Issue with Westinghouse 19" LCD Monitor (large pics)
+ More Options
Posts
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Issue with Westinghouse 19" LCD Monitor (large pics)
    Originally posted by gdement
    I'm concerned about these. These sizes might need to be low-ESR caps, and Nichicon KT series don't appear to be low ESR.
    Do they have these in the Nichicon HE? That would be a better choice.
    Saw the first two and the last two full desc, never saw the Audio grade in the middle. Also, providing the series gives PC (and others around the forum) the data he needs to make a very specific suggestion. See? the more data you give in, the more data you get out.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • gdement
      • Jan 2007
      • 690
      3x 25V 220μF (KF)
      2x 25V 1000μF (KF)
      1x 10V 2200μF (KF)
      1x 10V 1000μF (KF)
      1x 50V 47μF (GL)
      1x 50V 22μF (GL)
      1x 400V 100μF (KM)
      This is all still pretty new to me. I know low ESR is where I want to go, and I even see the parts list for Nichicon high-to-low ESR, I just didn't find my particular caps listed...maybe that's because they were too high of ESR. I'll do some more searching
      Nichicon HE is a good replacement for all of those (excluding the big 400V cap).
      But Nichicon HE doesn't come in 47uF. Maybe they have 47uF Chemicon KY, which are the same specs as HE. Or maybe you could use a 56uF, I don't know if that's safe or not.
      Don't use the Nichicon VY on the smaller ones - they aren't good enough to meet the old specs.
      I found the CapXon datasheets here:
      http://www.capxongroup.com/en/prod_all_cat_full.aspx
      Nichicon HE can be found here:
      http://www.nichicon-us.com/english/p...ini/list_f.htm
      direct link:
      • mobaar
        • Mar 2009
        • 18
        Alright, here is what I have planned in my cart now:
        Mouser #: 647-UPW1E102MHD
        Mfr. #: UPW1E102MHD
        Desc.: Low Impedance Radial Aluminum Electrolytic Capacitors - 105Degree 1000uF 25V 105c 12.5x20 20% 5LS
        Mouser #: 647-UHD1A222MHD
        Mfr. #: UHD1A222MHD
        Desc.: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 2200uF 10V 105c 12.5x20 20% 5LS
        Mouser #: 661-ELXZ500ELL470MFB
        Mfr. #: ELXZ500ELL470MFB5D
        Desc.: Radial Aluminum Electrolytic Capacitors 50volts 47uF 6.3X11.5
        Mouser #: 647-UHE1H220MDD
        Mfr. #: UHE1H220MDD
        Desc.: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 22uF 50V 105c 5x11 20% 2LS
        Mouser #: 647-UHE1A102MPD
        Mfr. #: UHE1A102MPD
        Desc.: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 1000uF 10V 105c 8x20 20% 3.5LS
        Mouser #: 647-UPTW6101MHD
        Mfr. #: UPTW6101MHD
        Desc.: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 100uF 420V 18X35.5 20%
        Mouser #: 647-UHE1E221MPD
        Mfr. #: UHE1E221MPD
        Desc.: Low Impedance Aluminum Electrolytic Capacitors - 105 Degree 220uF 25V 105c 8x11.5 20% 3.5LS
        I went HE where I could, went with a PT for the 420V/100uF, PW for another, and HD for yet another. I think this fits what everyone has been telling me. I'll leave this up overnight and make the order sometime tomorrow afternoon unless someone has an issue.
        EDIT: Oh, and yes, I did get to sizing these things up. I have a limit on height of 25mm, with the exception of the 420V cap, which will be on its side.
        Thanks!
        Collin
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Audio grade is fine for PC use.
          In most cases the only difference is the material of the leads [often copper w/tin plating] and that they etch the foil differently before forming the oxide layer on it.
          It helps in Audio apps and doesn't hurt in other apps.
          Yes HE probably exceeds the minimum required for all of theses.
          I see no reason they couldn't be used, just not what I usually use.
          ~~~ Now that list I can work with ~~~
          FC is a close match to KF
          - In some the FC is smaller cap than the same uF/volt in KF and in those cases FC may be rated less than KF.
          - Only affects the 2200uF/10v in this particular list.
          GL are better than FC in those sizes.
          The KM is a general purpose cap with 560 mA for ripple rating.
          KF_______
          25V 220μF 8mm (KF) 550/.150
          -- FC [8x11.5 mm] EEUFC1E221, 555/.117
          25V 1000μF 13mm (KF) 1650/.045
          -- FC [12.5x20 mm] EEUFC1E102, 1655/.038
          10V 2200μF 13x20 mm (KF) 1750/.041
          -- FC [10x30 mm] EEUFC1A222L 1815/.035 [Recommend FC if not too tall]
          -- FC ~16v~ [12.5x25 mm] EEUFC1C222 1945/.030 [A viable alternate if 25mm fits]
          -- HE [12.5x20 mm] UHE1A222MHD6 1900/.035
          10V 1000μF 10mm (KF) 1040/.076
          -- FC [10x16 mm] EEUFC1A102, 1050/.068
          GL_______
          50V 47μF 8mm (GL) 285/.500 [FC, doesn't have a good match]
          -- Nichicon PW 6.3x11 mm 300/.430
          50V 22μF 6.3mm (GL) 135/1.00 [FC, doesn't have a good match]
          -- Chemicon LXZ 5x11.5 mm 155/.900
          KM_______
          400V 100μF 18x35.5 mm (KM) 560mA at 120Hz
          --- Chemicon KXG 18x31.5 mm -- 765mA at 120Hz
          Mann-Made Global Warming.
          - Dr Seuss
          • mobaar
            • Mar 2009
            • 18
            Thanks to everyone for their input; the order to Mouser has been made. Keep your fingers crossed.
            I have the replacement MOSFETs coming in either today or tomorrow. I have to think of a good way to get those things in without burning the board or the MOSFETs themselves. Probably will try to use an alligator clip when soldering leads into place.
            Anyone care to speculate on whether I should test the board after new MOSFETs are in place or should I wait for the recap job before plugging anything in?
            Thanks again to everyone!
            Mobaar
            • EGuevarae
              • Nov 2008
              • 1336
              Mobaar
              I went ahead and ordered them too.
              I have recapped it already. I guess it would be wise that you do it too before installing the new pair.
              • GeForce GT1050
              • mobaar
                • Mar 2009
                • 18
                #27
                Ugh, I'm finished but no dice on the backlight working.
                I've checked and double-checked capacitor polarity, made sure there weren't any shorts in the system or any solder crossover, but it's behaving exactly like it did last time.
                The MOSFET replacements checked out on a multimeter before I put them in, and it looks like everything is squared away. When I turn the monitor on, the backlight doesn't turn on; on the bright side (so to speak) there don't appear to be any overheating or shorting out parts.
                Is there anything I'm overlooking? It seems like something is just keeping the voltage from getting to those backlights. Maybe I can rig something to supply the power alternatively, but I really was hoping to get this fixed the old fashioned way.
                Any tips or advice? I can't seem to find any inconsistencies in the circuit. Heck I'm willing to pay someone a little something if they'd be willing to look things over and diagnose it. Or maybe someone can walk me through how to diagnose where the issue is coming from.
                Collin
                • EGuevarae
                  • Nov 2008
                  • 1336
                  Collin
                  Since we have the same board, same problem, but just different LCD size (mine is 20.1", yours is 19"), I guess I can help. I'm about to pull that box in front of the line, so I can get it and see what can I suggest.
                  Here's a picture of my board, that is discussed on another thread :
                  Give me a couple of hours and I'll be back with you. Too bad that my MOSFETS have not arrived yet .....
                  • GeForce GT1050
                  • anno
                    • Sep 2007
                    • 140
                    • netherlands
                    #29
                    find a IC in inverter area that handles the backlight. find a datasheet and look for the voltage supply pin (vcc). Check if the vcc pin of the IC is getting voltage (around 12-18 volt). If there is no voltage trace back in the circuit. maybe there is an open fuse or the "backlight on" signal is missing from mainboard (bad mainboard)
                    • mobaar
                      • Mar 2009
                      • 18
                      #30
                      Well the CCFL inverter IC is a BIT3713, a 16-pin IC. Trying to find the datasheet on it now.
                      Collin
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        Moobar, I have some questions for you.
                        But before, let me tell you that I had to make a quick trip to Mexicali (at the border, in Mexico, where I used to live), and as I didn't receive the MOSFETS, I bought them there. They cost there, at the current exchange rate, $1.20 USD. I bought two, and as soon I arrived home I installed them, and now I am typing using my newly repaired 20.1" Westinghouse. But I had the same problem as you : new MOSFETS in, same shit out : no backlight.
                        Before messing with the IC, look at this:
                        Right at the side of the MOSFETS, there's a jumper labeled J204.
                        I have 14v there, which I assume it is the voltage that feeds the inverter part of the board.If you don't have a V reading there, then move to the other side of the board.
                        There are small jumpers and fuses (SMD) there. The fuse highlighted was open in my board, so no voltage reached the MOSFETS. Replacing the fuse fixes the problem. Now I have image & backlight, but here's the question that you could answer me in case you fix yours too:
                        in the MOSFET at the left , I get the following readings :
                        S: 0.79v
                        D: 6.60v
                        G: 0v
                        In the MOSFET at the right, I get:
                        S: 6.54v
                        D: 14.06v
                        G: 4.14v
                        I replaced both of them, and after the readings, I switched them with each other. The readings remained the same (readings didn't move with the MOSFETS, so I guess they are not bad).
                        Any idea if this is normal, anyone?
                        • GeForce GT1050
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          no exact match... but it could help to find the correct pin..
                          http://www.alldatasheet.com/view.jsp...3713&q=BIT3713
                          edit: ^ see post above.. lol
                          • EGuevarae
                            • Nov 2008
                            • 1336
                            Scenic, any idea if this readings are normal?
                            • GeForce GT1050
                            • mobaar
                              • Mar 2009
                              • 18
                              #34
                              I am more than willing to look into this fuse issue like you are suggesting, but I have 2 very very elementary questions to ask (remember, I am new at this whole circuit board stuff!)
                              1.) I have my multimeter and I'm ready to take some DC readings with it. Red probe on the jumper in question, black probe where? Supposed to go to ground, but I want to make sure I'm doing everything exactly right before I go probing around on the PCB.
                              2.) How do I know if a circuit board fuse is "open?" Is this something visible or do I just do a quick continuity test?
                              Thanks again. I'll get on that tonight once I get some quick directions
                              Collin
                              • EGuevarae
                                • Nov 2008
                                • 1336
                                Collin
                                Red probe (+) on fuse, and black one (-) on GND. I first make the continuity test.
                                You can put the (+) on JP204 and the (-) on GND, and you should have a V reading (DC) if the fuse is OK.
                                • GeForce GT1050
                                • mobaar
                                  • Mar 2009
                                  • 18
                                  #36
                                  Right. Where *exactly* is GND? I've heard too many conflicting cases of where exactly that black probe is going. Sorry, it's really a very basic question.
                                  Collin
                                  • EGuevarae
                                    • Nov 2008
                                    • 1336
                                    Collin
                                    No problem.
                                    GrouND is any part of the metallic part of the chassis. You can put the probe in the screw hole right at the top of the barcode to the right. That's where I put the black probe when I was testing my LCD. That will serve to test on J204.
                                    • GeForce GT1050
                                    • mobaar
                                      • Mar 2009
                                      • 18
                                      #38
                                      Strange readings...
                                      Some of the time the jumper gave me readings of 0, but other times it would read exactly .375V (or .4V or .38V, depending on the setting of the MM). Continuity of the fuse was nonexistant.
                                      So if that proves that the problem is with that fuse...how in the world do I get one of those little things??? And how do I replace it? sheesh!
                                      Collin
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Strange readings...
                                        Collin
                                        I got a variable ohms reading sometimes, and sometimes a complete open. What I did, while I can get a fuse, was bridge the two ends of it with solder, just to test. It is not recommended to do it, but that is what I did. you can do it just to see if that is your problem. And I will take the fuse from a dead board I have around here. Test it and then if that's your problem, we can ask someone to suggest a replacement fuse. I guess it opened/failed when the MOSFET shorted (it is the fuse that protects the Inverter). My unit has been operational for more than two hours, and is a nice screen, despite having one stuck pixel (green dot always on). I don't mind 1 in the middle of millions ....
                                        • GeForce GT1050
                                        • mobaar
                                          • Mar 2009
                                          • 18
                                          #40
                                          Holy crap....it worked.
                                          • Cuboy
                                            HP probook 4510s mosfet issue
                                            by Cuboy
                                            I am currently trying to help a ONG by volunteering to help repair laptops, it's something that i have been into since 2017, always watching videos, on discords, forums etc...
                                            I have an HP ProBook 4510s laptop that does not power on and has no indicator lights, which suggests an issue with the power supply or the motherboard.
                                            I started by verifying that there is voltage at the input of the motherboard, confirming that the power adapter is working correctly. However, when I checked the voltage at the output of the first MOSFET (Q1032), I found 19V at...
                                            03-16-2024, 10:29 AM
                                          • ebyte64
                                            Lenovo IdeaPad 330 laptop mosfet issue
                                            by ebyte64
                                            Good day everyone.
                                            I have been scratching my head with a Lenovo laptop I got in today.
                                            The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
                                            Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
                                            Would anyone...
                                            06-27-2023, 10:19 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                            Westinghouse L2210NW LCD monitor - bad caps repair
                                            by momaka
                                            Here's another LCD monitor repair: Westinghouse L2210NW.
                                            Quick specs: 22” CCFL backlit LCD, 1680x1050 max resolution (16:10 aspect ratio)
                                            I got it with a bunch of desktops PCs from a repair shop that was trying to free up space a few years ago. It seemed like a cheap monitor, so I didn't really care that much at first when I picked it up (and indeed it is, picture-wise.) But hey, free is free, so I can't complain. Moreover, it looked clean and the screen didn't have any significant scratches or blemishes.
                                            Pictures of the monitor outside/case after a brief...
                                            01-11-2021, 01:14 AM
                                          • Nooy
                                            VGA MOSfet permanently shorted and loss of MOSfet pad
                                            by Nooy
                                            Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                                            I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                                            02-14-2024, 02:26 AM
