attempt to repair power supply board
  • ryn0909
    Professor X
    • 122
    This is a continuance from my last post---> https://www.badcaps.net/forum/showthread.php?t=66677
    Hp f2105 monitor with a dead power supply board. id like to repair it myself instead of replacing with a different one. I like the challenge of learning something new that interests me.
    i decided to do some voltage reading comparison between a good working monitor, that was given to me and the one that i have that doesnt work. I have found an issue with mine but im not sure what to make of it. Checking the voltage at F851 and F852 the voltage fluctuates between 10vdc and 14vdc. the voltage at the same locations (F851 & F852) , on the good monitor, is a steady 18.98vdc any help is greatly appreciated.
  • gabik111
    ORD spotter
    • 142
    • USA / Poland
    Re: attempt to repair power supply board
    First of all get the schematic. It will be much much easier when you have a diagram of faulty device.
    What is the board number of power supply? I couldn't find on the pictures.
    Laptops and computers repair.
    • ryn0909
      Professor X
      • 122
      board number is 4H.L1S02.A21 im searching for a schematic as we speak, so far no luck yet.
      here as some pics of the board
      • R_J
        • 9561
        If you can't find a schematic, provide very good high res. straight on pictures of both sides of the board, that way we can follow the traces and "maybe" help with the repair.
        We can't trace the circuit with only top views.
        Have you changed the small elecrolytics like c606 c611?
        • ryn0909
          Professor X
          • 122
          ok im working on the images as we speak ill post asap
          im still trying to get a schematic for it but hp isnt wanting to cough it up
          • ryn0909
            Professor X
            • 122
            here are some pics let me know if u need more
            • Dumah Brazorf
              • Jun 2013
              • 179
              • Italy
              Are you measuring that voltages with all other boards connected?
              What if inverter and audio boards disconnected?
              • ryn0909
                Professor X
                • 122
                good question.... i dont exactly remember. ill take the measurement again and report back. ill do that rite now
                • ryn0909
                  Professor X
                  • 122
                  ok well after hooking it back up with all boards connected, i checked the voltage and it was fluctuating between 10vdc and 14vdc. i unplugged each board 1 by 1 and when i unplugged the logic interface board, the voltage stabilized at 18.98vdc. there was no change with any of the other boards plugged or unplugged
                  • Dumah Brazorf
                    • Jun 2013
                    • 179
                    • Italy
                    Well, let's have a look at the logic board.
                    • ryn0909
                      Professor X
                      • 122
                      i know for certain that the issue is in the power supply board because when i attach the board from my other monitor (same model) everything works fine. i just now took measurements at the connector on the power supply board (cn702) that connects to the logic board see attached pic
                      • Dumah Brazorf
                        • Jun 2013
                        • 179
                        • Italy
                        I think you caused some damage working on it.
                        I see several scratches on the pcb and a trace probably ripped near a cap.
                        Clean the board from all that dust/fur/hairs and check for continuity between solder points at the ends of all the traces that present scratches or you worked on.
                        • Dumah Brazorf
                          • Jun 2013
                          • 179
                          • Italy
                          Here the pads are gone. Make sure there's continuity between the soldering points of ic403 and the first component connected to that traces.
                          So again check all of your soldering for continuity.
                          I also see some solder between that diode and that resistor, check if it's ok on the other board.
                          • Dumah Brazorf
                            • Jun 2013
                            • 179
                            • Italy
                            What's that? Is there at least some solder on the central leg?
                            You're using too much heat and probably no flux, your solder pads/points are mostly destroyed.
                            If the solder point is destroyed jump wire to the nearest solder point.
                            • ryn0909
                              Professor X
                              • 122
                              yes there is continuity at the points of concern i made double sure of that. also the problem exsisted before i replaced the caps
                                • Jul 2011
                                • 6046
                                Either you are using to much or you are staining to long on those small pads
                                If you put heat on a pad and the solder does not flow to Desoldiering wick then get off of it and put new solder on the joint and try it again if that does not work use some soldering flux and try again or increase your heat a little bit
                                I hope this helps
                                I use a Desoldiering Gun which makes easier but you can have the same problem if you use to much heat or you stay on it to long or you put to much pressure on the tip can do the same thing
                                When I use the Desoldiering Gun I have the temperature set for 775* F but with this setting I am on the the soldering joint and off of it very quickly
                                Now for multilayer boards it gets a little trickier this is when I have to set it to 890* F
                                and I might have to leave on the there a little bit more for ground plains to begin to flow with small soldering joints I leave it there until it flows and get off it
                                I have also ran across some boards are just plain s**t and those I have setting at 650* F and sometimes you have have to leave there for a little bit more for the solder to flow I do not like working with these boards you can tell if it’s this type of board because if you have it set for 775*F and turns the area around the pad black or brown it’s probably one of those type board
                                • ryn0909
                                  Professor X
                                  • 122
                                  thank you but the solder joints are fine, they dont look the best but they arent shorted and they do have continuity.
                                  • Dumah Brazorf
                                    • Jun 2013
                                    • 179
                                    • Italy
                                    Could you measure the voltages at the connector on the good board?
                                    And on the bad with the logic one disconnected.
                                    Is C811 missing?
                                    • R_J
                                      • 9561
                                      I'll ask again, did you replace the small elec. caps in the primary?
                                      • ryn0909
                                        Professor X
                                        • 122
                                        sorry about that, i totally missed that question. No i have not changed the small electrolytic caps on the primary
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • penangit
                                          Hp v193 monitor power supply board
                                          by penangit
                                          Hey everyone,hope everyone is fine, I got an issue hoping you guys can help me,
                                          I got a HP V193 monitor it has a E59670 now i got a few of these, been using them for long time now, however this particular monitor was blacking out for a few times then after unplugging and plugging it back in it gets back to normal until now its dead.
                                          I tried switching the power supply board with another similar monitor and it works,so I'm trying to fix this power supply board I got some basic in electronics as a hobbyist.
                                          Steps taken so far:
                                          Checked all...
                                          02-21-2023, 04:00 AM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          by sam_sam_sam
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
