fine meaning my inverter is faulty.If I can get 9v across the input of the high voltage transformer then why would it to fail to work?The inverter uses the su'scon caps is this quality good enough? :noob
            • EGuevarae
              • Nov 2008
              • 1336
              Normally the inverters use at least 12v.
              And Su'scons just plain "suck's".
              Pics would help.
              There are 10 kind of people in this world: those that understand binary, and those who don't.
              • ASUS ROG Maximus IX Code
              • Intel Core i5-7600K 3.8GHz
              • 16gb GSKILL TridentZ RGB DDR4-3200
              • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
              • Windows 10 Pro x64
              • GeForce GT1050
                2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
              • DanPoka
                by DanPoka
                02-15-2025, 05:05 AM
              • Zilicon
                NEWSYNC B27F165 MONITOR HAS NO BACKLIGHT. board no: JY85QS_UPH_LS_R10.3
                by Zilicon
                Greetings everyone.
                Please I need help with the above monitor.
                Below is the summary of what happened and what I have done:
                The monitor started by turning off 2 seconds after it was turned on. It displayed with a backlight when it turned on. However, the standby light remains on after it is turned off on its own, I have to press the power button again to turn it on, but it will go back to standby after 2 seconds.
                The backlight driver IC is 0b3350cp.
                I applied a 370k SMD resistor on the CMP pin which is pin 6, while the other...
                11-07-2023, 09:12 AM
                by momaka
                03-15-2023, 10:17 PM
              • turmix
                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                by turmix
                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                During another reassembly, I made a mistake, and...
                01-29-2024, 03:48 AM
              • Chiro
                DIGMA PRO Art M Monitor 5K IPS 60hz only backlight
                by Chiro
                The monitor has no visible external damage and has not been dropped. Currently, the backlight is on, but no image is displayed. I have replaced the power and HDMI cables, and connected it to my laptop (the graphics card detects the monitor, but no image appears). The service menu is also unresponsive. Could anyone share insights on troubleshooting or repair options for this issue?
                07-06-2025, 02:21 PM
