Viewsonic VX2370SMH
  • Coinhunter
    • Oct 2011
    • 65
    Viewsonic VX2370SMH
    Monitor works flawlessly for about 15 minutes then slowly starts to lose color. Picture remains colors are just all screwed up. Checked the power board but no visual signs of problems. I suspect overheating causing the problems as there is almost zero air clearance to dissapate heat. Any ideas or suggestions?
    Re: Viewsonic VX2370SMH
    Can we see the screen shot so we can see what the pictures look like?
    May be you can use canned air duster upside down to cool the main logic board to help narrowing down the location of the problem.
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • Hondaman
      USB problems?
      by Hondaman
      Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
      (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
      I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
      08-12-2024, 03:26 PM
    • lostone
      Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
      by lostone
      Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
      First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
      When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
      05-19-2024, 11:40 AM
    • clabr
      Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
      by clabr
      Need help to solve some problems with this laptop.
      After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
      After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
      Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
      Before this had happened I observed some other problems:
      When I tried replacing original mecanical HDD with a SSD HDD could not get them...
      12-02-2021, 08:09 AM
    • skelband
      Viewsonic VX2235WM-3 problems
      by skelband
      I am trying to diagnose an issue with the above monitor.
      Initially, I assumed that it was a PSU issue, but I'm not so sure.
      OK, here are the symptoms:
      Powering on the monitor, the backlight comes on, but there is no display on the panel. The power light is illuminated Blue.
      After about 3 seconds, the backlight goes off and the the power light goes Amber.
      I cannot get it to do anything with the buttons with either the blue or amber lights illuminated.
      If I plug in a VGA source, then the panel stays on indefinitely, blue light + backlight....
      02-15-2021, 02:56 PM
