Benq Q7T4 (FP71G)
    Benq Q7T4 (FP71G)
    Hi guys, just done 5 of these today, all with dud caps @ c703, c704, c707, c708, c709 and c712 - or a mixture thereof.
    This last one is different, it has burnt through, C824.
    Now, as a relative 'Noob', i'm not to sure what else would have been stressed and what i should replace as a "precautionary" measure in that part of the board.
    Have found lots of mention re: C826 and such.. but nothing on this one.
    Cheers, and thanks for any help you may offer.
    David.
    My sludgebox:
    Intel Xeon E3110
    ASUS P5E
    CoolerMaster CM690
    CoolerMaster Extreme 650 PSU
    4GB Mushkin DDR2-800
    2 x Samsung 750GB HDD
    2 x WD 400GB HDD
    Everything else varies depending on the week
    Re: Benq Q7T4 (FP71G)
    Welcome to the forums.
    Pictures would help to get attention to this thread.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • Windows 10 Pro x64
    • GeForce GT1050
      Done, they be up today...
      My sludgebox:
      Intel Xeon E3110
      ASUS P5E
      CoolerMaster CM690
      2 x WD 400GB HDD
        Sorry for the delay.
        This is the state when i opened the machine, has already had a few caps replaced judging from the repair stickers on the back.
        As said, ANY help is appreciated.
        Cheers.
        My sludgebox:
        Intel Xeon E3110
        ASUS P5E
        CoolerMaster CM690
        2 x WD 400GB HDD
          Cheers.
          I guess that the Picofuses replaced by jumpers in the board might have helped to prevent this (just my idea. Someone more experienced here help us out).
          I guess you are referring to the part in yellow.
          - Have you checked the board? It powers up?
          - Have you replaced any caps yet?
          - Those look like Elites or CapXons. Can you give more info on them?
          - You said you've done 5 of those. Do you have any available that you can pull that part from to test this one?
          - Have you checked if the transistors at its side are not shorted?
          ... lots of questions. Well... that were the things that crossed my mind.
          • GeForce GT1050
            I'd say obvious components to check would be Q816 and it's complement on the other end of C824 (the number isn't visible). Also take a look at the solder side of the board. The control IC and some associated transistors are there. Compare them to the companion circuit around C825.
            As always, work with the power OFF and one hand in your pocket. (Guess how I learned that.)
            PlainBill
              Looks like .22uF 250V poly (not polymer) cap burned up. replace it should fix that. Remember to meter the 2 transistor between that grey capacitor for leak or shorts.
              These type of caps usually fail themselves on occasion. RCA uses these lot (grey box and blue boxes) and I seen them fail more frequently than anything else.
              Dipped poly caps do fine as well, use same rating: .22uF or 225 at 250V
              Cheers, Wizard
                Cheers, Wizard
                WWizard, what do you think about the PFs replaced by jumpers?
                Would be good to put some fuses there, or just leave it like that. I guess that when they designed the thing it was intended to have fuses there, or else the markings would read "Jxxxx" instead of "PFxxxx".
                • GeForce GT1050
                  Yes it powers up, has a "bloom" of light which disappears in 1 - 2 seconds, power light stays on, so i think the only real problem is the Inverter portion, TBH, i never looked at the others to see if they had the PicoFuses fitted or the links..
                  Unfortunately, the others i did have all gone back and be re-inserted into the "array" (there are 10 of them total, used for monitoring camera's throughout a factory.)
                  This was given to me to fix after the rest were done, otherwise i could compare them with each other.
                  <quote> As always, work with the power OFF and one hand in your pocket. (Guess how I learned that.) </quote>
                  I learned that from a couple of PS2's
                  Cheers, will post more details tomorrow when i get back to my bench.
                  My sludgebox:
                  Intel Xeon E3110
                  ASUS P5E
                  CoolerMaster CM690
                  2 x WD 400GB HDD
                    I still don't get the "one hand in your pocket" thing, but now that you mention it, do you have experience with PS2 slim? I have a couple of them here that would love to get working as the one we had is missing (after a party. Please, don't ask....)
                    • GeForce GT1050
                      if you keep one hand in your pocket a shock wont have a path through your heart.an arm to arm shock is most dangerous.
                      (bzzzt...thud!)
                        Cheers, Wizard
                        Hello Wizard
                        Sorry but can you explain what the 225 is, Im not following you there, when you got a spare minute.
                        Thaks bob
                          Originally posted by Bobdee
                          Hello Wizard
                          Thaks bob
                          I think he's talking about V rating
                          • GeForce GT1050
                            Suppose 226 or .22nF is marking on the solid capacitors. Is expressed in pF. nF moves three decimals, uF move six decimals. And this is also a multipler.
                            .22uF is either 220nF or 220000pF, Now look at how many decimal places is needed to move to the left or right to make pF in short form, that's 6 places. Now write 22 as capacitance size followed by decimals places in number (multipler) as 226.
                            My apologies for earlier error on "225". However!! The solid capacitors aren't expressed with 6 and 7 multiplers so thus written as .22uF or 220nF
                            This .22uF/220nF is common in 250V, 400V, 600V rating. I can come up with one easily from junk parts.
                            Cheers, Wizard
                              There are several ways to label a cap. Large electrolytics are easy. 220 uf, 25 V, a polarity band, the manufacturer's name, the series code, and even the date and place of manufacture all fit easily.
                              Smaller caps are more of a problem. one common way is the nnmtvvv marking.
                              nn= the two most significant digits of the value (22)
                              m = the number of zeros following the significant digits
                              t = the tolerance
                              v = the voltage rating, expressed in volts
                              So a capacitor marked 473K50 would be 47000pf (.047 uf), 10% 50 volts.
                              With larger values of capacitors some manufacturers mark the value directly. That's what was done in this case. The cap above it on the board is identical, and it's markings are AV (the manufacturer's logo) .22K250 This decodes as .22 uf, 10%, 250 Volt. Another manufacturer might use 224K250.
                              PlainBill
                                Thanks Fellas,
                                I like keep with you when I can, as you know it helps the knowledge chain, I dont mean to be a pain,
                                Many thxs
                                bob
                                  t = the tolerance
                                  PlainBill
                                  Now it makes sense to me too. It's just a matter of space constrains.
                                  OK, noted. Thanks guys.
                                  • GeForce GT1050
                                    Ihave a little cap calc/converter programer if anyone wants
                                    send me mail ps works email only here mon to friday till 4pm
                                    makes it easier to work from i.e
                                    104 to 100000 pico or 100 nano or 0.1 micro etc
                                      Sorry for my delay in replying to you all...
                                      I have ordered new 2sc5707's and will replace them when they arrive, also have new cap waiting to drop in.
                                      Will let you know the result when i fire it up.. Thanks to all who offered help..
                                      eguevarae, As for the PS2's... PM me ad i'll see what i can help you with
                                      My sludgebox:
                                      Intel Xeon E3110
                                      ASUS P5E
                                      CoolerMaster CM690
                                      2 x WD 400GB HDD
                                        okay.. Partial success.. the backlights now turn on (got the 2sc's today) and then the monitor just kind of "pixelates" and fades off..
                                        Am recapping the rest of the board now, but anyone got any ideas on what else could cause it ?
                                        My sludgebox:
                                        Intel Xeon E3110
                                        ASUS P5E
                                        CoolerMaster CM690
                                        2 x WD 400GB HDD
