Replaced 820µF caps on syncmaster 2253BW, backlight still shuts off after 1s
    Hello
    I replaced 4 820uF 25V caps which had bulges, but as I didn't have replacement parts, I connected capacitors in parallel: 680uF+100uF which provides 780uF and 470uF+330uF=800uF. However, I don't notice any changes: the backlight still shuts off after 1 second. Is it so much dependant on capacitor values? Or may I replace more capacitors even if they seem OK (no bulges)? I already fixed some displays by only replacing capacitors which looked defective. But this power supply seems to be more tricky.
    Re: Replaced 820uF caps on syncmaster 2253BW, backlight still shuts off after 1s
    Could be one or more cfl lamps broken.
      Did you notice a pink hue before it started to shut off, or can you see it the very short time the lamps turn on?
      If that's the case, it is a bad lamp.
      There are 10 kind of people in this world: those that understand binary, and those who don't.
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • 16gb GSKILL TridentZ RGB DDR4-3200
      • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
      • Windows 10 Pro x64
      • GeForce GT1050
        2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
