Issue with Westinghouse 19" LCD Monitor (large pics)
  • Welchs101
    • Sep 2008
    • 979
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Bobdee,
    Another quick question. When i try to review the datasheet for 3193 some of the pages appear "blank". Do you see all the pages when you view the pdf file?
    Before ordering the part i want to make sure the datasheets are comparable.
    thanks again.
    David
    • Bobdee
      • Jun 2008
      • 461
      #82
      Bluestar are as sound as a pound,
      get all 10 pages of datasheet, no blank pages.
      bob
      • Bobdee
        • Jun 2008
        • 461
        #83
        Originally posted by Welchs101
        Bobdee,
        thanks again.
        David
        Hello again David
        This should sort it for you,
        Go to posting 10 of the link below, the link on it will lead you to d/sheet of missing bit3713
        http://translate.google.co.uk/transl...3713%26hl%3Den
        bob
        • EGuevarae
          • Nov 2008
          • 1336
          Originally posted by Bobdee
          Hello again David
          bob
          Yep. I downloaded the 3193 datasheet and it looks like the same part. But only one GND on that
          There are 10 kind of people in this world: those that understand binary, and those who don't.
          • ASUS ROG Maximus IX Code
          • Intel Core i5-7600K 3.8GHz
          • 16gb GSKILL TridentZ RGB DDR4-3200
          • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
          • Windows 10 Pro x64
          • GeForce GT1050
            2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
          • tgray
            • Mar 2009
            #85
            Hi, I have the same monitor, failing the same as the others. I was going to get the caps that were described in post #23, with the Mouser numbers. But I see that in post #24 there were comments on the list. Did the list change after the comments? If I order the caps in #23 are they the correct ones? If the list changed, can one of you that ordered the caps give the corrected Mouser number?
            Thanks,
            Tony
            • EGuevarae
              • Nov 2008
              • 1336
              Thanks,
              Tony
              You can either go to the #23 list or add the corrections/ upgrades PC suggested on #24.
              And welcome to the forums
              • GeForce GT1050
              • Welchs101
                • Sep 2008
                • 979
                I am back again with a question. I have not ordered the BIT3713 replacement part from Bluestar since I found what i thought was a replacement for the entire "PCB" board. But i wanted to ask a question.
                MY power supply board (which looks similar to the one shown in the pics above) has the part number: DAC-19M005 DF (note the DF is hand written).
                The part number of the power supply board in this posting above (which has the pics) is : DAC-19M005 AF (note the AF is hand written).
                My question is this: I found a place where i can get a replacement board part number : DAC-19M005 BF (note BF is hand written) for very cheap....$30.
                My question is can i use the BF board to replace MY DF board?
                • PlainBill
                  • Feb 2009
                  • 7034
                  There are few guarantees in life, but this one sounds like a pretty safe bet. The hand written characters at the end of the part number are either version code, a revision level or a date code.
                  PlainBill
                  • Welchs101
                    • Sep 2008
                    • 979
                    Hi PlainBill,
                    Just want to be sure i understand your post.
                    So, can i be safe in assuming that the
                    DAC-19M005 (BF) will work for my DAC-19M005 (DF).
                    I hope so ...........
                    thanks.
                    David
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Hi PlainBill,
                      thanks.
                      David
                      Define 'safe'.
                      I would say there is a 90% chance that the DAC-19M005 (BF) is a slightly earlier version of the DAC-19M005 (DF), but functionally identical. The remaining 10% chance is that the two supplies are built on the same circuit board, but one version lacks some feature found on the other.
                      You state in an earlier post that the DAC-19M005 (AF) looks 'similar' to your power supply. What is the difference? Maybe a picture will help.
                      PlainBill
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Define 'safe'.
                        PlainBill
                        I second that. In fact, you can post a picture of the board you have, one of the board you're gonna get (if possible) and another of the board you reference from this thread.
                        • GeForce GT1050
                        • Welchs101
                          • Sep 2008
                          • 979
                          I am enclosing the pictures of my westing house (436,437,438,and 439). The other picture (1049456001) is a pic of the "BF" board. The (436,437, 438 and 439) are pictures of my "DF" board. They look identical except for the "BF,DF,AF" and revision numbers.
                          Are there any other pics you need?
                          Note: My monitor is a westinghouse L2046NV
                          • tgray
                            • Mar 2009
                            #93
                            All,
                            I was able to get my Westinghouse Monitor working by using the information from this thread. I have attached pictures of the repaired board.
                            1. I used the capacitors from Mouser as described in post #23, there were corrections to this post in #24, but I didn't know my electronics well enough to translate into a change in the Mouser order. (Note that this post was modified since I got the list and appears to have been corrected. The 1000uF 25V that I ordered was the wrong size, so these 2 caps were the only ones I didn't replace).
                            2. I did NOT replace the MOSFET's, but your problem may be different then mine.
                            3. I did find that the small fuse on the solder side of the board was blown (tested with a multi-meter, so I soldered a wire over it, this is not recommended and I need to find a replacement fuse so if the capacitors go bad again I don't fry the board beyond repair.
                            4. The 100uF 420V replacement for the 400V that was their it fine, just a little longer.
                            5. The attached pictures show the front and back of the board with red arrows pointing to repaired areas.
                            My monitor model number is L1975NW
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              Note: My monitor is a Westinghouse L2046NV
                              The 1975 and the L2046NV (just like the one I'm using now) use the same PSU. I say that you go for it. Also, please let us know where to get the PSU for $30 if possible. Maybe It can come handy later...
                              • GeForce GT1050
                              • Welchs101
                                • Sep 2008
                                • 979
                                The board DAC-19M005 is found at discount-merchant.com
                                http://www.discount-merchant.com/We-...-viewsonic.htm
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  'Sorry, the following item is currently out of stock: "DAC-19M005 PC MONITOR - POWER SUPPLY FOR VIEWSONIC N/A - 2995302800'
                                  Out of stock. But good price.
                                  • GeForce GT1050
                                  • Welchs101
                                    • Sep 2008
                                    • 979
                                    Yes, i contacted the company and the item is indeed out of stock but they said they were going to be getting more in within the next month or so.
                                    • Braymond141
                                      • Mar 2009
                                      • 5
                                      #98
                                      They have been out of stock for quite some time... Goodluck getting that, odds are you wont.
                                      • Welchs101
                                        • Sep 2008
                                        • 979
                                        Thanks for the info. You might be right. I called the company today and they were still out and did not know when they would be getting any in.
                                        I did have another question.
                                        Regarding the MOSFETS:
                                        I could not find the "40T03GP" in mouser but i did find the following as a replacement. Is the following a good replacement?
                                        NTP45N06LG (from ON semiconductor.....MOSFETs- Power and Small Signal 60V 45A N-Channel).
                                        Dave
                                        • ExMORTIUS
                                          • Jan 2009
                                          #100
                                          Hi, I also have a bad fuse, Ware do i get one? can i find one on some scrap board i have.
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • keepread
                                            Dell monitor PSU vs Dell laptop PSU
                                            by keepread
                                            Hi there!
                                            Someone gave me their old monitor, it's Dell S2715ht.
                                            The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                                            Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                                            10-30-2025, 04:45 PM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • DqMagetz
                                            Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
                                            by DqMagetz
                                            Good day!
                                            I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
                                            Here are the voltage readings:
                                            • Input – 19V (stable)
                                            • +LCDVDD – 3.3V briefly, then drops to 0V
                                            • EDP_HPD – 3.3V briefly, then drops to 0V
                                            • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
                                            • EC BKOFF# – 1.8V briefly, then drops to 0V
                                            • PANEL_OD_EN – 0.3V
                                            Is it possible that the EC chip is corrupted or damag...
                                            07-12-2025, 09:37 PM
